familiezufall 2 Posted August 26 Posted August 26 (edited) Hi, I originally created my Emby database from a Kodi export. Now, almost all my folders contain low-resolution image files, all following the naming convention `moviename-fanart`, `moviename-poster`, etc. Can I search for all files ending in `-fanart`, `-poster`, etc., and delete them in a batch? Will Emby regenerate all these files upon restarting? Edited August 26 by familiezufall
GrimReaper 5223 Posted August 26 Posted August 26 (edited) 2 minutes ago, familiezufall said: Will Emby regenerate all these files upon restarting? Only on Refresh Metadata. Edit: Hm, do you want them to be recreated or you don't want them next to media? Edited August 26 by GrimReaper
familiezufall 2 Posted August 26 Author Posted August 26 i want new files like poster.jpg, discart.jpg etc
GrimReaper 5223 Posted August 26 Posted August 26 3 minutes ago, familiezufall said: i want new files like poster.jpg, discart.jpg etc Then as said: 7 minutes ago, GrimReaper said: Refresh Metadata If it's a multi-movie folder, they'll still be named: 9 minutes ago, familiezufall said: `moviename-fanart`, `moviename-poster`, etc. If each movie is in its own folder, they'll be named: 4 minutes ago, familiezufall said: poster.jpg, discart.jpg etc
familiezufall 2 Posted August 26 Author Posted August 26 if i refresh metadata, emby refresh only the files they have to refreshed or the complete hdd?
GrimReaper 5223 Posted August 26 Posted August 26 2 minutes ago, familiezufall said: if i refresh metadata, emby refresh only the files they have to refreshed or the complete hdd? You have several options: per-item, per-folder, per-library / Search for missing or Replace all, you pick the one that suits your needs the best.
