Breezey 0 Posted July 17 Posted July 17 Hi, I'm hoping someone can help because I've narrowed this down as much as I can. Environment Emby Server 4.9.5.0 QNAP TS-464 and TS-453D Native QPKG installation (not Docker) Nginx Proxy Manager (latest jc21/nginx-proxy-manager) HTTPS using Let's Encrypt Reverse proxy to Emby on HTTP port 8096 Reverse proxy NPM configuration is very standard: Forward Scheme: HTTP Forward Host: 192.168.x.x Forward Port: 8096 Force SSL: Enabled HTTP/2: Enabled WebSockets: Enabled Cache Assets: Disabled Block Common Exploits: Disabled No custom locations No custom nginx directives Emby Network settings Secure connection mode: Handled by reverse proxy External domain configured Public HTTPS port: 443 Local HTTP port: 8096 Local HTTPS port: 8920 Remote connections enabled UPnP disabled The strange part I have two completely separate Emby servers. Different NAS hardware Different databases Same Emby version Same reverse proxy Both behave identically. Testing results Works Windows browser via reverse proxy Android phone browser via reverse proxy Android phone Emby app via reverse proxy Android TV browser (Edge) via reverse proxy Android TV app via local IP OttoAibox Emby app via local IP Fails Sony Android TV Emby app via reverse proxy OttoAibox Emby app via reverse proxy Both Android TV devices authenticate correctly if I connect directly to: http://192.168.x.x:8096 They fail only when using: https://emby.backup.monitoringcomputers.com.au Emby Connect Emby Connect also fails. The PIN page says: Pin Confirmed. Thank you. but the TV never completes the login. Logs The server receives the authentication request. Immediately afterwards the log shows: GET /emby/Users/authenticatebyname followed by: Access token is invalid or expired. 401 Unauthorized Browser authentication succeeds through the same reverse proxy. Why I think this may be a client issue Everything else works: Browser Android phone app Direct LAN Same reverse proxy Same certificate Only Android TV-style clients fail when connecting through the reverse proxy. Has anyone seen this before? Is there something different about Android TV authentication compared with the Android phone app? Any suggestions would be appreciated.
Breezey 0 Posted July 18 Author Posted July 18 This has never worked through the reverse proxy on Android TV devices. It is not a regression after an update."
ebr 17102 Posted July 18 Posted July 18 My 80% confidence guess is that your proxy is converting POST calls to GET OR not properly forwarding the POST data on POST calls.
Luke 43719 Posted July 18 Posted July 18 Quote GET /emby/Users/authenticatebyname Ding ding ding. Yes this should be a post. They Emby app sends a post, so something in your stack is modifying the request. I would start by resolving that.
Breezey 0 Posted July 18 Author Posted July 18 Thanks for the clue. I'm not using Cloudflare or any CDN. The path is: Internet → Grandstream GWN7003 port forwarding → Nginx Proxy Manager → Emby. NPM is using a standard proxy host with: Forward scheme: HTTP Forward host: 192.168.20.10 Forward port: 8096 WebSockets: Enabled Force SSL: Enabled HTTP/2: Enabled No custom locations No advanced configuration Is there a particular request or Nginx directive you'd like me to inspect to determine where the POST is being converted to a GET?
