kron0s 32 Posted August 27 Posted August 27 On 2/29/2024 at 9:02 PM, Luke said: Hi, what version of the Emby android app do you have installed? If you're referring to our standard app, there is no setting for passthrough because it auto-detects, although settings may get added at some point. I tested this and it doesn't auto detect properly. E-AC3 with Atmos doesn't get passthrough via the Emby App for Android but the Emby for Android TV is working. Now I have to switch back to Emby for Android TV.
Luke 43719 Posted August 27 Posted August 27 @kron0s Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
kron0s 32 Posted August 27 Author Posted August 27 2 hours ago, Luke said: @kron0s Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! I can open an issue but as a workaround if you can add the option to the "Android" version to toggle passthrough of audio formats like the Android TV version, it wouldn't matter that auto detect doesn't work. Thoughts?
Luke 43719 Posted August 27 Posted August 27 36 minutes ago, kron0s said: I can open an issue but as a workaround if you can add the option to the "Android" version to toggle passthrough of audio formats like the Android TV version, it wouldn't matter that auto detect doesn't work. Thoughts? No because the settings only exist to turn off passthrough, not to make it happen.
