pierce1921 0 Posted August 16 Posted August 16 Does anyone know how to prevent emby from automatically joining/stacking two movies that have the names Part 1 and Part 2 in their title? I have two movies: "Chainsaw Man - The Compilation Part 1 (2025)" and "Chainsaw Man - The Compilation Part 2 (2025)" which have two different TMDB ids keep showing up as "Chainsaw Man - The Compilation Part 1 (2025)". When I move Part 1 out of the media folder it then picks up Part 2. But, Part 2 disappears when I put Part 1 back in place. I don't have any other media that I would want to auto join/stack, so I would prefer to turn that feature off completely. I am running emby version 4.9.5.0 on Centos 10.
Abobader 3544 Posted August 16 Posted August 16 Hello pierce1921, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
pierce1921 0 Posted August 16 Author Posted August 16 Yes. The first thing I did was turn off "Enable multi-part items". It still didn't change it's behavior.
Luke 43549 Posted August 16 Posted August 16 HI, did you also read the help text at the top of the dialog?
pierce1921 0 Posted August 16 Author Posted August 16 Which help text? On this forum or in the emby library settings?
RanmaCanada 601 Posted August 16 Posted August 16 (edited) Have them in separate folders for starters and name their folders and files properly as per the naming guidelines Name (Year) [tmdb=xxxx] Chainsaw Man - The Compilation Part 1 (2025) [tmdb=1544513] Chainsaw Man - The Compilation Part 2 (2025) [tmdb=1544707] This should fix it. Edited August 16 by RanmaCanada
pierce1921 0 Posted August 16 Author Posted August 16 It looks like renaming just part 2 using that naming standard: (i.e. Chainsaw Man - The Compilation Part 2 (2025) [tmdb=1544707]). It does indeed unstack the videos. Thanks for your help RanmaCanada! I will have to say that I think it's a bug, though. The library option of "Enable multi-part items" doesn't seem to work as expected.
Luke 43549 Posted August 16 Posted August 16 HI ,it works just fine, but it requires a library scan after changing.
