Gabi92 2 Posted August 6 Posted August 6 Hi there. I´ve found an issue as few films has disapeared in emby but the files exist and can be played from the disk. When i try to scan the library there is an issue: 2026-08-06 17:09:05.216 Error ProviderManager: Error validating children for W 116964 /discos/Peliculas/Pelis/W *** Error Report *** Version: 4.9.5.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 6.8.12-22-pve (build@proxmox) (gcc (Debian 12.2.0-14+deb12u1) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC PMX OS/Process: x64/x64 Framework: .NET 8.0.25 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/lib/emby Application path: /opt/emby-server/system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Emby.Naming.Video.VideoListResolver.GetVideosGroupedByVersion(List`1 videos, VideoResolver videoResolver, Boolean supportMultiVersion) at Emby.Naming.Video.VideoListResolver.ResolveToResult(List`1 files, Boolean supportMultiVersion, Boolean parseName, Boolean isMixedFolder) at Emby.Server.Implementations.Library.Resolvers.VideoResolver.ResolveVideos[T](IEnumerable`1 files, Folder parent, IDirectoryService directoryService, Boolean supportMultiEditions, Boolean supportsMultiParts, BaseItem[] collectionFolders, LibraryOptions libraryOptions, Boolean parseName, Boolean checkSubFolders) at Emby.Server.Implementations.Library.Resolvers.VideoResolver.FindMovie[T](FileSystemMetadata[] fileSystemEntries, Folder parent, IDirectoryService directoryService, BaseItem[] collectionFolders, LibraryOptions libraryOptions, Boolean supportsMultiVersion, Boolean supportsMultiPart, Boolean parseName) at Emby.Server.Implementations.Library.Resolvers.VideoResolver.ResolveVideos[T](IEnumerable`1 files, Folder parent, IDirectoryService directoryService, Boolean supportMultiEditions, Boolean supportsMultiParts, BaseItem[] collectionFolders, LibraryOptions libraryOptions, Boolean parseName, Boolean checkSubFolders) at Emby.Server.Implementations.Library.Resolvers.VideoResolver.ResolveMultipleInternal(Folder parent, List`1 files, List`1 originalFiles, LibraryOptions libraryOptions, BaseItem[] collectionFolders, IDirectoryService directoryService) at MediaBrowser.Controller.Resolvers.BaseItemResolver`1.ResolveMultiple(Folder parent, List`1 files, List`1 originalFiles, LibraryOptions libraryOptions, BaseItem[] collectionFolders, IDirectoryService directoryService) at Emby.Server.Implementations.Library.LibraryManager.ResolvePaths(FileSystemMetadata[] files, IDirectoryService directoryService, Folder parent, BaseItem[] collectionFolders, LibraryOptions libraryOptions) at MediaBrowser.Controller.Entities.BaseItem.ValidateChildrenInternal(IProgress`1 progress, CancellationToken cancellationToken, Boolean recursive, Boolean refreshChildMetadata, BaseItem[] collectionFolders, LibraryOptions libraryOptions, Dictionary`2 newItemIds, MetadataRefreshOptions refreshOptions, IDirectoryService directoryService) at Emby.Providers.Manager.ProviderManager.RefreshCollectionFolderChildren(MetadataRefreshOptions options, CollectionFolder collectionFolder, CancellationToken cancellationToken) Source: Emby.Naming TargetSite: System.Collections.Generic.List`1[Emby.Naming.Video.VideoInfo] GetVideosGroupedByVersion(System.Collections.Generic.List`1[Emby.Naming.Video.VideoInfo], Emby.Naming.Video.VideoResolver, Boolean) What can i do to solve it? Thank you embyserver.txt
Luke 43391 Posted August 6 Posted August 6 Hi, yes this should be resolved for the next release. If you need immediate relief there is the server beta channel. Thanks.
