vdatanet 1724 Posted August 5 Posted August 5 Hi, I'm building a tvOS client that uses the native Apple player (AVPlayer/AVFoundation) rather than a bundled software decoder. On Apple TV that's the only path that gets you hardware decoding, Match Dynamic Range and Match Frame Rate — but it also means I'm bound by what AVFoundation accepts, and that's where I've run into a wall. What I observe My device profile advertises HLS transcoding with an MP4 container: { "Type": "Video", "Protocol": "hls", "Container": "mp4", "VideoCodec": "hevc,h264", "AudioCodec": "aac,ac3,alac,eac3,flac" } I then POST to /Items/{id}/PlaybackInfo, follow the returned TranscodingUrl to the master playlist, and fetch the first variant playlist. What comes back is MPEG-2 TS: there is no #EXT-X-MAP:URI="..." initialisation segment, and every media segment URI ends in .ts. The "Container": "mp4" in my transcoding profile doesn't appear to change the segment format. Why this blocks a native Apple client Apple's HLS Authoring Specification for Apple Devices is explicit on this point: The container format for HEVC video MUST be fMP4. MPEG-2 TS is only sanctioned for H.264. HDR10, HLG and Dolby Vision all ride on HEVC, so they inherit the same restriction. In practice, on an Apple TV 4K, that means: HEVC can't be delivered over HLS at all, so everything has to be re-encoded to H.264; HDR and Dolby Vision sources get tone-mapped down to SDR; and since the player never sees the real video range or frame rate, tvOS can't switch the display — Match Dynamic Range and Match Frame Rate stay inert. The net effect is that a 4K HDR HEVC file the Apple TV would decode in hardware, untouched, instead becomes a full SDR H.264 transcode: more work for the server, and a visibly worse picture on the TV. But what about clients that can't handle HDR? That's the concern I've seen raised whenever HDR delivery comes up, and it's a fair one. The answer is the reason the HLS multivariant playlist exists in the first place, and the authoring specification states it directly: For backward compatibility, SDR streams MUST be provided. You don't choose between HDR and SDR — you publish both, described side by side in the master playlist. Each #EXT-X-STREAM-INF carries the attributes a player needs in order to judge it: CODECS, RESOLUTION, FRAME-RATE and VIDEO-RANGE. Every client reads that list and takes only what it can actually decode and display. A player with no HDR support never selects the VIDEO-RANGE=PQ variant, because it can see from the manifest that it shouldn't; it takes the SDR one instead. Nothing has to be decided server-side, no client has to be sniffed or profiled, and no client ends up holding a stream it can't play. This is also why the description matters as much as the segments do. On Apple platforms the player decides what a stream is before it downloads a single segment: it reads those attributes and uses them both to rule variants in or out and to pre-configure the display. If the HDR variant isn't described in the master playlist, tvOS has nothing to act on and the display-mode switch never fires, however good the segments underneath happen to be. The request Two things, and the second is what makes the first safe: fMP4 segments. When a client's transcoding profile asks for HLS with an mp4 container, emit fMP4/CMAF segments instead of MPEG-2 TS — ffmpeg's -hls_segment_type fmp4, which writes an initialisation segment referenced by #EXT-X-MAP:URI="init.mp4" and .m4s media segments. Gating it on the container the client declares, or behind a server setting, leaves today's TS output as the default, so nothing that currently works changes. An HDR + SDR variant pair in the master playlist for HDR and Dolby Vision sources: the HDR variant (VIDEO-RANGE=PQ, carrying the Dolby Vision codec string where it applies) alongside an SDR companion, each fully described. One URL then serves both a 4K HDR television and a device that can't take HDR, with no second trip through PlaybackInfo and no guesswork about the client. Questions Is any of this already achievable and I've simply missed it — a server setting, or a different property in the device profile? If not, are fMP4 segment output and the HDR/SDR variant pair things you'd consider? Happy to test against a 4K HDR/DV library and report back with player-side measurements: variant chosen, video range as the player reports it, and whether the display mode switches. Thanks.
Luke 43719 Posted August 5 Posted August 5 Try asking for m4s as the segment container. you can get fmp4. you can't get both hdr and sdr together in the same manifest.
