sdragon001 31 Posted July 11 Posted July 11 (edited) Emby Sever beta: 4.10.0.18 Trakt Plugin: 3.8.3 Issue: After import or file scan Trakt plugin does not import watched status and update Emby. Example: Movie/TV Episode marked watched on Trakt and after import schedule task, this will not update on Emby to mark movie/episode as watched. This started between June 25, 2026 and Present. Steps taken to try to resolve: rolled Emby Server back to 4.10.0.12/.13/.14/.15/.16/.17 problem persists. Removed and re added Trakt pin for user, this did not solve problem either. Edited July 11 by sdragon001 Added info
Luke 43675 Posted July 12 Posted July 12 HI there, can you please provide a specific example? How to Report a Problem Thanks !
sdragon001 31 Posted July 12 Author Posted July 12 The best example is pretty generic as the above problem happens on all files. A watched status on Trakt is not being synced to Emby and being marked as watched. scrobbling works fine from Emby to Trakt. I’ve reconnected Emby and Trakt multiple times to see if it was a connection error. But that’s not the case. I’ve added about 6 movies that have a watched status on Trakt but after running an import Trakt scan, status does not get marked watched on Emby.
Luke 43675 Posted July 12 Posted July 12 2 hours ago, sdragon001 said: The best example is pretty generic as the above problem happens on all files. A watched status on Trakt is not being synced to Emby and being marked as watched. scrobbling works fine from Emby to Trakt. I’ve reconnected Emby and Trakt multiple times to see if it was a connection error. But that’s not the case. I’ve added about 6 movies that have a watched status on Trakt but after running an import Trakt scan, status does not get marked watched on Emby. Hi, please select an exact example and provide a description of it here including file naming, organization, and a log file from when the problem occurred: How to Report a Problem Thanks.
sdragon001 31 Posted July 12 Author Posted July 12 Once I’m back at my server I’ll update and add. but looking into issues and found out a few days ago Trakt updated their api and having issues with other services (kodi, Jellyfin, infuse, sen, and so on that pull Trakt data) pulling watched data. issues maybe because of: Requests without pagination now return page 1 with up to 100 items. 1
Mahtan 4 Posted July 12 Posted July 12 Yes same problem for me. He existe alternative for emby of trakt ?
Luke 43675 Posted July 12 Posted July 12 10 hours ago, sdragon001 said: Once I’m back at my server I’ll update and add. That would be helpful. Thanks.
sdragon001 31 Posted July 12 Author Posted July 12 @Luke Attached is a fresh server log right after the Trakt import. missing data i can see is these movies I’ve recently added: piranah 3d, piranah 3dd, stop! Or my mom will shoot, Don’t look up. This is just a few of them that will not update its watch status. embyserver.txt
Luke 43675 Posted July 12 Posted July 12 3 minutes ago, sdragon001 said: @Luke Attached is a fresh server log right after the Trakt import. missing data i can see is these movies I’ve recently added: piranah 3d, piranah 3dd, stop! Or my mom will shoot, Don’t look up. This is just a few of them that will not update its watch status. embyserver.txt 341.41 kB · 0 downloads And which specific example do you want to focus on here? And for that specific example, what exactly happened? How are the files named and organized?
sdragon001 31 Posted July 12 Author Posted July 12 3 minutes ago, Luke said: 6 minutes ago, sdragon001 said: Expand And which specific example do you want to focus on here? And for that specific example, what exactly happened? How are the files named and organized? This is only a recent problem so I don’t think it has anything to do with structure and organization but see below. After creating the movie rip I add the movie to my Emby path for library. So let’s use Piranah 3D as our example file. files are names and organized like: Movie folder which Emby sees as the movie library and inside that looks like this. Folder: Piranah 3D (2010) [imdb-tt0464154] File inside folder: Piranha 3D (2010) [imdb-tt0464154].mkv metadata all present from Emby scan to identify and is correct.
sdragon001 31 Posted July 12 Author Posted July 12 @LukeHere is some more info for changes in api posted on GitHub. I hope this helps narrow down what’s going on. “Likely related to the recent Trakt API change that returns paginated results. The data is there, the app just needs to grab each page of data to obtain your full watched history.” https://github.com/trakt/trakt-api/discussions/775
Buhric 0 Posted July 13 Posted July 13 On Emby 4.9.5.0 (Synology) and Trakt plugin v3.8.3.0 I confirm the same error, also for the 100 "shows' that are returned I get the following error "Debug Trakt: No Season match in Watched shows list Episode: 1x5 'Remember It' Series: 'X-Men '97'" Sound like the format that the info is returned for TV shows is no longer recognized by Emby. IT works fine for Movies (the 100 returned) - i get "Debug Trakt: Movie is in Watched list Cube" I also see this in the logs 2026-07-12 21:49:34.151 Info Trakt: Trakt.tv watched Movies count = 100 2026-07-12 21:49:34.151 Info Trakt: Trakt.tv watched Shows count = 100 2026-07-12 21:49:34.151 Info Trakt: Trakt.tv playback Movies count = 0 2026-07-12 21:49:34.151 Info Trakt: Trakt.tv playback Episodes count = 1
Solution Luke 43675 Posted July 13 Solution Posted July 13 OK the 3.8.4 plugin update has added support for their new paging requirements. Thanks. 1 1
sdragon001 31 Posted July 13 Author Posted July 13 6 hours ago, Luke said: OK the 3.8.4 plugin update has added support for their new paging requirements. Thanks. @LukeThank you, appreciate the quick fix and update on this. 1
