Hu7cH 0 Posted 2 hours ago Posted 2 hours ago In a newly introduced emby client update (version 2.1.48g) on my Nvidia shield (version 9.2.4 (33.2.0.400)) has been broken overnight so now there is no audio for 70%+ of my media unless I turn on the following options: Use the option to invoke a separate video player (it uses VLC and you are then opting out of all the emby playback magic) Use the option to force non-supported dolby codecs (and the playback performance is then abysmal when scrubbing or play/pausing) Additional information: Emby Server Version is 4.9.5.0
Kramerika 18 Posted 57 minutes ago Posted 57 minutes ago Is this the Android version or Android TV version? I am having the same issue with the Android TV version, but the Android version seems to work fine although I need to do more testing on both of my Shield TV boxes to confirm.
Solution Hu7cH 0 Posted 37 minutes ago Author Solution Posted 37 minutes ago Haha, yes you are correct this is a complaint on the Android TV version. I'm working on recreating this over in that category and deleting this.