Luke 43719 Posted July 19 Posted July 19 1 hour ago, Breezey said: Thanks for the clue. I'm not using Cloudflare or any CDN. The path is: Internet → Grandstream GWN7003 port forwarding → Nginx Proxy Manager → Emby. NPM is using a standard proxy host with: Forward scheme: HTTP Forward host: 192.168.20.10 Forward port: 8096 WebSockets: Enabled Force SSL: Enabled HTTP/2: Enabled No custom locations No advanced configuration Is there a particular request or Nginx directive you'd like me to inspect to determine where the POST is being converted to a GET? Have you compared your nginx setup to this:
Breezey 0 Posted July 19 Author Posted July 19 Posted just now I captured the Nginx Proxy Manager access log during a failed login. The Android TV app initially sends: POST http://xxx.xxx.xxx.com.au/emby/Users/AuthenticateByName?format=json NPM returns 301 Moved Permanetly The client then immediately retries as: GET https://xxx.xxx.xxx.com.au/emby/Users/AuthenticateByName?format=json which returns 401. So the POST is being converted to a GET after the HTTP→HTTPS redirect. I captured the Nginx Proxy Manager access log during the failed Android TV login. The Android TV client appears to POST over HTTP, receives the Force SSL redirect, then retries as a GET over HTTPS, which Emby rejects. My Nginx Proxy Manager configuration is otherwise standard with Force SSL enabled and no custom rewrite rules. Is the Android TV client expected to start with HTTP even when the server is configured as HTTPS, or should it be connecting via HTTPS directly?
Luke 43719 Posted July 19 Posted July 19 Quote NPM returns 301 Moved Permanetly This is not going to work. I mean you can leave it that way but it will not work like you're expecting. It will work when you put the server address in the browser address bar. That is what that kind of redirect is made for. It's not going to work for request that aren't GET because the request method and body do not get preserved on the redirect. This is correct behavior and it's not even in our control anyway. It's happening internally in the browser or client device networking stack. For more info, read this AI-generated blurb: Quote When using the fetch() API, an HTTP 301 Moved Permanently status code automatically forces a non-GET request (like POST, PUT, or DELETE) to change into a GET request during the subsequent redirection follow-up. This behavior complies with the Fetch Standard specification, which converts the HTTP method to GET and strips the original request body to prevent data corruption at the new destination. [1, 2] Why This Happens Historically, web browsers automatically changed POST requests to GET requests upon receiving a 301 or 302 redirect status. Because this became standard practice for client applications, modern APIs and the official Fetch specification codified this exact sequence. [1, 2, 3, 4] How to Fix or Prevent It If you want the redirected request to keep its original HTTP method (such as POST) and preserve its payload, you can use any of the solutions below: Use HTTP 308 instead: Change your server-side configuration to respond with a 308 Permanent Redirect instead of a 301. The 308 status code explicitly prohibits user agents from changing the request method. [1, 2] Use HTTP 307 for temporary changes: If the redirection is not permanent, use a 307 Temporary Redirect status code. This preserves the original HTTP method and body just like a 308. [1, 2, 3] Update your client-side target URL: Change the initial URL string inside your fetch() code to point directly to the new, final endpoint so that zero redirects occur. [1, 2]
Luke 43719 Posted July 19 Posted July 19 It mentions 307 and 308, but I don't recall users mentioning that before and it's not something we've tested. Hopefully it will work. The third option about updating your client-side url is what you want to do, and that's what I'm about to explain: Quote Is the Android TV client expected to start with HTTP even when the server is configured as HTTPS, or should it be connecting via HTTPS directly? No, it will connect however you want, but you need to actually connect that way by setting up a server connection. I would guess that you initially connected over http, then setup the redirect in NPM and expected it to just work in Emby apps. You need to go back to the Emby app and do a new server connection and specify the https address if that's what you want to do. And of course, make sure the server dashboard is displaying the https address as your remote address.
ebr 17102 Posted July 19 Posted July 19 9 hours ago, Luke said: It mentions 307 and 308, but I don't recall users mentioning that before and it's not something we've tested. Hopefully it will work. It won't - at least not in the TV app because the Volley system doesn't follow the 308. We recently had someone run into that. 11 hours ago, Breezey said: Is the Android TV client expected to start with HTTP even when the server is configured as HTTPS, Make sure you've set the server to require it and, if entering the address manually in the app there is now a simple check box to click to use SSL.
Luke 43719 Posted July 19 Posted July 19 Since he's using a reverse proxy that is taking care of the https, he'll want to use the option called handled by reverse proxy, rather than requiring ssl. The result for Emby apps is the same. It just tells the server not to do any redirect because the proxy will handle it. 1