Gabi92 2 Posted August 8 Author Posted August 8 Than you for the response. I´ve tried the beta version but the error is still there: 2026-08-08 09:01:29.039 Info ProviderManager: RefreshItem Start: 116949 Folder /discos/Peliculas/Pelis/H 2026-08-08 09:01:29.262 Error ProviderManager: Error validating children for H 116949 /discos/Peliculas/Pelis/H *** Error Report *** Version: 4.10.0.22 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 6.8.12-22-pve (build@proxmox) (gcc (Debian 12.2.0-14+deb12u1) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC PMX OS/Process: x64/x64 Framework: .NET 8.0.28 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/lib/emby Application path: /opt/emby-server/system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Emby.Naming.Video.VideoListResolver.GetVideosGroupedByVersion(List`1 videos, VideoResolver videoResolver, Boolean parseName, Boolean supportMultiVersion) at Emby.Naming.Video.VideoListResolver.ResolveToResult(List`1 files, Boolean supportMultiVersion, Boolean parseName, Boolean isMixedFolder) at Emby.Naming.Video.VideoListResolver.Resolve(List`1 files, Boolean supportMultiVersion, Boolean parseName, Boolean isMixedFolder) at Emby.Server.Implementations.Library.Resolvers.VideoResolver.ResolveVideos[T](IEnumerable`1 files, Folder parent, IDirectoryService directoryService, Boolean supportMultiEditions, Boolean supportsMultiParts, BaseItem[] collectionFolders, LibraryOptions libraryOptions, Boolean parseName, Boolean checkSubFolders) at Emby.Server.Implementations.Library.Resolvers.VideoResolver.FindMovie[T](FileSystemMetadata[] fileSystemEntries, Folder parent, IDirectoryService directoryService, BaseItem[] collectionFolders, LibraryOptions libraryOptions, Boolean supportsMultiVersion, Boolean supportsMultiPart, Boolean parseName) at Emby.Server.Implementations.Library.Resolvers.VideoResolver.ResolveVideos[T](IEnumerable`1 files, Folder parent, IDirectoryService directoryService, Boolean supportMultiEditions, Boolean supportsMultiParts, BaseItem[] collectionFolders, LibraryOptions libraryOptions, Boolean parseName, Boolean checkSubFolders) at Emby.Server.Implementations.Library.Resolvers.VideoResolver.ResolveMultipleInternal(Folder parent, List`1 files, List`1 originalFiles, LibraryOptions libraryOptions, BaseItem[] collectionFolders, IDirectoryService directoryService) at MediaBrowser.Controller.Resolvers.BaseItemResolver`1.ResolveMultiple(Folder parent, List`1 files, List`1 originalFiles, LibraryOptions libraryOptions, BaseItem[] collectionFolders, IDirectoryService directoryService) at Emby.Server.Implementations.Library.LibraryManager.ResolvePaths(FileSystemMetadata[] files, IDirectoryService directoryService, Folder parent, BaseItem[] collectionFolders, LibraryOptions libraryOptions) at MediaBrowser.Controller.Entities.Folder.GetNonCachedChildren(IDirectoryService directoryService, BaseItem[] collectionFolders, LibraryOptions libraryOptions) at MediaBrowser.Controller.Entities.BaseItem.ValidateChildrenInternal(IProgress`1 progress, CancellationToken cancellationToken, Boolean recursive, Boolean refreshChildMetadata, BaseItem[] collectionFolders, LibraryOptions libraryOptions, Dictionary`2 newItemIds, MetadataRefreshOptions refreshOptions, IDirectoryService directoryService) at Emby.Providers.Manager.ProviderManager.RefreshItem(BaseItem item, MetadataRefreshOptions options, CancellationToken cancellationToken) Source: Emby.Naming TargetSite: System.Collections.Generic.List`1[Emby.Naming.Video.VideoInfo] GetVideosGroupedByVersion(System.Collections.Generic.List`1[Emby.Naming.Video.VideoInfo], Emby.Naming.Video.VideoResolver, Boolean, Boolean) embyserver.txt
Luke 43391 Posted August 8 Posted August 8 OK that's strange. We'll have a new build up today. I've added one more change so please let us know if that resolves it. Thanks.
Solution Luke 43391 Posted August 9 Solution Posted August 9 Hi, new build is up. Please let me know if this resolves the issue. Thanks.
Gabi92 2 Posted August 9 Author Posted August 9 Hi Luke. With the latest beta is now working fine with some other errors, i attach the logs just in case. Thank you embyserver.txt 1