vdatanet 1724 Posted August 5 Author Posted August 5 Thanks for the pointer — I went and measured it, and the result is worth reporting, because it changes what I'm asking for. First, a correction to my own post. I said the transcoding output was MPEG-2 TS with .ts segments. Against Emby 4.9.5.0 that doesn't reproduce. With my existing profile — "Container": "mp4", the one I quoted — the variant playlist already contains #EXT-X-MAP:URI= and the media segments are 0.mp4. That's fMP4. So request #1 in my original post is already satisfied, and I withdraw it. Either something changed since I took that measurement or I misread my own capture; either way the record should be straight. I did try m4s as you suggested. It works, but as far as I can tell it only changes the file extension — 0.m4s instead of 0.mp4 — with #EXT-X-MAP present in both cases. Same container, different name. If it's meant to do something more than that, I'd be glad to know what to look for. What actually blocks the native Apple player is the manifest description, not the segments. Here is the multivariant playlist Emby produces for an HDR10 source (Emby's own metadata for the item reports VideoRange: "HDR 10", ExtendedVideoType: "Hdr10" #EXT-X-STREAM-INF:BANDWIDTH=26581586,AVERAGE-BANDWIDTH=22151322,RESOLUTION=3840x1600,FRAME-RATE=23.976 There is no VIDEO-RANGE attribute and no CODECS attribute. This is the part that matters on Apple platforms, and it's independent of what the segments contain. AVPlayer decides what a stream is before it downloads a single segment: it reads the #EXT-X-STREAM-INF attributes to rule variants in or out and to pre-configure the display. With no VIDEO-RANGE=PQ and no codec string to inspect, tvOS has nothing to act on, so Match Dynamic Range never fires and the TV stays in SDR — even if the elementary stream underneath is perfectly good HDR HEVC. CODECS is also what lets a player reject a variant it can't decode without downloading it first; without it, every client has to guess. For contrast, this is what a correctly described HDR variant looks like — VIDEO-RANGE, a codec string, and Dolby Vision signalled via SUPPLEMENTAL-CODECS: #EXT-X-STREAM-INF:BANDWIDTH=44081437,VIDEO-RANGE=PQ,CODECS="hvc1.2.4.L150.B0,ac-3",SUPPLEMENTAL-CODECS="dvh1.08.06/db1p",RESOLUTION=3840x2160,FRAME-RATE=23.976 To pre-empt the obvious objection: for a lot of my library Emby decides to burn in subtitles (SubtitleMethod=Encode, TranscodeReasons=SubtitleCodecNotSupported), and a burn-in forces a full re-encode through format=pix_fmts=yuv420p — 8-bit, so HDR is gone regardless of the source. For those items, omitting VIDEO-RANGE would be entirely honest: you shouldn't advertise PQ if what you're sending is SDR. So I removed the burn-in entirely (it turned out to come from a remembered per-item subtitle selection on my user account, not from anything you do by default) and re-measured. Across the first 10 HDR10 and Dolby Vision items in my library, with no burn-in on any of them — TranscodeReasons=ContainerNotSupported on its own, no subtitle filter in the chain — none gets a VIDEO-RANGE attribute. The attribute isn't missing because the pipeline tone-mapped; it's missing because it never gets written. The server does receive the information, for what it's worth: with Property: "VideoRange" on the CodecProfile (I had been using Jellyfin's VideoRangeType, which Emby ignores — that one's on me), the transcoding URL comes back carrying hevc-videorange=SDR,DOVIWithSDR,HLG,…,DOVIWithHDR10,DOVI. So Emby knows the client accepts HDR. It just doesn't say anything about it in the manifest. On "you can't get both HDR and SDR together in the same manifest": understood, and I want to be clear that I'm not asking you to change that. The HLS Authoring Specification does ask for an SDR companion, but a single well-described variant would already solve my problem. If the manifest said VIDEO-RANGE=PQ and carried a CODECS string, an Apple TV 4K would configure the display correctly and a client that can't handle HDR would see, from the manifest alone, that it shouldn't select it. That's a much smaller change than restructuring into a variant pair, and it's the one I actually need. So the revised request is just this: populate VIDEO-RANGE and CODECS on #EXT-X-STREAM-INF (and SUPPLEMENTAL-CODECS where Dolby Vision applies), reflecting what the stream really is. And the stream really is HDR. I pulled the #EXT-X-MAP init segment and the first media segment, concatenated them and ran ffprobe — once on an HDR10 title, once on a Dolby Vision one: HDR10 → hevc (Main) · 3840x1600 · yuv420p · smpte2084 · bt2020 · bt2020nc DOVI → hevc (Main) · 3840x2160 · yuv420p · smpte2084 · bt2020 · bt2020nc smpte2084 is PQ and the primaries are BT.2020 — Emby is sending me HDR right now. It just doesn't say so in the manifest, and by the time the player has a segment in hand it's too late: on Apple platforms the display mode is decided up front, from the attributes. So this isn't a request to change what the transcoder produces. The bytes are already right. It's a request to describe them. Four questions: Is the absence of VIDEO-RANGE and CODECS deliberate, or just not implemented? Is there a server setting or a device-profile property that turns it on that I've missed? Would you also consider keeping 10-bit? The output is hevc (Main) at yuv420p — 8-bit — while carrying PQ and BT.2020 tags. PQ at 8 bits bands visibly, and HDR10 is defined as 10-bit. The source is Main 10, so the depth is being dropped in the transcode rather than being a limitation of the input. I notice the ffmpeg command line asks for -profile:v:0 main10 while the filter chain ahead of it has already done format=pix_fmts=yuv420p, which looks like the two ends disagreeing. The Dolby Vision title comes out the same as the HDR10 one: PQ and BT.2020, but no RPU or DV configuration record left in the stream. Is DV expected to survive a transcode, or is dropping to HDR10 base the intended behaviour? If the attributes were added, is there anything else on the Emby side that would stop tvOS from switching display mode? One footnote, in case it's useful to anyone else: this took a while to measure because most of my HDR titles were failing with HTTP 500 — Error starting ffmpeg. That turned out to be a burn-in of a subrip track that my account had remembered per-item, which puts subtitles=filename='<the same 18 GB mkv>' in the filter chain; that filter scans the whole container before emitting a frame, my media sits on a nearly-full ZFS pool doing ~34 MB/s, and the encode timed out. The same command without the subtitle filter produces its first segment in 14 seconds. Entirely my storage's problem, not a bug on your side — but worth knowing that a burn-in on a very large file can fail outright rather than just run slowly. Happy to test any build against a 4K HDR/DV library and report back with player-side measurements: the variant chosen, the video range as AVPlayer reports it, and whether the display mode actually switches on an Apple TV 4K.
