luowengang 0 Posted July 26 Posted July 26 index=2 codec_name=unknown codec_long_name=unknown TAG:language=chi TAG:title=中文(简体) index=3 codec_name=unknown codec_long_name=unknown TAG:language=chi TAG:title=中文(繁體) index=2 codec_name=unknown codec_tag_string=[0][0][0][0] codec_tag=0x0000 index=3 codec_name=unknown codec_tag_string=[0][0][0][0] codec_tag=0x0000 in this case,the sever cannot recognize and render the subtitle.
Luke 43390 Posted July 26 Posted July 26 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
luowengang 0 Posted July 26 Author Posted July 26 2 hours ago, Neminem said: 41 minutes ago, Luke said: Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! There is the attachement that I splited form the origin mkv useing mkvmerge tool. It has two subtitle channels. It can be recognized and rendered in IINA palyer, but emby sever。 AI said that It is the S_TEXT/WEBVTT format,I don't know if it is correct. test.mkv
Luke 43390 Posted July 27 Posted July 27 13 hours ago, luowengang said: There is the attachement that I splited form the origin mkv useing mkvmerge tool. It has two subtitle channels. It can be recognized and rendered in IINA palyer, but emby sever。 AI said that It is the S_TEXT/WEBVTT format,I don't know if it is correct. test.mkv 68.92 MB · 0 downloads So you made a small sample? Did you ensure the issue also occurs with the sample?
luowengang 0 Posted July 27 Author Posted July 27 11 hours ago, Luke said: So you made a small sample? Did you ensure the issue also occurs with the sample? yes,the issue occurs with the test sample. There are the IINA shotcut and the emby server shotcut.
visproduction 375 Posted July 27 Posted July 27 (edited) When I extract the subs, I get an undefined extension instead of .vtt. Why do the subs get the undefined extension? Are they not listed correctly in the media? This might cause Emby player to no recognize the subs correctly. I noticed that there is a uncommented Note at the beginning of the of one of the subtitles. Perhaps the undefined extension works in some situations on some countries. VLC seems to work OK. I can rename the extensions to .vtt as separate files and then the subs look normal. Edited July 27 by visproduction
luowengang 0 Posted July 28 Author Posted July 28 21 hours ago, visproduction said: I can rename the extensions to .vtt as separate files and then the subs look normal. I see. It seems that the problem is on the resourse. Is it possible to accommodate this kind of issue?
visproduction 375 Posted July 29 Posted July 29 (edited) That is a question for a developer, who knows the code. I remux every media to fix any video or audio issue. I pick video and audio codecs that play on anything. I also remove all subtitles and convert them to files. I don't run into any subtitle problems. For live TV that is not practical. Every commercial media website; Prime, Hulu, Netflix, Youtube... prepares their video media collection to be compatable with user's systems. The video websites can do this either automatically or manually, by checking and preparing each media file. Emby does an excellent job of handling this for all the possible situations. It's good to remember that you are skipping any preparation, remuxing, video or audio codec conversion, subtitle checking and hoping that every possible issue is fixed, without any extra effort. The question of Emby being able to know that the file is .vtt, even if the file name of the subtitles embedded in the media may end in undefined is a good question. I don't know the answer. Perhaps the problem is something else. Anyway, that is a start. Let's see who answers. Edited July 29 by visproduction 1
Luke 43390 Posted August 5 Posted August 5 OK I think the server ffmpeg build does not handle embedded webvtt. We'll be updating it on the beta channel very soon so this should be re-evaluated at that time.
