JK1969 3 Posted July 22 Posted July 22 A library category just for multichannel music. And support for SACD and .iso.
Luke 43662 Posted July 22 Posted July 22 Hi, why does this need a separate category? Why can't you just use music? 1
JK1969 3 Posted July 22 Author Posted July 22 I am trying it right now and the DVD folders are not playing. Music Video category they work.
JK1969 3 Posted July 22 Author Posted July 22 The Dolby ATMOS single files work, but the Blu Ray Audio disc does not show the video stream for the music
JK1969 3 Posted July 22 Author Posted July 22 Going back to the Music Video for it. This is why I was asking for a separate category. When listening to Dark Side of the Moon you want to see the video streams for these discs. Same for Rush, Yes, etc. And be able to see the ATMOS albums with single files see the album covers.
JK1969 3 Posted July 23 Author Posted July 23 (edited) In the Music Video category, the DVD and Blu Ray folders play but the separate Dolby ATMOS files do not play Edited July 23 by JK1969
JK1969 3 Posted July 23 Author Posted July 23 Also the multichannel PCM files don't play in Music Video either
Solution JK1969 3 Posted July 23 Author Solution Posted July 23 OK mixed use they all work in mixed use. Also i can't believe the actual DVDA ISO discs work as well. 1
JK1969 3 Posted August 6 Author Posted August 6 (edited) The ones thing this needs is to be able to use discogs or music brainz for identifying the media. Instead of the movie database, tvdb, IMDb, or be able to switch between the metadata sites. Edited August 6 by JK1969
