Goober77 2 Posted July 9 Posted July 9 Hello Emby Support, First time using Emby and bought the lifetime to use with my Alexa and music collection. Any help would be appreciated. Alexa stop playing after the first song ends on multi echo devices (3rd generation). Plays fine on a single echo dot and continue to next song. You can ask it to paly next song and it's fine but after the song ends, it stop playing. Cloudfare domain and SSL cert port 443 Reversed proxy Command used: alexa, ask m. b. home to shuffle playlist Party Alexa echo set to automatically recognize echo group and plays from multi device 2026-07-08 20:54:42.171 Info SessionManager: PlaySession 5d57587150e745919a9583bb3abde42c has gone idle while playing 2026-07-08 20:54:42.171 Info SessionManager: Playback stopped reported by app Alexa 1.0.0 on Amazon Echo playing Unnamed item. Position: unknown ms. PlaySessionId: . IsPaused: False 2026-07-08 20:54:42.171 Info SessionManager: Removed playSession 5d57587150e745919a9583bb3abde42c from session f3a3e39d8e41b3d9107ca2ecbd92d010 2026-07-08 20:54:42.171 Debug EncodingManager: ReportPlaybackStopped PlaySessionId: 2026-07-08 20:58:08.906 Debug TaskManager: IntervalTrigger fired for task: Refresh Emby Connect Data 2026-07-08 20:58:08.906 Debug TaskManager: Queueing task RefreshAuthorizationsScheduledTask 2026-07-08 20:58:08.906 Debug TaskManager: Executing Refresh Emby Connect Data 2026-07-08 20:58:09.237 Debug TaskManager: Refresh Emby Connect Data Completed after 0 minute(s) and 0 seconds Which version of the skill you are using: Release or Beta. - Release What time you got the error message. If you are unsure, try to recreate the bug and include the time. - about 9pm PST Which language you are using: English US, English UK, etc. - English A description of the problem you are experiencing. What did you say exactly, what Alexa think you said and the behavior you expected.
hatharry 121 Posted July 9 Posted July 9 With the alexa app on your phone please say "alexa ask m. b. home to play a few songs" and check if the next song plays
Goober77 2 Posted July 9 Author Posted July 9 Yes, it continues to play next song on the phone but that audio is only on the phone not the Alexa echo. When I tried that command on the Echo device group, it stops after the first song. Is the session not shared with all the echos in the group? Thanks for your help in advance. d=4c795e8c058a4405b22afca4ea35efc8 2026-07-09 13:30:26.347 Info SessionManager: PlaySession 131316f892b649b3ab3aa225f32704c6 has gone idle while playing 2026-07-09 13:30:26.347 Info SessionManager: Playback stopped reported by app Alexa 1.0.0 on Amazon Echo playing Unnamed item. Position: unknown ms. PlaySessionId: . IsPaused: False 2026-07-09 13:30:26.347 Info SessionManager: Removed playSession 131316f892b649b3ab3aa225f32704c6 from session 16c86dcd33cf74e8f1571a987a085b3f 2026-07-09 13:30:27.717 Info SessionManager: PlaySession 67f54e1a8f9a4342a32e99921d6410f0 has gone idle while playing 2026-07-09 13:30:27.717 Info SessionManager: Playback stopped reported by app Alexa 1.0.0 on Amazon Echo playing Unnamed item. Position: unknown ms. PlaySessionId: . IsPaused: False 2026-07-09 13:30:27.717 Info SessionManager: Removed playSession 67f54e1a8f9a4342a32e99921d6410f0 from session 16c86dcd33cf74e8f1571a987a085b3f 2026-07-09 13:30:28.273 Info SessionManager: PlaySession b79b60fa831144a4a3a0f1718a04634c has gone idle while playing 2026-07-09 13:30:28.273 Info SessionManager: Playback stopped reported by app Alexa 1.0.0 on Amazon Echo playing Unnamed item. Position: unknown ms. PlaySessionId: . IsPaused: False 2026-07-09 13:30:28.273 Info SessionManager: Removed playSession b79b60fa831144a4a3a0f1718a04634c from session 16c86dcd33cf74e8f1571a987a085b3f 2026-07-09 13:30:28.474 Info SessionManager: PlaySession 35c686b97022467595ce3f77c3041933 has gone idle while playing 2026-07-09 13:30:28.474 Info SessionManager: Playback stopped reported by app Alexa 1.0.0 on Amazon Echo playing Unnamed item. Position: unknown ms. PlaySessionId: . IsPaused: False 2026-07-09 13:30:28.474 Info SessionManager: Removed playSession 35c686b97022467595ce3f77c3041933 from session 16c86dcd33cf74e8f1571a987a085b3f
baker171 0 Posted July 11 Posted July 11 i have exactly the same issue 2026-07-11 07:46:04.745 Info SessionManager: Playback stopped reported by app Alexa 1.0.0 on Amazon Echo playing Unnamed item. Position: unknown ms. PlaySessionId: . IsPaused: False
hatharry 121 Posted July 11 Posted July 11 Alexa echo Group support has been added please try again 1
Goober77 2 Posted July 11 Author Posted July 11 Thank you hatharry it's working now! When you ask Alexa to stop, it says "I encounter a glitch. Can you say that again?" It stops the music though.
