achalmers 4 Posted July 20 Posted July 20 (edited) I'm sure I'm being dumb - but why is my 1883 library not showing in the Emby GUI properly? each file has an .nfo and image etc. Attaching pictures for reference (only 1 episode appears able to play in Emby GUI and its not matched correctly). Also....there is no Season 18 lol. What can I do to fix? Thanks, Edited July 20 by achalmers Additional details / screen snip
Solution Luke 43402 Posted July 20 Solution Posted July 20 Hi there, have you taken a look at our TV naming guide? TV Naming
achalmers 4 Posted July 20 Author Posted July 20 10 minutes ago, Luke said: Hi there, have you taken a look at our TV naming guide? TV Naming My bad. Its fixed. Thank you. To be honest I didnt do the "season" because its just a 10 part series and I didn't realize that was causing the issue since the files seemed to be scraping art etc. As always thank you for your help and crazy fast response. 1
