gcw07 347 Posted November 4, 2013 Posted November 4, 2013 Metabrowser, but you can use the built in tools in the MB3 server. If they added drag and drop support for add images, I might stop using metabrowser It does have that already. You click on the upload button and just drag an image to the upload popup.
LASooner 24 Posted November 4, 2013 Posted November 4, 2013 (edited) The button press is what I don't want to add to the mix. When you're doing a lot of manual metadata, it's nice to be able to just drag images onto a field and have it save it. Also you can select multiple videos and apply common data, such as studio, aspect ratio, etc. Edited November 4, 2013 by LASooner
gcw07 347 Posted November 4, 2013 Posted November 4, 2013 The button press is what I don't want to add to the mix. When you're doing a lot of manual metadata, it's nice to be able to just drag images onto a field and have it save it. Also you can select multiple videos and apply common data, such as studio, aspect ratio, etc. Ah no idea how metabrowser works as I've never used it. Don't you have to click on a button to bring up all the images or something?
LASooner 24 Posted November 4, 2013 Posted November 4, 2013 You can, but if you have an image stored locally, say a folder full of helmet images, you can just drag and drop the image on the folder field and it saves it in the folder as folder.jpg it works with banners, backdrops and actors images as well.
