Chris0248 4 Posted August 19 Posted August 19 Hi All, I have recently bought the UGREEN DXP6800 Pro and I’m having issues getting Emby working. I’m installing this image in docker https://hub.docker.com/r/emby/embyserver I’m clearly doing something wrong as my Synology build is rock solid and this is all over the place. Do we have a docker install guide for the UGREEN until the native application is released? It doesn’t matter what method i use i still get issues with the server not creating LibraryMonitor for my media libraries even though Emby has RW permissions. Cheers, Chris embyserver.txt
Chris0248 4 Posted August 19 Author Posted August 19 Hi Luke, thank you for the information. I will follow the guide and report back. 1
Chris0248 4 Posted August 19 Author Posted August 19 (edited) @Luke - what do you put in here please Luke, there is no mention of this in the guide? Edited August 19 by Chris0248
Chris0248 4 Posted August 19 Author Posted August 19 (edited) I removed it and proceeded with the install. Installed fine and works however i created a test library called movies and when I add new content to a library it is not processed at all even though I have checked "Enable real time monitoring" upon reviewing the logs no library watcher is created. embyserver.txt Edited August 19 by Chris0248
Luke 43390 Posted August 19 Posted August 19 1 hour ago, Chris0248 said: I removed it and proceeded with the install. Installed fine and works however i created a test library called movies and when I add new content to a library it is not processed at all even though I have checked "Enable real time monitoring" upon reviewing the logs no library watcher is created. embyserver.txt 76.21 kB · 1 download HI there, can you please provide a specific example? How to Report a Problem Thanks !
Chris0248 4 Posted August 19 Author Posted August 19 (edited) Hi Luke, I’m confused. How else do you want me to say that "Enable real time monitoring" isn’t working on the UGREEN. This seems to be a known issue?? I followed the guide to the letter, install went as expected. I setup the server with basic options as i have done 5 times now as i thought i must have been doing something wrong with my docker install that’s why i asked for the guide (turns out i wasn’t) i create the media links to /config and all my media folders and deployed the server. Setup the GUI and added a test library called movies. I then dropped in the film called Alien (1979) in the media folder "real time monitoring" is set up on and every single time nothing. The only way i can get Emby to detect new media is a manual scan. Apart from this bug it works a treat, but it must be permissions of some sorts?? Cheers, Chris embyserver.txt Edited August 19 by Chris0248
Chris0248 4 Posted August 19 Author Posted August 19 The only thing i can see in the logs is this Watching directory with new FileSystemWatcher for /movies for item 4 but i have no idea what the "for item 4" means
Chris0248 4 Posted August 19 Author Posted August 19 (edited) Yes it’s on the NAS in volume2/media/movies btrfs file system. Volume 2 also has a 2TB M.2 read cache volume1 is an M.2 NVME drive for system apps, docker and virtual machines etc Edited August 19 by Chris0248
Luke 43390 Posted August 19 Posted August 19 Do you have to use btrfs ? INotify probably does not support that.
Chris0248 4 Posted August 19 Author Posted August 19 (edited) The only other option when creating the storage pool was ext4 and I don’t like the limitations so I chose btrfs as most users would do with large storage pools. I have 6 x 18TB drives and want to use snapshots. I cannot do that with ext4. Also my current Synology NAS uses btrfs and Emby runs fine on that picks up any changes to the media folders. Edited August 19 by Chris0248
Luke 43390 Posted August 19 Posted August 19 OK I'm guessing the docker container must be adding an extra layer that's preventing it from working. Perhaps there's something to configure there. I'm not sure. This is something you may just want to reevaluate once we have a native package.
Chris0248 4 Posted August 19 Author Posted August 19 How close are we to going live with a native package?
Luke 43390 Posted August 20 Posted August 20 6 hours ago, Chris0248 said: @Luke It doesn’t make sense that they would say that. The real-time monitor in those other applications is built the same way.
Chris0248 4 Posted August 20 Author Posted August 20 @Luke Well at least you have your answer on the native application. Nothing for at least another 6 to 12 months. Seriously considering dropping UGOS and switching to TrueNAS.
