kicsrules 4 Posted July 8 Posted July 8 Hello, I have a server that is asking me for a Premiere Subscription whenever i access it from outside my lan, with a domain name... i have two subdomains, same server embyA.exampledomain.stream (this one is registered inside emby) embyB.exampledomain.stream (this one is NOT registered inside emby) both domains are proxied through cloudflare (not tunnels, just dns) if i play a movie with hardware acceleration, it does work, just Live TV is asking me for a Subscription still it's asking me for an emby premiere subscription on the home page and in live tv, if i access the server through tailscale, appears normal (with premiere). what can i do so LIVE TV works outside LAN and remove the premiere requirements.?? embyserver.txt
TMCsw 317 Posted July 9 Posted July 9 6 hours ago, kicsrules said: what can i do so LIVE TV works outside LAN and remove the premiere requirements.?? Do you work for free? Otherwise... https://emby.media/premiere.html 1
Luke 43549 Posted July 9 Posted July 9 Hi, we work very hard on Emby and we thank you for your support. 2
Solution ebr 17032 Posted July 9 Solution Posted July 9 Hi. I suspect something is blocking your browser or other client from validating with our servers. 1
js28194 76 Posted July 9 Posted July 9 (edited) 15 hours ago, TMCsw said: Do you work for free? Otherwise... https://emby.media/premiere.html I don't know how OP can have SAME server, but one "registered and one not" The whole post is confusing. Edited July 9 by js28194
kicsrules 4 Posted July 9 Author Posted July 9 i do have emby premiere, it is registered and working ok in my LAN... i think i figured it out that on the network that i want it to work, probably has a firewall blocking some scripts.... 1
kicsrules 4 Posted July 9 Author Posted July 9 2 hours ago, js28194 said: I don't know how OP can have SAME server, but one "registered and one not" The whole post is confusing. different subdomains, same domain, same server....
pwhodges 2132 Posted July 9 Posted July 9 <shrug> I have two subdomains pointing to the same server, but the server knows only one of them. The reason is historical, but there's no reason to change the current setup. Paul
kicsrules 4 Posted July 9 Author Posted July 9 what ?? same issue on both, doesn't recognize emby premiere on that network, probably of a firewall both subdomains work well in other open networks.....
pwhodges 2132 Posted July 10 Posted July 10 The client must be able to access MB3admin.com. The check is made that way to improve security - not by the client asking the server, which would be a bit like asking it to mark its own homework. Paul 1
kicsrules 4 Posted July 10 Author Posted July 10 thank you for that info, from that network i can't access MB3admin.com, probably that's the issue. 1
ebr 17032 Posted July 10 Posted July 10 2 hours ago, kicsrules said: thank you for that info, from that network i can't access MB3admin.com, probably that's the issue. Hi. That is definitely the issue.
