Iskara 1 Posted August 10 Posted August 10 Yesterday out of nowhere my hardware acceleration stopped working. I was watching something on my server and suddenly it started lagging, which is why I turned down the bitrate of the series I was watching. After this, the entire system started crashing as soon as I use hardware acceleration for transcoding. I did check the logs for any information on why this is happening. There seems to be an error which I can't really make out what it means right before the log stops (Logs attached). At first I thought it was an error that occured because of my reverse proxy setup, however the same thing happens when I stream through the local network. I did once have a similar issue that I could resolve by changing the transcoding settings to only use QuickSync instead of VA API and QuickSync. The driver for my GPU seems to be installed and loaded, however the output to the Command lspci -k | grep -A 2 VGA outputs no kernel driver in use: 00:02.0 VGA compatible controller: Intel Corporation Iris Plus Graphics 650 (rev 06) DeviceName: Onboard - Video Subsystem: Intel Corporation Iris Plus Graphics 650 Also of note: Running any glx commands in the console gives me the following error: Error: unable to open display I'm kind of at a loss here and don't know what to do. If anyone can help me with this would be nice, I have absolutely no clue how to make this work, especially since I don't really understand much about transcoding or hardware drivers. If I can add any more information to help solve this let me know! Thanks in advance! embyserver-63921916800.txt
Luke 43390 Posted August 10 Posted August 10 Hi, there is no transcoding activity happening in this log file. Are you saying it happens without using it?
Iskara 1 Posted August 10 Author Posted August 10 (edited) 12 minutes ago, Luke said: Hi, there is no transcoding activity happening in this log file. Are you saying it happens without using it? It crashes before the transcoding can even start. The ffmpeg file gets created in the logs, however it just says "no items found" Edit: The file I sent was actually the wrong one, here's on with transcoding activity embyserver-63921916800.txt Edited August 10 by Iskara
Luke 43390 Posted August 10 Posted August 10 48 minutes ago, Iskara said: It crashes before the transcoding can even start. The ffmpeg file gets created in the logs, however it just says "no items found" Edit: The file I sent was actually the wrong one, here's on with transcoding activity embyserver-63921916800.txt 272.61 kB · 0 downloads I still don't see it in this log. This example here is direct play.
Iskara 1 Posted August 10 Author Posted August 10 1 hour ago, Luke said: Hi, there is no transcoding activity happening in this log file. Are you saying it happens without using it? It crashes before the transcoding can even start. The ffmpeg file gets created in the logs, however it just says "no items found" 18 minutes ago, Luke said: I still don't see it in this log. This example here is direct play. I recreated the error cause I was confused which logs contained any transcoding activity, this one should. embyserver-63921990415.txt
Luke 43390 Posted August 10 Posted August 10 and if you disable hardware transcoding in server transcoding settings, does it happen then?
Iskara 1 Posted August 10 Author Posted August 10 (edited) 44 minutes ago, Luke said: and if you disable hardware transcoding in server transcoding settings, does it happen then? No everything works fine without hardware transcoding. Also it worked fine before yesterday Edited August 10 by Iskara
Iskara 1 Posted September 20 Author Posted September 20 I finally got to test around a bit. The problem seems to be only with the H.264 encoder. When I use either QuickSync or VAAPI encoder it crashes. Haven't managed to test all the decoders yet but I will keep at it, so far the AV1 decoder works for sure. I've also tried to test it out with the transcoding-tests plugin. There it seems to work fine and the transcoding for both encoders worked from what I can interpret. I'd still really appreciate some help in this if anyone has an answer.
Iskara 1 Posted September 20 Author Posted September 20 26 minutes ago, Iskara said: I finally got to test around a bit. The problem seems to be only with the H.264 encoder. When I use either QuickSync or VAAPI encoder it crashes. Haven't managed to test all the decoders yet but I will keep at it, so far the AV1 decoder works for sure. I've also tried to test it out with the transcoding-tests plugin. There it seems to work fine and the transcoding for both encoders worked from what I can interpret. I'd still really appreciate some help in this if anyone has an answer. I've done some more tests and even the testing seems to be crashing the system now as soon as I use any hardware encoder.
Iskara 1 Posted September 25 Author Posted September 25 Yes. The QuickSync encoder and VAAPI encoder for H.264 crash my system without warning or logs when I use them.
Luke 43390 Posted September 26 Posted September 26 OK we'll have a new ffmpeg build on the server beta channel soon so it's possible that may help with this.
Luke 43390 Posted September 26 Posted September 26 For now you may want to disable hardware transcoding in server transcoding settings.
Iskara 1 Posted September 26 Author Posted September 26 6 hours ago, Luke said: OK we'll have a new ffmpeg build on the server beta channel soon so it's possible that may help with this. Okay thanks for letting me know! I'll try that as soon as it's available. 1
