Chiefmas 43 Posted July 31 Posted July 31 Is it more than just denying non-admin logins? If I am doing changes to the contents of the library paths, will Emby still automatically pick them up/perform library scans in maintenance mode and update them? I actually don't want to have it update the library, so I am trying to determine if I need to do a total shutdown or not. Thanks!
Luke 43549 Posted July 31 Posted July 31 Hi, yes you'll still be able to do admin functions. You just won't be able to browse the library.
Chiefmas 43 Posted July 31 Author Posted July 31 15 minutes ago, Luke said: Hi, yes you'll still be able to do admin functions. You just won't be able to browse the library. Ok, but will it continue to do automatic and scheduled operations, like if it's monitoring the folders for changes, will it pick those up, or does everything go manual? So as long as I don't tell it to start a scan, it shouldn't detect changes? Thanks!