vdatanet 1724 Posted August 6 Author Posted August 6 You're right — the server does populate it, and I can now show you exactly why it never reached me. There are two separate problems, one of them mine. Mine first. My CodecProfile was written with Jellyfin's range enum names (HDR10, DOVIWithHDR10…). Emby compares against the literal VideoRange string on the stream, which for these files is "HDR 10" — with a space. Your log says so plainly: Profile: VideoCodecProfile, DirectPlay=false. Reason=Atrium tvOS.VideoRange Condition: EqualsAny. ConditionValue: SDR|DOVIWithSDR|HLG|…|HDR10|…|DOVI So the server correctly concluded this client can't take HDR, and went off to tone-map (tonemap_opencl=tonemap=mobius). Omitting VIDEO-RANGE in that situation is the right thing to do, and my earlier post was wrong to read it as a missing attribute. Apologies. Now the part that isn't mine. When I fix the profile to "SDR|HDR 10|DolbyVision", PlaybackInfo accepts it — it even offers direct play for the title. But the TranscodingUrl it hands back has lost the space: Sent in the profile: Value = "SDR|HDR 10|DolbyVision" Came back in the URL: hevc-videorange=SDR,HDR10,DolbyVision And the manifest generator compares that against "HDR 10" again, so it fails a second time and tone-maps anyway. The two halves of the same request disagree with each other. Putting the space back by hand is enough to prove it. Requesting the same master playlist with hevc-videorange=SDR,HDR%2010,DolbyVision: #EXT-X-STREAM-INF:BANDWIDTH=26581586,AVERAGE-BANDWIDTH=22151322,VIDEO-RANGE=PQ,RESOLUTION=3840x1600,FRAME-RATE=23.976 There it is. VIDEO-RANGE=PQ, exactly as you said. So this is a serialisation bug, not a missing feature — and from a client's point of view it's unreachable, because the value that passes the profile check is the one the URL builder mangles. Two things still don't work even once the attribute appears: The segment endpoint throws. With the space present in the URL, /videos/{id}/hls1/main/init.mp4 returns HTTP 400 with an unhandled System.ArgumentException: The index is equal to or greater than the length of the array, or the number of elements in the dictionary is greater than the available space from index to the end of the destination array. So the correct value breaks the other end of the same round trip. That's why no client can work around this on its own. CODECS is still absent from the #EXT-X-STREAM-INF line even when VIDEO-RANGE=PQ is there. That one matters for a different reason: it's what lets a player rule a variant in or out before downloading anything, and on Apple platforms it feeds the initial decision alongside the range. Environment, in case it's version-specific: Emby 4.9.5.0 on Linux from the .deb, source is HEVC Main 10, yuv420p10le, bt2020nc/bt2020/smpte2084, in an MKV (so the container forces the HLS path rather than direct play). One last observation while I'm here, since it's the root of my original mistake: the ProfileConditionValue enum only exposes VideoRange, so a client has to match on a free-form string whose exact spelling — spaces included — isn't documented anywhere I could find. Meanwhile the stream itself carries ExtendedVideoType (Hdr10, Hdr10Plus, HyperLogGamma, DolbyVision) and ExtendedVideoSubType, which are properly typed but can't be used in a profile condition. Being able to condition on those would have made this whole class of bug impossible. Happy to re-test any of this against a fix.
vdatanet 1724 Posted August 23 Author Posted August 23 (edited) 5 hours ago, AJV20 said: is there a testflight for this new app? Thanks for the interest — genuinely glad to hear it. Where things stand, honestly: Atrium is on the App Store today and it's free, but right now it speaks Jellyfin only. Version 1.1 is with Apple for review as I write this, and Emby support is planned for 1.2, which I've already started work on. I can't give you a date, and I'd rather not invent one. 1.2 doesn't have a frozen scope yet, and on top of that every release goes through Apple's review queue, which isn't mine to control. One thing I'd rather say up front than have you discover it: in the first Emby release, HDR content will be tone-mapped by the server instead of played as HDR. That isn't the app being lazy — Emby's HLS manifest doesn't carry the VIDEO-RANGE and CODECS attributes that Apple's player reads to switch the TV into HDR mode, so letting the server map it down is the option that actually looks correct on screen. Everything else is meant to behave as it does on Jellyfin. If that changes on Emby's side, the app is built to take advantage of it the same day. https://apps.apple.com/app/id6777638751 Edited August 23 by vdatanet 1
AJV20 72 Posted August 23 Posted August 23 17 hours ago, vdatanet said: Thanks for the interest — genuinely glad to hear it. Where things stand, honestly: Atrium is on the App Store today and it's free, but right now it speaks Jellyfin only. Version 1.1 is with Apple for review as I write this, and Emby support is planned for 1.2, which I've already started work on. I can't give you a date, and I'd rather not invent one. 1.2 doesn't have a frozen scope yet, and on top of that every release goes through Apple's review queue, which isn't mine to control. One thing I'd rather say up front than have you discover it: in the first Emby release, HDR content will be tone-mapped by the server instead of played as HDR. That isn't the app being lazy — Emby's HLS manifest doesn't carry the VIDEO-RANGE and CODECS attributes that Apple's player reads to switch the TV into HDR mode, so letting the server map it down is the option that actually looks correct on screen. Everything else is meant to behave as it does on Jellyfin. If that changes on Emby's side, the app is built to take advantage of it the same day. https://apps.apple.com/app/id6777638751 Any plans for iOS support?