Goober77 2 Posted July 13 Author Posted July 13 Thank you hatharry it's working now! When you ask Alexa to stop, it says "I encounter a glitch. Can you say that again?" It stops the music though. Edited: Stop music doesn't say the error anymore but playing next song doesn't work now. Tried Alexa next track, next song, and next. Thanks for the quick support. 1
Goober77 2 Posted July 17 Author Posted July 17 Hello, Tested the next song and it works on single echo device and not the group echo. It seems like it acknowledge the command but doesn't process it. Thanks 1
hatharry 121 Posted July 20 Posted July 20 Thanks i will look into what change might have caused the next song not to play. Does the next song play after letting the current song play until the end?
Goober77 2 Posted July 20 Author Posted July 20 Hello, Yes, the next song plays after it ends on the echo group. Thanks for looking this.
Goober77 2 Posted July 20 Author Posted July 20 here is the logs from Emby. 2026-07-20 13:43:24.749 Info SessionsService-0HNN4ENRLPATS:00000001: http/2 POST https://host5/emby/Sessions/06356d41ca6e6e90cded6126cf310244/Playing/NextTrack?api_key=x_secret3_x. Source Ip: host52, UserAgent: node-fetch/1.0 (+https://github.com/bitinn/node-fetch) 2026-07-20 13:43:24.751 Info SessionsService-0HNN4ENRLPATS:00000001: http/2 Response 204 to host52. Time: 2ms. POST https://host5/emby/Sessions/06356d41ca6e6e90cded6126cf310244/Playing/NextTrack?api_key=x_secret3_x. 2026-07-20 13:43:47.630 Info SessionsService-0HNN4ENRLPATN:0000000D: http/2 POST https://host5/emby/Sessions/06356d41ca6e6e90cded6126cf310244/Playing/NextTrack?api_key=x_secret3_x. Source Ip: host52, UserAgent: node-fetch/1.0 (+https://github.com/bitinn/node-fetch) 2026-07-20 13:43:47.631 Info SessionsService-0HNN4ENRLPATN:0000000D: http/2 Response 204 to host52. Time: 1ms. POST https://host5/emby/Sessions/06356d41ca6e6e90cded6126cf310244/Playing/NextTrack?api_key=x_secret3_x.
Goober77 2 Posted July 23 Author Posted July 23 Thanks hatharry! It plays the next song but sometimes after one or two songs of telling it next song, it will jump to a different playlist which is alphabetically the last one in my playlist order. Saying next song after it jumps to that playlist will only continue playing songs in that playlist and will not jump to different playlist. Appreciate all you and your team's hard work in getting this fixed!
Goober77 2 Posted July 28 Author Posted July 28 Hello hatharry, It appears to stop the music when you ask it to play the next song. After that happens and when you try to play a different playlist, it notifies you that it will begin the playlist but no songs play and it's just silent. If you try to tell it to play next song, it tells you that you must state which music provider to play from. I had to switch to a different music provider like Amazon, then back to Emby to get it to work again. Thanks in advance for working on this!
Goober77 2 Posted August 1 Author Posted August 1 Hi hatharry, It seems to play the next song but after that song ends it stop playing after that. If you ask it to play the next song after that, it will stop and doesn't appear to queue up the playlist. Appreciate all the hard work you put into this plugin to get it working!
hatharry 121 Posted August 3 Posted August 3 Thanks for the feedback, Alexa has been updated, can you please try again?
Goober77 2 Posted August 6 Author Posted August 6 It seems to be working a lot more consistent now but maybe 1 of 15 times it will just go silent after you ask it to play the next song, and the only way to get it to play again is changing it to Amazon music and then switching back. Also, is there a way it can let you know if it reached the end of the playlist when you ask it to play next song? It was something Plex plugin had that was pretty nice. As alway appreciate your hard work hatharry!
Goober77 2 Posted August 13 Author Posted August 13 Hello, The next song issue appears to happen if the songs are 10+ minutes where the next song doesn't queue up when you tell it next song, and it just stops. If you let it play all the way, it automatically moves to the next song. If I say next song after a couple minutes on the long songs, it starts the next song perfectly. Hopefully that makes senses lol Appreciate the support from Emby!
hatharry 121 Posted August 17 Posted August 17 (edited) Thanks for the feedback. If I understand correctly if you say "next" near the end of the song it doesn't work but at the beginning or middle of the song it does? Edited August 17 by hatharry
Goober77 2 Posted August 17 Author Posted August 17 Hello hatharry, Yes, that's correct. Another issue is that it might play in a different echo group when you say next. Thanks
Luke 43719 Posted August 18 Posted August 18 16 hours ago, Goober77 said: Hello hatharry, Yes, that's correct. Another issue is that it might play in a different echo group when you say next. Thanks HI there, can you please provide a specific example? How to Report a Problem Thanks !
Goober77 2 Posted August 18 Author Posted August 18 Hello Luke, This is related to telling Alexa next song. If one song has been playing for about more than 10 minutes, and you tell it next song, it will not go to the next track. The other I issue I mentioned above happens randomly when you tell Alexa next song and it begins playing in a different echo group than the one it was originally playing on. The only way to get it to start playing from the correct echo group again is to tell it to play from Amazon music and then switch back to the Emby for the playlist. This happened to me on Saturday morning. Thank you for the support
