voodoo5_6k 36 Posted July 27 Posted July 27 Hi, I've just installed the current version from github and it stopped auto-connecting to the known server (on the LAN). Every time when restarting the application, it will stop at the select server window. If I select the known server, and hit connect, it will connect. Forgetting the server and re-entering everything won't alter the application's behaviour. This behaviour is new. The previous version didn't do this. And nothing else changed.
voodoo5_6k 36 Posted July 27 Author Posted July 27 Thanks @ebr It was set to "remember last user" (the default, I guess). That didn't work anymore. Then I had set it to specifically sign in as "that user", but that also didn't have any effect. It is always showing that server selection screen. It worked before. This just changed with the last update.
ebr 17102 Posted July 27 Posted July 27 What version number of the app? Ensure your server is showing the proper address on its dashboard.
voodoo5_6k 36 Posted July 27 Author Posted July 27 3.5.40 on Shield TV Pro (2019). Yes, the server is showing the right address. This is 4.9.5.0 on TrueNAS. Like I said. Nothing else has changed, nothing else was even touched. We were watching a movie on Saturday with 3.5.38 (or so) and all worked fine, as always, for many years. On Sunday, I upgraded to 3.5.40, and it started.
Solution Luke 43720 Posted July 27 Solution Posted July 27 Hi, please try the 3.5.41 update. THanks. 1
CBers 7794 Posted July 28 Posted July 28 15 hours ago, Luke said: Hi, please try the 3.5.41 update. THanks. Can you update the Release Notes for v3.5.41 please.
