bobaldis 29 Posted July 10 Posted July 10 Hi, I just bought a HDhomerun to record the World Cup and although some initial Audio issues on my LG TV, Gemini gave me some suggestions and forcing a Transcode appears to have resolved this, the problem I have at the moment if I start watching a match that is still being recorded I can't Fast Forward to the start of the match. but I can Fast Forward on completed recordings withour issue. Gemini suggested using the skip 30 Secs and/or pressing a number 1-9 which should move to a fixed point 1=10% etc., neither of these work either, the remaining suggestions from Gemini is to plav using VLC or Plex, neither of which appeals to me. Has anyone else encountered this issue and found a way to do this, any assiatnce welcome. Thanks, Bob
MBSki 1134 Posted July 10 Posted July 10 Yes, this has always been an issue. Slightly resolved by forcing transcoding, but it's not great and there is no fix at the moment. Plenty of users have asked for this to be fixed. 1
js28194 79 Posted July 11 Posted July 11 Have you looked at these settings by any chance? I personally don't use 'em as I have a NextPVR backend for recording that handles this (Pre-Emby LIve TV setup and not willing to change) Of course the below will require to point your "temp drives" to places that have some decent space. 1
bobaldis 29 Posted July 11 Author Posted July 11 2 hours ago, js28194 said: Have you looked at these settings by any chance? I personally don't use 'em as I have a NextPVR backend for recording that handles this (Pre-Emby LIve TV setup and not willing to change) Of course the below will require to point your "temp drives" to places that have some decent space. Not yet, I think this is one Gemini mentioned amongst other things I've tried, I was hoping someone would have an example of a real life fix, but thanks
bobaldis 29 Posted July 12 Author Posted July 12 10 hours ago, bobaldis said: Not yet, I think this is one Gemini mentioned amongst other things I've tried, I was hoping someone would have an example of a real life fix, but thanks I checked I had this set already, shame this feature is not available in Emby, I wonder if there's a technical limitation or just not something they're interested in providing
Luke 43719 Posted July 28 Posted July 28 @bobaldis Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
bobaldis 29 Posted July 28 Author Posted July 28 1 hour ago, Luke said: @bobaldis Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! @LukeHi, yes I'll try and get the logs and attach them but the description is: When watching a recording that is part way through I can't Fast Forward, but once the recording is finished I can. Thanks for looking into this. Bob 1
bobaldis 29 Posted July 28 Author Posted July 28 (edited) @LukeI have the log, it says not to upload here, please confirm how to get it to you? I recorded Live at the Apollo and attempted to fast forward both by using the 30 sec buttons and dragging the play bar the playback just kept going back to the begining, once I stopped the recording I could do either without issue, Bob Edited July 28 by bobaldis
bobaldis 29 Posted August 1 Author Posted August 1 On 28/07/2026 at 22:49, bobaldis said: @LukeI have the log, it says not to upload here, please confirm how to get it to you? I recorded Live at the Apollo and attempted to fast forward both by using the 30 sec buttons and dragging the play bar the playback just kept going back to the begining, once I stopped the recording I could do either without issue, Bob Hi @Luke, What would you like me to do with the log file? Bob
Luke 43719 Posted August 5 Posted August 5 On 8/1/2026 at 5:18 PM, bobaldis said: Hi @Luke, What would you like me to do with the log file? Bob Hi, you can attach here or PM it to me. Thanks.
bobaldis 29 Posted August 20 Author Posted August 20 @LukeHi, no rush as my Server's offline ATM, but curious if you found anything from the logs and have a way forward? Cheers, Bob
Luke 43719 Posted August 25 Posted August 25 On 8/20/2026 at 8:18 AM, bobaldis said: @LukeHi, no rush as my Server's offline ATM, but curious if you found anything from the logs and have a way forward? Cheers, Bob Hi, we are still looking at it. Thanks. 1
bobaldis 29 Posted October 5 Author Posted October 5 On 25/08/2026 at 20:26, Luke said: Hi, we are still looking at it. Thanks. Hi @Luke, Just wondered if any updates? Bob
Luke 43719 Posted October 5 Posted October 5 6 hours ago, bobaldis said: Hi @Luke, Just wondered if any updates? Bob Hi, we are still looking at it. Thanks. 1
