gluk147 9 Posted July 28 Posted July 28 Hi everyone. Any ideas what the problem might be? Emby Server version 4.10.20. For playback, I tried the Emby Android and Emby for Android TV apps—the latest versions from the Google Play Store. I tested about six different movies; all used the AV1 video codec and Dolby Atmos TrueHD audio. In all cases, the streaming boxes were connected directly to a Samsung HW-930F soundbar. The boxes I tested were the Xiaomi Mi Box 3, Ugoos SK-01, and Homatics Box 4R; the problem was the same on all of them. Between the 55- and 65-minute mark, a severe audio-video desync occurs (a lag of about 2 seconds). If I watch the same movies on the Google TV Streamer, there are no such issues—though that device doesn't output TrueHD audio. The problem only occurs in the Emby apps; everything works perfectly via Vimu and Kodi. I checked the server logs, but there are no errors.
Luke 43719 Posted July 28 Posted July 28 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
gluk147 9 Posted July 28 Author Posted July 28 (edited) To clear the logs, I restarted the server at 20:00 before the test. I started playing the movie at 20:01. The audio began to lag at approximately 21:00 (around the 58–59 minute mark). Device: Xiaomi Mi Box 3. I am attaching the server logs and information about the video file. 2026-07-28 21:00:29.440 Info SessionManager: Playback progress (Pause) I stopped playback myself at that point, after the lag had started. embyserver.txt hardware_detection-63920865587.txt Супермен 2025 (TrueHD Atmos).mkv.MediaInfo.txt Edited July 28 by gluk147
gluk147 9 Posted September 28 Author Posted September 28 Hi everyone, I’m facing a persistent audio-video synchronization issue with Dolby TrueHD Atmos tracks in the official Emby for Android / Android TV app, and I wanted to share logs and details to help track it down. The Problem: When playing media with a Dolby TrueHD Atmos audio track (bitstreamed/passthrough), the audio and video lose sync gradually. The desync starts to become noticeable right around 54–55 minutes into playback (drifting by about 2 seconds). If I jump backward by 10 seconds, the sync temporarily recovers, but the drift continues over time. Other players work fine: Playing the exact same files through Kodi or ViMu Player on the same hardware has zero sync issues. Scope & Environment: Issue reproduced on 4 different devices: Ugoos AM9 Pro, Xiaomi Mi Box 3, Homatics Box R 4K Plus, and Ugoos SK1. The behavior is identical across all of them. Emby for Android version: Latest version from the Google Play Store. Emby Server version: 4.10 Beta. Audio Setup: Bitstream (Passthrough) via HDMI to a Dolby Atmos-compatible soundbar (Samsung HW-Q930F). What the Logs Show: I captured a debug log during playback using ADB: adb logcat -v time | grep -i -E "emby|exoplayer|audio|codec|video" > emby_debug_logs.txt Looking into the logs around the desync point, the system audio HAL shows regular adjustments, and we can spot warnings from AudioTrack such as: W/AudioTrack: getTimestamp_l: retrograde timestamp position corrected It seems that during long playback sessions of heavy TrueHD Atmos streams, the ExoPlayer / Android MediaCodec passthrough pipeline slowly loses precise PTS alignment, whereas other media players handle this seamlessly. I have attached the debug log files to this post. Any insights, workarounds, or fixes from the dev team would be greatly appreciated! Thanks, emby_debug_logs.txt
visproduction 381 Posted September 28 Posted September 28 debug_logs.txt Position gap is ahead of system time gap" happens 323 times I have no idea what that means, but perhaps it is a clue. lines 297-299 Quote 09-28 14:54:40.091 I/audio_hw_hal_stream( 574): aml_stream_out_info_print: out:0xb40000750b0cdd00, stream_type:raw, sync_mode:non tunnel, input_size:0 bytes 09-28 14:54:40.091 I/audio_hw_hal_stream( 574): aml_stream_out_info_print: last_time:143017555 ms (sec:143017, nsec:555954694), last_position:18263 ms (876640), cur_time:143017571 ms (sec:143017, nsec:571940611), cur_position:18282 ms (877552) 09-28 14:54:40.091 I/audio_hw_hal_stream( 574): aml_stream_out_info_print: time_gap:16 ms (thr:100 ms), position_gap:19 ms, delay:0 ms, jitter: Position gap is ahead of system time gap by 3 ms (thr:100 ms)
gluk147 9 Posted October 11 Author Posted October 11 As a temporary workaround, I wrote a custom plugin for Emby Server. The plugin performs a micro-seek (rewind/forward jump) by a specified duration in milliseconds at regular time intervals, with an audio codec filter. How it works: For example, if you set the interval to 50 minutes, it performs a tiny seek every 50 minutes for a duration of 50 milliseconds. While watching, it causes a tiny micro-lag, but it completely eliminates any audio/video desync issues. Configurable Settings: Time Interval: How often to trigger the micro-seek. Seek Duration (ms): The length of the skip/jump. Codec Filter: Allows you to restrict this behavior to run exclusively on the TrueHD codec. If anyone is interested, I can share the plugin. 1