vdatanet 1724 Posted August 23 Author Posted August 23 11 minutes ago, AJV20 said: Any plans for iOS support? No plans for iOS at the moment — Apple TV is my only target for now. The app is built specifically around the tvOS experience (focus engine, remote, big-screen playback), so an iOS version would be a separate project rather than a quick port. Thanks for asking!
abat119 13 Posted August 25 Posted August 25 (edited) Just wanted to say a huge thanks for this! I only ever use the native player on my Apple TV and the emby implementation - while pretty good - is missing a few things when it comes to 4K playback. Regarding iOS playback - I use the safari web interface and that uses Apple's native player on iPad / iPhone - so that works and looks great. No need for a seperate app - keep focus on making this the best Native Apple TV Emby client (Emby team - maybe implement this app into the mainstream one? With blessings from the author of course ) Edited August 25 by abat119
Geordie 20 Posted August 25 Posted August 25 @vdatanet Have you ever thought about using the open source AetherEngine? It does on-device remuxing to specs-complaint Apple-friendly HLS and uses the platform-native AVPlayer with all the privileges that entails. https://github.com/superuser404notfound/AetherEngine That said, Emby’s HLS implementation still needs some minor improvements (it’s way better than when i last tried it years ago). Any improvements would be welcome.
vdatanet 1724 Posted August 25 Author Posted August 25 17 minutes ago, Geordie said: Have you ever thought about using the open source AetherEngine? Thanks for the pointer — I hadn't come across this one, and I went and read it properly, because I wanted it to be the answer. For my case it isn't, and I'd rather be precise about why than vague. Its README is explicit that a non-live remote .m3u8 handed to the loopback path gets rerouted onto the AVPlayer bypass: the bundled FFmpeg is built without network support, so the playlist can't be demuxed locally, and as they put it, remote HLS is AVPlayer's native domain anyway. That's a reasonable call rather than an oversight — but it means that pointed at an Emby transcoding manifest, the engine hands the same attribute-less #EXT-X-STREAM-INF to the same AVPlayer I'm already using, and the display stays in SDR for the same reason. The on-device remux is real; it applies when the source is something FFmpeg can open, not when it's already a remote HLS playlist. Where it would change things is by a route I hadn't considered, so the pointer was worth it anyway: skipping the HLS path altogether and direct-playing the original file. Once the CodecProfile uses the range spelling Emby actually compares against — the literal "HDR 10" from the MediaStream, with the space, on Property: "VideoRange" — Emby stops deciding to tone-map and offers direct play on these titles. I couldn't use that, because AVPlayer won't open an MKV. An engine that demuxes with FFmpeg and decodes with VideoToolbox can. So the value would be as a way around the manifest rather than through it, with the HDR coming from the original file untouched: 10-bit, and the Dolby Vision RPU still in place. I've written that down as a real option. It isn't a small one, to be fair to it. LGPL-3.0 with an App Store exception — well drafted, and it does cover the store's signing and re-linking restrictions, but only for the binary; the source obligations stay. Bundling FFmpeg. And on that path subtitle rendering moves out of the native tvOS picker and into the app's own overlay, which is a chunk of work I've already done once. It's a question for a later version. It's also why the two attributes are still what I'd rather have. VIDEO-RANGE and CODECS exist precisely so a client doesn't have to carry its own demuxer to find out what it's being sent — any client using the platform player benefits, and only the ones shipping FFmpeg can route around their absence. On "Emby's HLS implementation still needs some minor improvements" — which ones did you hit? The two I ran into are that the range value loses its space somewhere between PlaybackInfo and the transcoding URL, so the manifest generator never matches it; and that putting the space back by hand does produce VIDEO-RANGE=PQ, but then the segment endpoint answers 400. I owe this thread the full measurements on both and will post them. If you hit the same things from a different pipeline, or something else entirely, I'd like to know — you've clearly looked at this more recently than most.
