NotYourErnst 1 Posted July 21 Posted July 21 Hi I'm working on a mobile Emby Server which I can take with me in the car, plane and vacation for the kids. As a server I'm using a Dell Wyse 3040 with integrated wifi card and attached a USB stick for the content to it. As OS i'm using Dietpi. Power comes from a powerbank. Everything works like a charm, with the Emby app, BUT when I try to use a browser from a notebook I don't get audio to work. I tested several notebooks and browser already. As the unit has not enough performance I configred it for direct play. Any idea? For example: Stream MKV (5 mbps) Direktwiedergabe Video 1080p HEVC Main 120 5 mbps 24 fps Direktwiedergabe Dropped Frames 1 Audio German AC3 stereo (Standard) 384 kbps 48000 Hz Direktwiedergabe embyserver.txt
NotYourErnst 1 Posted July 21 Author Posted July 21 After activation of audio transcoding it works fine. Any other possibility without transcoding? The 3040 doesn't has so much performance if multiple streams are in use.
Neminem 1957 Posted July 21 Posted July 21 I think the best codex for browsers are still. video : H264 Audio : AAC 2.0 Subs : text based like srt. So It might be the AC3 is not supported by your browser. What browser are you using and have you tried with another browser?
NotYourErnst 1 Posted July 21 Author Posted July 21 1 hour ago, Neminem said: What browser are you using and have you tried with another browser? I tried Firefox and Chorme.
Neminem 1957 Posted July 21 Posted July 21 12 minutes ago, NotYourErnst said: I tried Firefox and Chorme. Ok then I guess, that's it or transcode the audio to AAC Stereo. 2 hours ago, NotYourErnst said: The 3040 doesn't has so much performance if multiple streams are in use. But Transcoding audio should be a task it can handle, most potatoes can do this, without breaking a sweat. Did you see what cpu usage it was using when transcoding audio?
NotYourErnst 1 Posted July 22 Author Posted July 22 On 7/21/2026 at 2:24 PM, Neminem said: Did you see what cpu usage it was using when transcoding audio? Two streams 50% CPU usage. Still looking for a Powerbank, which could deliver constant power for it, everything else works fine now. 1
Neminem 1957 Posted July 22 Posted July 22 This might be overkill for a simple road trip. Ecoflow but nice to have if you get strandet. Amazon.com: EF ECOFLOW: 𝐎𝐮𝐭𝐝𝐨𝐨𝐫 𝐒𝐞𝐚𝐬𝐨𝐧
NotYourErnst 1 Posted July 23 Author Posted July 23 Absolut overkill Currently running a test with an old Anker powercore 13000. Lets see how long it will last with two streams running.
