chuwz 27 Posted July 24 Posted July 24 Hello, here's how Emby is currently designed: When I click on Episode 4, the poster at the bottom switches to the poster for Episode 5 (as shown in the video). Screenbits 2026-07-25_065605.mp4 I hope the poster stays with Episode 4. In other words: When I click on an episode, it stays on the poster for that episode. Screenbits 2026-07-25_070031.mp4 I'm not used to the current design, when I click on Episode 4, I want to see everything about Episode 4, including its poster. But Emby shows the poster for Episode 5 instead, which really bothers me. Let's take a look at how Jellyfin does it: When you click on Episode 4, the poster for Episode 3 appears. Screenbits 2026-07-25_070621.mp4 Well, it's pretty hard to use, too... but at least it's better than Emby, because in Jellyfin, I can at least see the poster for Episode 4. Now let's take a look at how Plex handles this on TV: it uses a different design so that when we select Episode 4 to play, we see the poster for Episode 4—perfect! Screenbits 2026-07-25_070940.mp4 In short, Emby should take a cue from Jellyfin and Plex—their designs are the way to go. Of course, you don’t have to completely overhaul Emby’s current design; you could simply add an option that allows us to “When I click on an episode, Stay on the current episode's poster”
Luke 43667 Posted July 25 Posted July 25 Hi, the "more from" section is not intended to show information about the current episode. It's there to help you get to the next episode. why not just enable the poster on the detail screen? then you will see the poster for episode 4.
chuwz 27 Posted July 25 Author Posted July 25 (edited) 28 minutes ago, Luke said: enable the poster on the detail screen? then you will see the poster for episode 4. Hello, this solution works on the web, but it doesn't work on Android TV. Because when I open this option on Android TV, The whole layout looks unbalanced and a little odd. That’s why Plex and Jellyfin haven’t adopted this design. As shown in the image, you can see that Wholphin’s interface is much more attractive and harmonious. Sorry, maybe I should start a new topic—the discussion has shifted to optimizing the Android TV layout. Quote enable the poster on the detail screen? then you will see the poster for episode 4. In any case, if you don’t plan to optimize the current design, this option is indeed a useful alternative. Edited July 25 by chuwz
chuwz 27 Posted July 25 Author Posted July 25 Hello, based on this post, I enabled ”Show a poster on the detail screen“. Then I noticed a problem on my Android TV: 1. I go to the first episode. 2. Then I press the down arrow on the remote. At this point, it should select the second episode, but it selects the third episode instead. Screenbits 2026-07-25_130411.mp4 Before enabling ”Show a poster on the detail screen“, the cursor worked fine; Screenbits 2026-07-25_130535.mp4 but after enabling ”Show a poster on the detail screen“, the cursor jumps erratically—it often selects the episode after the next one, or the episode before the previous one. Screenbits 2026-07-25_130721.mp4 Please fix this. Thank you.
chuwz 27 Posted July 25 Author Posted July 25 (edited) @Luke Hi, I noticed that the design of Emby for Android TV is exactly what I expected! I was pleasantly surprised! (But I’d rather not use Emby for Android TV—it has fewer features and more issues.) As shown in the video, when I select Episode 3 and press the down arrow on the remote, the following happens: Episode 3 is selected in the “More from” section. Screenbits 2026-07-25_132556.mp4 You said, Quote the "more from" section is not intended to show information about the current episode. It's there to help you get to the next episode. but the fact is that Emby for Android TV is designed to display the current episode. Screenbits 2026-07-25_135157.mp4 So could you please bring this feature from ”Emby for Android TV“ to ”Emby Web“ and the ”Emby Universal App“? Thank you very much! Edited July 25 by chuwz
chuwz 27 Posted July 27 Author Posted July 27 Hello @Luke@ebr I'm using the Emby for Android TV 2.1.51g. I found that the design of Emby for Android TV was exactly what I was looking for. As shown in the video, when I select Episode 3 and press the down arrow on the remote, the following happens: Episode 3 is selected in the “More from” section. Screenbits 2026-07-25_132556.mp4 In other words, on Emby for Android TV, the poster displayed under “More from” is always the current episode. I know Quote the "more from" section is not intended to show information about the current episode. It's there to help you get to the next episode. But the fact is that Emby for Android TV is designed to display the current episode's poster. Because Emby for Android TV has a lot of issues, such as this bug, I gave up on Emby for Android TV and switched to the Emby Universal App. However, the design of the Emby Universal App is odd—it’s far inferior to the “always display the current episode’s poster” design of Emby for Android TV. Here's how Emby Universal App is currently designed: When I enter Episode 3 and press the “Down” button on the remote, the “More from” section moves the cursor to Episode 4 or Episode 2. (as shown in the video). Screenbits 2026-07-27_071108.mp4 This design prevented me from seeing the poster for the current episode, so I enabled "Show a poster on the detail screen". Then I noticed a BUG on my Android TV Quote 1. I go to the episode 1. 2. Then I press the down arrow on the remote. At this point, it should select the episode 2, but it selects the episode 3 instead. In other words, the cursor selection is messed up... I'm reporting this BUG here (I recorded a video; you can take a look.); please fix it as soon as possible. Therefore, the Emby Universal App currently does not support the feature where “the poster displayed under ‘More from’ is always the current episode,” unless you port this design from Emby for Android TV to the Emby Universal App. By the way, this design by Emby Universal App is quite illogical, because both Plex and third-party Emby clients use a design that “displays the poster for the current series.” Plex does Yamby does (this is a video) Screenbits 2026-07-27_114244.mp4 Hills does So could you please bring this Emby for Android TV's design to the Emby Universal App? Thank you very much!
ebr 17081 Posted July 27 Posted July 27 5 hours ago, chuwz said: such as this bug, Hi. A feature that you would like that doesn't exist is not a "bug" . Our apps are designed to use the internal player within them. We provide the ability to use external players for odd situations but do not intend to support every feature in every external app.
Luke 43667 Posted July 27 Posted July 27 OK it seems as though we're having the same conversation in multiple places. Let's merges some of these topics.
chuwz 27 Posted July 28 Author Posted July 28 (edited) Great, the two posts have now been merged. Hello, have you read through my post? Sorry for writing so much, but I want to make sure my thoughts come across clearly. @Luke@ebrAre you considering bring the design of “Emby for Android TV” (always display the current episode's poster) to the “Emby Universal App”? Thank you very much! Edited July 28 by chuwz
chuwz 27 Posted July 30 Author Posted July 30 Hello @Luke@ebr, is there any update on this topic? Will you considering bring the design of “Emby for Android TV” (always display the current episode's poster) to the “Emby Universal App”?