Geordie 20 Posted August 25 Posted August 25 (edited) Why would you point it at Emby’s manifest though? The engine will ingest media files directly (mkv, avi, ts etc) so as far as the server is concerned, you’ll be direct playing via http. The engine will do what the server does (mkv to fMP4 + HLS to AVPlayer) directly on device and where not possible due to an older or unsupported codec, it will use ffmpeg software decode. Also, AVPlayer does DV to HDR to SDR tone mapping natively during playback. You don’t need to transcode to play DV on an SDR monitor (just need to skip the master playlist and play the media playlist directly instead). Lots of apps already use AetherEngine like Moonfin, Plezy, Silo, Sodalite… etc. I use Moonfin for Emby and Sodalite for Jellyfin. I do hope the web client gets better with HLS though as I prefer it to third party apps. It’s more power efficient on mobile. Edited August 25 by Geordie 1
vdatanet 1724 Posted August 25 Author Posted August 25 You were right about the route, and I checked rather than take it on trust — Moonfin direct plays these files and the device does the remux, exactly as you described. The approach works. It isn't the one I want for this app, though, and that's a goal of mine rather than a verdict on the engine. What I'm building leans deliberately on two things: the native tvOS player, and the server's own stream. No bundled engine, no external dependencies. That's a line I've drawn for myself, and it's why the app behaves the way it does — the system track picker, the system chapter menu, all of it comes free as long as I stay on the platform player. That combination already gives me real HDR wherever the manifest describes the stream. Here it doesn't yet, and that's the whole of the gap: VIDEO-RANGE and CODECS on #EXT-X-STREAM-INF, and the player handles the rest by itself. On the Dolby Vision point — playing the media playlist directly is the one thing I can't do, because the master is where the display switch comes from. Skip it and the TV never leaves SDR, whatever the segments contain. Still curious which HLS problems you ran into, if you get a moment.
vdatanet 1724 Posted August 25 Author Posted August 25 @Geordie When you suggested the engine, I said the route wasn't for me but the pointer was worth it either way. It turned out to be worth more than that. I kept turning it over — the part of your suggestion that stuck wasn't the engine, it was the route itself: stop negotiating with the server's manifest and do the remux locally. So I built a narrow version of exactly that. The app now carries its own Matroska demuxer and fMP4 muxer — about two thousand lines of Swift, no FFmpeg, no decoders, nothing bundled. It reads the MKV straight from the server with HTTP range requests (opening a 19 GB file costs 16 requests and ~300 KB, thanks to Matroska's cues), splits it into fMP4 segments on the device, writes its own HLS master — VIDEO-RANGE, CODECS, one audio rendition per track, all derived from the file itself — and hands that to the native AVPlayer. It never touches the bytes: video and audio are copied, not transcoded. HDR10, and the HDR10+ metadata that a server-side transcode strips, survive untouched. Measured last night on an Apple TV 4K, with a 19 GB 4K feature — Dolby Vision profile 8 over an HDR10 base, ~25 Mbps average: the display switches into HDR, and it switches from a 4K SDR output mode with Match Dynamic Range on, before playback starts — the case that used to be hopeless. The server's only work is serving byte ranges: the day's server log shows zero ffmpeg launches and ~1,300 HTTP 206 responses against the static file endpoint, and the dashboard reports the session as Direct Play. Seeking, chapter jumps and resume all behave like local playback — the cues map straight to byte ranges, so nothing round-trips through a session. So the line I drew in my earlier post still stands, and now it has both halves: the native player, the system track picker, no bundled engine — and the local remux you were right to point at. The difference from the engine route is only where the pieces come from: AVPlayer keeps doing the decoding and the UI, and the app only rearranges containers, which is the boring part and the one I'm happy to own. For everyone else on the thread: this doesn't retire the original request. VIDEO-RANGE and CODECS in the manifest are still what would fix this for every client that doesn't carry its own demuxer — which is nearly all of them. My app just stopped needing to wait. Thanks again, @Geordie. The nudge did more work than the suggestion. 1
Luke 43719 Posted August 27 Posted August 27 what's the media info from the web app for one that is missing the codecs value?
vdatanet 1724 Posted August 27 Author Posted August 27 56 minutes ago, Luke said: what's the media info from the web app for one that is missing the codecs value? That's the right question to ask, and the answer turned out not to be in the media info at all — so let me give you that first, and then what actually decides it. MEDIA INFO (Emby web app) — "¡La novia!", the item from my earlier posts Container mkv, 19.0 GB, 21.5 Mbps overall Video 4K HDR 10 HEVC Codec hevc · Profile Main 10 · Level 150 3840x1600 (2.40:1) · 23.976 fps · 21511322 bps Bit depth 10 · Pixel format yuv420p10le VideoRange "HDR 10" · ExtendedVideoType Hdr10 · ExtendedVideoSubType Hdr10 Color space bt2020nc · transfer smpte2084 · primaries bt2020 Audio Spanish AC3 5.1 (default) · 640 kbps · 48 kHz plus Spanish E-AC-3 5.1 and English E-AC-3 5.1 But the video stream isn't what decides it. Same item, same PlaybackInfo request, transcoding forced — the only thing I change is the audio codec my transcoding profile allows: AudioCodec=aac -> CODECS="hvc1.1.4.L126.B0,mp4a.40.2" AudioCodec=mp3 -> CODECS="hvc1.1.4.L126.B0,mp4a.40.34" AudioCodec=ac3 -> attribute absent AudioCodec=eac3 -> attribute absent AudioCodec=flac / alac / opus / dts / truehd -> attribute absent AudioCodec=aac,ac3 -> attribute absent AudioCodec=aac,mp3 -> CODECS="hvc1.1.4.L126.B0,mp4a.40.2" It isn't copy versus transcode either — it's the codec the audio ends up as. Two forced audio transcodes, in opposite directions, on two MKVs. Neither source has the codec being asked for, so neither of these can be a stream copy: Cartouche (source AAC) -> out ac3 (aac -> ac3) absent ¡La novia! (source E-AC-3) -> out aac (eac3 -> aac) CODECS="hvc1.1.4.L126.B0,mp4a.40.2" So: the attribute is written if and only if the output audio codec is aac or mp3. I checked 14 items