mattyg8 23 Posted August 14 Posted August 14 Currently in my server a have movies ect with both a 4k file and 1080p file all named correctly and they appear in the drop down menu to select which one to play. Currently it defaults to the 4k file, Is it possible to have a setting in play back to either set it to default to 4k or 1080 to allow some devices that struggle to play larger files. Or even better have a Movies default and Tv shows default. Thanks
mattyg8 23 Posted August 14 Author Posted August 14 (edited) @LukeAfter reading through that thread it seems its not going to be an option. I know in some apps you can set playback to 4k-200 mbps or 1080-60 mbps and is should pick the one based on this but some apps like emby apple tv and android tv you can only set the max to 1000 mbps and not chose either 4k or 1080 Edited August 14 by mattyg8
