pjreid 0 Posted December 4, 2014 Posted December 4, 2014 Hi there, I am using Media Browser with Parental Controls turned on. I have a folder that is rated "G" so that my kids can view all of the movies inside of it. However, some titles in this folder are only visible if the parental controls are unlocked, and disappear again when they are locked. The movie.xml file for these movies have "G" as the MPAARating, ContentRating, and Classification tags. What am I missing?
Luke 42184 Posted December 4, 2014 Posted December 4, 2014 is it possible you also have nfo metadata in the directory, and that your metadata settings are prioritized for that over xml?
ebr 16307 Posted December 4, 2014 Posted December 4, 2014 Yeah, forget about the actual files. What shows in the metadata editor in MB?