and it holds in all 14. I deliberately kept every one of them in MKV, because MP4 sources take a different decision path (TranscodeReasons=DirectPlayError on its own, rather than ContainerNotSupported,DirectPlayError) and I didn't want the container to be a second variable. Within MKV that still covers HDR10, Dolby Vision and SDR; HEVC, H.264 and VC-1; and source audio in E-AC-3, AC-3, DTS, TrueHD, MP3 and AAC. Which I think explains the whole disagreement earlier in this thread. You were right that the server populates it. I was right that I never see it. Both, because mine doesn't ask for a single audio codec — it advertises aac,ac3,alac,eac3,flac, the server picks the source AC-3 track, and the attribute disappears. I'd expect that to be true of any profile that passes AC-3 through rather than transcoding it, but I've only measured my own. That's also why "which item?" has no answer: it isn't the item. Two things, and the second matters more than the first: 1. AC-3 and E-AC-3 do have codec strings — "ac-3" and "ec-3", both in Apple's authoring specification. They just don't seem to be in the mapping. 2. More importantly: when the audio half can't be produced, the whole attribute is dropped, including the video half that was computed correctly a moment earlier. Even with an audio codec you have no string for, emitting CODECS="hvc1.2.4.L150.B0" on its own would be valid HLS, and it's all a player needs to rule the variant in or out before downloading anything — which is the whole of my original request in this thread. And the good news, because I don't think you're far from it at all. Here is the same server, same version, on a Dolby Vision source with AudioCodec=aac: #EXT-X-STREAM-INF:BANDWIDTH=31738634,AVERAGE-BANDWIDTH=26448862,VIDEO-RANGE=PQ,CODECS="hvc1.2.4.L150.B0,mp4a.40.2",RESOLUTION=3840x2160,FRAME-RATE=23.976 VIDEO-RANGE=PQ, a Main 10 codec string, fMP4 segments with #EXT-X-MAP, and both init.mp4 and the first media segment return 200. That is a fully described HDR variant, produced by 4.9.5.0 with no patching of any kind. Everything I asked for at the top of this thread is already in there. Two small things stand between that and every other file: this AAC-only mapping, and the space in "HDR 10" from my earlier post. That range name is the one difference here — "DolbyVision" has no space, so it survives the round trip through the TranscodingUrl and reaches the manifest generator intact, which is a second, independent confirmation of the serialisation bug. To be clear about why I'm still chasing this: my own app stopped needing it a few posts ago, since it now demuxes the MKV and writes its own manifest. This is the diagnosis handed over, not a request I'm still waiting on — the two attributes are what would fix this for every client that doesn't carry its own demuxer, which is nearly all of them. One correction I owe you, on my own post. I reported there that with the space put back by hand the segment endpoint returned HTTP 400 with an unhandled System.ArgumentException. I can't reproduce that today — same machine, same 4.9.5.0, same patched URL, tried with the full audio list, with eac3 and with ac3, and init.mp4 returns 200 every time. I don't know what changed, and I'd rather flag it than leave a claim of mine standing that I can't reproduce on demand. Happy to run any of this again against a build, or to test a different profile combination if it would help narrow the mapping down.
Luke 43719 Posted August 27 Posted August 27 OK i'll add more audio values for the next server beta build.
vdatanet 1724 Posted August 27 Author Posted August 27 8 minutes ago, Luke said: OK i'll add more audio values for the next server beta build. A follow-up, and a retraction — mine, and it's good news for once. In my post from the 6th I wrote that putting the space back into the video range broke the other end of the round trip, and concluded from that: "no client can work around this on its own." In my last post I retracted half of it — the HTTP 400 on the segment endpoint doesn't reproduce any more. What I didn't do is re-test the conclusion that rested on it. Doing that now, it falls over completely. A client can work around this on its own, and what it gets is real HDR10. Same server, 4.9.5.0, an HDR10 MKV whose VideoRange is the "HDR 10" spelling. AudioCodec=aac, so the CODECS attribute is written (per my last post). The only variable is rewriting the parameter in the TranscodingUrl before following it: hevc-videorange=SDR,HDR10,... -> hevc-videorange=SDR,HDR%2010,... as returned with the space put back IsVideoDirect False True VIDEO-RANGE absent PQ CODECS hvc1.1.4.L126.B0,... hvc1.2.4.L150.B0,... ffprobe of init+seg0 Main / yuv420p / Main 10 / yuv420p10le / bt709 / bt709 smpte2084 / bt2020 first segment 7,690,748 bytes 12,662,628 bytes Three things I think are worth having in the thread: 1. It's genuine HDR10, not PQ tags left on an 8-bit encode — 10-bit and smpte2084 measured on the segment itself. And your own session report says IsVideoDirect=True: the video isn't being re-encoded at all, it's being copied. So the HDR path costs you a remux, not a transcode. 2. The manifest is honest in both cases. Without the rewrite it omits VIDEO-RANGE and delivers a real bt709 tone-map; with it, it declares PQ and delivers PQ. Nothing here is mislabelled. 3. So the whole HDR pipeline is already complete in 4.9.5.0, for HDR10 sources too and not only for Dolby Vision. The one thing standing between it and every client is that space being dropped when the TranscodingUrl is built. Fixing that single serialisation turns it on. One methodological note, since it cost me a wrong measurement before I caught it: this only shows up if each case gets its own PlaySessionId. If you patch the URL on a session that has already written segments, the server hands back the first transcode's files and it looks like the patch changed nothing — both segments come back byte-for-byte identical. With separate sessions the difference is immediate. To be clear, I'm not proposing that clients should do this rewrite. It's a hack against an internal parameter of yours and it only works because of the bug; if you fix the serialisation it stops being needed, and if you change the parameter's shape it would break. I'm posting it because it locates the defect precisely, and because the claim I need to withdraw was mine. The AAC-only CODECS mapping from my last post is unaffected by any of this — it's still missing with the rewrite in place. The two halves are independent.
