Cooltwou76 0 Posted July 21 Posted July 21 My server was working just fine before the power went out yesterday Morning. Ever since the power came back on every time I go to watch something it keeps giving me a blue circle going around and around and keeps saying too many errors and a quit message and I don’t know what is going on. I am using Linux Mint and my media is on an external hard drive
visproduction 375 Posted July 21 Posted July 21 Suspect possible file access rights affected after power outage on Linux systems. see: https://unix.stackexchange.com/questions/191682/ubuntu-broken-after-power-failure-how-to-fix 1
Cooltwou76 0 Posted July 21 Author Posted July 21 I don’t understand what I am post to do with that link you gave me
Cooltwou76 0 Posted July 21 Author Posted July 21 Well I am leaving for work so I have to get them when I get back home
Cooltwou76 0 Posted July 22 Author Posted July 22 I posted the logs does anybody know why I can't play anything Spoiler t
Neminem 1957 Posted July 22 Posted July 22 (edited) There is nothing of value in those logs. Did you try to login in, in these logs. Your logs cover under a minut and are of no use. Edited July 22 by Neminem
Cooltwou76 0 Posted July 22 Author Posted July 22 I was singed into my account when I clicked on Logs
Neminem 1957 Posted July 22 Posted July 22 Did you look at the log? Before posting them? Did you try to play something in the time span of log? Its still the same standpoint you logs only show less that 1 minut of logs. With no playback attempts that reaches your server.
Cooltwou76 0 Posted July 22 Author Posted July 22 I attached another log where I played something & got the same blue circle & the error message too many tries giving up embyserver(1).txt
Lessaj 595 Posted July 22 Posted July 22 Ensure your mount point is properly accessible, there are several errors like this: System.IO.IOException: System.IO.IOException: Input/output error : '/mnt/wwn-0x5000c500e90d708c-part2/Wrestling/Wrestling/Kenny Omega' System.IO.IOException: System.IO.IOException: Input/output error : '/mnt/wwn-0x5000c500e90d708c-part2/Marvel/Movies' System.IO.IOException: System.IO.IOException: Input/output error : '/mnt/wwn-0x5000c500e90d708c-part2/Movies' 1
Neminem 1957 Posted July 22 Posted July 22 It look like you have mount issues System.IO.IOException: System.IO.IOException: Input/output error : '/mnt/wwn-0x5000c500e90d708c-part2/Wrestling/Wrestling/Kenny Omega' System.IO.IOException: System.IO.IOException: Input/output error : '/mnt/wwn-0x5000c500e90d708c-part2/Marvel/Movies' Is the mount working out side Emby? Also CoverArt plugin is not working without Emby Premiere, and those errors are making logs hard to read. 1
Cooltwou76 0 Posted July 22 Author Posted July 22 I am able to open the external hard drive in the file browser & everything I clicked opened & how do I fix mount issues
Neminem 1957 Posted July 22 Posted July 22 Not really the right person to help here. But there might be something in here. Quick Start | Emby Documentation Linux/Unix Permissions | Emby Documentation
Lessaj 595 Posted July 22 Posted July 22 45 minutes ago, Cooltwou76 said: I am able to open the external hard drive in the file browser & everything I clicked opened & how do I fix mount issues You're looking at the exact same paths that are defined in emby server? Can you show a screenshot?
Lessaj 595 Posted July 22 Posted July 22 (edited) That is not the same location you have told Emby server where your files are. How did you configure your libraries? EDIT: Depending on how you configured the libraries, the error may be indicating an error with that particular partition, but need to see the configuration. EDIT2: Right it's in your log file. Yea you need to be looking at /mnt/wwn-0x5000c500e90d708c-part2 because that's what you set up. I don't know why you would have done it this way, using a wwn in the wrong place... Edited July 22 by Lessaj
Cooltwou76 0 Posted July 22 Author Posted July 22 it is looking at that hard drive because I named the hard drive media and I looked though the path for libraries and every one is still pointing to this hard drive: /mnt/wwn-0x5000c500e90d708c-part2
Lessaj 595 Posted July 22 Posted July 22 And that is not what you showed, you showed the partition being mounted to a path like /media/cooltwou/Media, so that doesn't align with your library folders. Please provide your /etc/fstab, and ls -la /mnt/wwn-0x5000c500e90d708c-part2
Cooltwou76 0 Posted July 22 Author Posted July 22 /etc/fstab: Permission denied ls -la /mnt/wwn-0x5000c500e90d708c-part2 ls: /mnt/wwn-0x5000c500e90d708c-part2: Input/output error ls: reading directory '/mnt/wwn-0x5000c500e90d708c-part2': Input/output error total 0
Lessaj 595 Posted July 22 Posted July 22 You need to cat /etc/fstab. But so far, your mount situation seems completely messed up, and doesn't align with what you configured for your libraries.
Cooltwou76 0 Posted July 22 Author Posted July 22 cat /etc/fstab # /etc/fstab: static file system information. # # Use 'blkid' to print the universally unique identifier for a # device; this may be used with UUID= as a more robust way to name devices # that works even if disks are added and removed. See fstab(5). # # <file system> <mount point> <type> <options> <dump> <pass> # / was on /dev/nvme0n1p2 during installation UUID=09092419-a44d-4619-9b44-dda30b0b24e1 / ext4 errors=remount-ro 0 1 # /boot/efi was on /dev/nvme0n1p1 during installation UUID=7E7A-D8E2 /boot/efi vfat umask=0077 0 1 /swapfile none swap sw 0 0 /dev/disk/by-id/wwn-0x5000c500e90d708c-part2 /mnt/wwn-0x5000c500e90d708c-part2 auto nosuid,nodev,nofail,x-gvfs-show,x-gvfs-name=Media 0 0 how can the mount be messed up when nothing has changed
