nicko84 77 Posted July 23 Posted July 23 On Emby for Android 3.5.37 with Fire TV 4K (first gen) Fire OS 6.7.7.1 the horizontal scrolling doesn't work anymore : I mean, i can scroll to the right but display doesn't move to the left in the same time, so focus disapears to the rignt of the screen... Home screen of TV mode is set on horizontal. PS : If i set it on vertical than horizontal scrolling works well
nicko84 77 Posted September 12 Author Posted September 12 Hello Do you know when this issue on FireTV will be solved ? Thanks
Luke 43579 Posted September 21 Posted September 21 Hi, I think this is resolved for the next update to the app. Thanks.
nicko84 77 Posted 23 minutes ago Author Posted 23 minutes ago Hello, Do you know when the next update will be available ? Thanks