vdatanet 1724 Posted August 28 Author Posted August 28 Confirmed on 4.10.0.29 — thank you, that was fast. To keep this independent of my library and my server, I measured the beta on a fresh install in a disposable container, against a synthetic HDR10 HEVC MKV (AC-3 source track) made for the purpose. Same device profile as my earlier posts, transcoding forced; the only thing changing between rows is the audio codec list in the transcoding profile. What the manifest advertises, and what the media segment actually contains according to ffprobe: requested CODECS attribute segment audio aac "avc1.640029,mp4a.40.2" aac mp3 "avc1.640029,mp4a.40.34" mp3 ac3 "avc1.640029,ac-3" ac3 eac3 "avc1.640029,ec-3" eac3 opus "avc1.640029,opus" opus dts "avc1.640029,ac-3" ac3 flac "avc1.640029,fLaC" (transcode fails to start; below) alac attribute absent alac truehd attribute absent (transcode fails to start) (The video half is avc1 in these runs because the probe deliberately forces a transcode, tonemap included — the half under test here is the audio one.) And the row that matters most to me: with my app's actual profile, aac,ac3,alac,eac3,flac, the server now keeps AC-3 and writes CODECS="…,ac-3". A described variant and passthrough at the same time — that was the practical cost of the old behaviour for nearly every file in my library, and it's gone. Thank you. A few observations from the table, in case they're useful: - The dts row is the mapping being honest, not a bug: the transcoder falls back to AC-3, the segment really is AC-3, and the attribute describes what actually comes out rather than what was asked for — which is exactly what a player needs. The only stale trace is that the TranscodingUrl still echoes AudioCodec=dts. - alac is now a clean measurement of the second point from my earlier post: the server produces a valid ALAC segment, and the whole CODECS attribute still disappears with it, including the video half it computed correctly. Emitting CODECS="avc1.640029" alone would be valid HLS and enough to rule the variant in or out. - flac advertises fLaC, but the transcode itself never starts: ffmpeg refuses FLAC in fMP4 without "-strict -2" ("experimental, add '-strict -2' if you want to use it" … "Could not write header"). truehd fails to start too. Both reproduce on the clean container, so it isn't my server's ffmpeg being odd. One more data point from this build: the "HDR 10" space round-trip from my last post is unchanged, so everything there still applies. What is new is what the patched URL yields now that AC-3 has a codec string: #EXT-X-STREAM-INF:BANDWIDTH=8871857,AVERAGE-BANDWIDTH=7393214,VIDEO-RANGE=PQ,CODECS="hvc1.2.4.L150.B0,ac-3",RESOLUTION=1920x1080,FRAME-RATE=23.976 — the untouched HDR10 copy and the passthrough audio in the same fully described variant. With that one serialisation fix, an AC-3 library gets everything I asked for at the top of this thread out of the box. Happy to run the same table against any future build. 1
vdatanet 1724 Posted September 11 Author Posted September 11 The audio mapping is in the stable build — thank you. Same table as before, now on 4.10.0.40 and against my real library instead of the synthetic file: requested CODECS attribute aac "hvc1.1.4.L126.B0,mp4a.40.2" mp3 "hvc1.1.4.L126.B0,mp4a.40.34" ac3 "hvc1.1.4.L126.B0,ac-3" eac3 "hvc1.1.4.L126.B0,ec-3" flac "hvc1.1.4.L126.B0,fLaC" opus "hvc1.1.4.L126.B0,opus" dts "hvc1.1.4.L126.B0,ac-3" alac attribute absent truehd attribute absent aac,ac3,alac,eac3,flac "hvc1.1.4.L126.B0,ac-3" <- my app's actual profile alac and truehd still drop the whole attribute, video half included, but the row that mattered to me is the last one and it now works for anyone who updates. The reason I'm posting, though, is two things I ran into while measuring that — and both are worth more to you than to me. 1) YOUR SERVER ALREADY SERVES DOLBY VISION TO AN APPLE TV WITHOUT TRANSCODING IT What stopped it here was what my client was asking for. My app declared only SDR ranges to Emby, on purpose, because the manifest carried no VIDEO-RANGE and a player that doesn't know the range won't switch the TV into HDR. The reason it carried none is the "HDR 10" space round-trip I reported earlier in this thread — but "DolbyVision" has no space, so it survives it. Declaring it changes the answer on the same file: hevc VideoRange=SDR|DOVIWithSDR CODECS="hvc1.1.4.L126.B0,ac-3" (Main, 8-bit, tone-mapped) hevc VideoRange=SDR|DOVIWithSDR|DolbyVision VIDEO-RANGE=PQ, CODECS="hvc1.2.4.L150.B0,ac-3" There is a second half, and it cost me longer than the first: