Hu7cH 1 Posted July 12 Posted July 12 In a newly introduced emby client update (version 2.1.48g) on my Nvidia shield (version 9.2.4 (33.2.0.400)) has been broken overnight so now there is no audio for 70%+ of my media unless I turn on the following options: Use the option to invoke a separate video player (it uses VLC and you are then opting out of all the emby playback magic) Use the option to force non-supported dolby codecs (and the playback performance is then abysmal when scrubbing or play/pausing) Additional information: Emby Server Version is 4.9.5.0 NOTE: This is not an issue with the normal Android app. 1
kicsrules 4 Posted July 12 Posted July 12 i'm on the same boat, AC3 doesn't work in the TV version.... it worked before
ebr 17088 Posted July 12 Posted July 12 11 hours ago, Hu7cH said: so now there is no audio Hi. Please play a problematic item for several seconds and then follow the instructions to send a log from the app?
Hu7cH 1 Posted July 12 Author Posted July 12 Sorry, but I've uninstalled the android TV client and moved onto the android one as this was a significant regression I couldn't live with. Also, I'm blown away that this was able to get through your build process and the sort of reasons I left Plex.
Luke 43680 Posted July 13 Posted July 13 20 hours ago, kicsrules said: i'm on the same boat, AC3 doesn't work in the TV version.... it worked before @kicsrules Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
ebr 17088 Posted July 13 Posted July 13 17 hours ago, Hu7cH said: Also, I'm blown away that this was able to get through your build process and the sort of reasons I left Plex. The issue is apparently isolated to very specific configurations that none of our beta testers (which is a whole lot) appear to have. We are looking into it. Thanks.
ebr 17088 Posted July 13 Posted July 13 Before we can attempt to address it, I will need someone with the issue to do this, however. I cannot reproduce on any of my test systems either. Thanks. On 7/12/2026 at 12:07 PM, ebr said: Hi. Please play a problematic item for several seconds and then follow the instructions to send a log from the app?
atwigger 0 Posted July 17 Posted July 17 +1 on this issue. Infuriating that this software would be released without thorough testing. Nvidia Shield Emby app Emby server running in Docker
ebr 17088 Posted July 17 Posted July 17 4 hours ago, atwigger said: +1 on this issue. Infuriating that this software would be released without thorough testing. Please try the beta or the standard app. This issue only affects a very small percentage of people and was not picked up by any beta testers.
Jubaz 0 Posted July 23 Posted July 23 Any news on this, I am having the same issue, I have 3 nvidia shield and it is only the 2017 nvidia shield That is affected. Emby runs in docker (Synology) and the Emby client has updated only on the 2017 model. Why would it be pushed only to this model ?? Eac3 does not work and must be converted to DD to get audio. Subtitles imbedded in mkv does not show either And some settings changed on it's own in the client too. Quick question, I am running the "Emby for android" client, should I be running the "Emby" client instead?? I just wonder because "Emby for android" is older but better/easier to use, vs the newer Emby client.
FrostByte 5685 Posted July 23 Posted July 23 35 minutes ago, Jubaz said: Any news on this, I am having the same issue, I have 3 nvidia shield and it is only the 2017 nvidia shield That is affected. Emby runs in docker (Synology) and the Emby client has updated only on the 2017 model. Why would it be pushed only to this model ?? Eac3 does not work and must be converted to DD to get audio. Subtitles imbedded in mkv does not show either And some settings changed on it's own in the client too. Quick question, I am running the "Emby for android" client, should I be running the "Emby" client instead?? I just wonder because "Emby for android" is older but better/easier to use, vs the newer Emby client. Have you tried the latest beta of the AndroidTV app version 2.1.51 like ebr suggested? If the problem persists then provide logs as requested Also, try the standard Android app and compare to see if that works.
