Jmackay82 79 Posted August 19 Posted August 19 New issue just started, tv guide for live tv not scrolling right, it goes down to the next line when you get to the far right of the screen and not browse later or another day
Luke 43680 Posted August 19 Posted August 19 HI, seems to be working OK in my testing. Can you show a screenshot example?
Jmackay82 79 Posted August 19 Author Posted August 19 Which front end you testing on? I am using the classic amazon firestick app on front end, I will record a video example and send it for you soon
Jmackay82 79 Posted August 20 Author Posted August 20 See attached. You can scroll until around 11 pm, but it won't go to the next day. The data is there when you manually pick the date, but it won't let you scroll like it used to. 20260820_173624.mp4 20260820_173553.mp4
Jmackay82 79 Posted August 21 Author Posted August 21 Issue is with both guide, with the mini playback guide and the main TV guide. If you change the date at the top of the guide forward a day or two, you can scroll through the days as usual, but the first day is limited when the guide first loads.
Jmackay82 79 Posted August 21 Author Posted August 21 Issue does not happen on the other amazon app in the store just the classic firetv app. I have checked my android phone version and the web version also, these seem to work as expected just the fire tv app having issues Version 2.1.51a running on server 4.10.0.26
Jmackay82 79 Posted September 1 Author Posted September 1 Tv guide issue is still the same is there an updated beta for the amazon tv app? Also not sure if its the amazon tv app or server as I usually mostly use the amazon app but recordings are starting late around 5-6 mind and the popup for "now playing" also has the same delay
ebr 17088 Posted September 1 Posted September 1 2 hours ago, Jmackay82 said: Tv guide issue is still the same is there an updated beta for the amazon tv app? I haven't tracked down any issue. If it is a huge problem for you, you can use the standard app.
Jmackay82 79 Posted September 1 Author Posted September 1 It happens on all my tvs running on the same server only become an issue from server 4.10.0.26 upwards If you can not track an issue down then it must be something with the seever @Lukewhat do we need to do some checks? i have attached my latest server logs for your reference. Only seems to effect the amazon version of the app, also recordings are not starting on time i am going to double check the time on my server shortly to make sure its not that for recordings issue. Emby is used in my home for all live tv on all tvs so these bugs are easily identified my side. embyserver-63923824841.txt embyserver (23).txt
Jmackay82 79 Posted September 1 Author Posted September 1 @ebrmy firetv beta version is 2.1.51a is that the newest build running on server 4.10.0.30
ebr 17088 Posted September 1 Posted September 1 3 hours ago, Jmackay82 said: my firetv beta version is 2.1.51a .54 is publicly released but I don't know why it would be any different in regards to this.
Jmackay82 79 Posted September 1 Author Posted September 1 I will try and uninstall and reinstall official release .54 and see if it fixes
Jmackay82 79 Posted September 2 Author Posted September 2 Same issue on .54 You can scroll the tv guide with no issues until you get to midnight of the current day then it scrolls no further. You need to select the calendar icon choose another day then there is no problems until you next bring up the guide. Happens on both TV guides the mini one while watching TV and the main full guide page