with the range accepted but a TS/h264 transcoding profile listed first, the server still re-encoded. Your StreamBuilder ranks a profile that can copy above one that can't, so the fMP4/HEVC profile has to be allowed to win — on my side that meant no longer excluding HDR sources from the "prefer copy" decision I make before asking. With both halves in place, here is what the server does with a 3840x1606 DV Profile 8.1 file and an E-AC-3 5.1 track, straight from your own ffmpeg log: -c:v:0 copy -c:a:0 copy -hls_segment_type fmp4 -vtag hvc1 Stream #0:0 -> #0:0 (copy) hevc (Main 10) (hvc1), yuv420p10le, bt2020nc/bt2020/smpte2084, 3840x1606 Stream #0:1 -> #0:1 (copy) eac3 5.1, 640 kb/s DOVI configuration record: version: 1.0, profile: 8, level: 6, rpu flag: 1, el flag: 0, bl flag: 1, compatibility id: 1 No encoder, no tone-map, audio passed through, the DOVI RPU intact inside the fMP4 segments, and the TV lights up in HDR. Before the change, the same file on the same server went through tonemap_opencl=reinhard into h264_qsv at 1920x770. The only real work left is the subtitle tracks going to WebVTT. I'm spelling out both halves rather than just saying "it works now" because this is a client-side decision, not a server one, and I know other Apple TV client developers read this thread. On my server I still see the official tvOS app transcode this same file, and from the server's side the entire difference is those two things: a range name in the device profile, and letting the copy-capable transcoding profile win the tie. Whoever finds it useful, it's yours — it took me a day to find the second half and there's no reason for anyone else to spend it. 2) AND WHILE I'M AT IT: ON AN APPLE TV, MP4 IS BETTER SERVED AS HLS THAN AS DIRECT PLAY This one has nothing to do with HDR and I've never posted it here. Direct play works with MP4 — the native player will happily take an MP4 with HEVC Main 10 and AC-3 straight off the server. What it won't do is keep the buffer fed. Measured on an Apple TV 4K, same box, same LAN, same files, with an on-screen buffer readout: 67 Mbps remux, direct play starts ~10 s, drains to 1-2 s, never recovers: it stalls for good 15 Mbps file, direct play 5 s after a minute, 1 s after two, but it claws its way back either of them over HLS 50-60 s of buffer, steady for the whole film The interesting part is that the bleed is proportional, not a threshold: the progressive path delivers about 92% of what playback consumes, so you lose roughly 5 s of buffer for every minute played. The bitrate only decides how long you have before you hit zero — there is no safe "max direct play bitrate", just a slower death. It isn't decoding (an Apple TV 4K does HEVC Main 10 to L5.1 without breaking a sweat) and it isn't the network: a Mac direct-plays the same files over the same LAN with 32-52 s of buffer and no stalls. It's AVFoundation's progressive HTTP path on tvOS. Two things that look like fixes and aren't: preferredForwardBufferDuration (ignored on progressive assets unless you also set automaticallyWaitsToMinimizeStalling = false, and even then it only delays the drain) and seeking to force a re-fill (it drains again from scratch). What fixes it is serving the same file over HLS, and it costs the server nothing: -c:v copy, same bits, segmented with a manifest in front. That's the path the player is tuned for, and it's what Apple's authoring spec for long-form content is written around. It's also why players that bundle their own engine never hit any of this — they are not on that path to begin with. My own client does exactly that: it declines direct play for video entirely and asks for HLS, MP4 sources included. That is a device-profile decision, so it may be one worth revisiting in yours. Two things still on your side, and neither is urgent: - The "HDR 10" space round-trip is unchanged in 4.10.0.40, so HDR10 sources still tone-map. Dolby Vision only gets through because its name happens to have no space in it. - For the player to switch into Dolby Vision proper rather than HDR10, the variant would also need SUPPLEMENTAL-CODECS="dvh1.08.06/db1p" alongside VIDEO-RANGE=PQ, which is what Apple's HLS authoring spec asks for. With Profile 8.1 the base layer is HDR10-compatible and the picture is right either way, so this is the smaller of the two. Happy to keep running the table against future builds. 1
Luke 43719 Posted 1 hour ago Posted 1 hour ago With the next beta build. ExtendedVideoType and ExtendedVideoSubType will be usable as transcoding conditions, and the web app will be taking this into account now.
