sa2000 890 Posted July 8 Posted July 8 (edited) 5 hours ago, gdbrow said: Channels don't show up as option for mapping. Thanks for reporting this. I will refer it to Gracenote Can you tell me if channels 20.4 and 20.6 are correct The lineup has them as 20.4 TELE and 20.6 CRIME https://www.rabbitears.info/market.php channels for Portland, Oregon show 20.4 as NTD America and 20.6 as Black Vision TV Edited July 8 by sa2000
gdbrow 2 Posted July 9 Author Posted July 9 Yes, the lineup is correct. 20.4 is Tele and 20.6 is crime. 1
sa2000 890 Posted July 9 Posted July 9 Tahnks @gdbrow 8 hours ago, gdbrow said: the lineup is correct. 20.4 is Tele and 20.6 is crime. Are these the same channels as what shows on https://www.ontvtonight.com/guide/listings/PortlandNight.html for Portland With regards to 20.8 to 20.13, are you able to tell me what the callsigns are showing on the tuner (screenshot?) and confirming what is being broadcast According to rabbitears, they show as 20.8 Jewelry TV 20.9 Shop LC 20.10 COZI TV 20.11 NBC True CRMZ 20.12 Salem News Channel 20.13 America's Voice Español I need confirmation that this list is accurate before referring it to gracenote Thanks
sa2000 890 Posted July 9 Posted July 9 @gdbrowI have referred the above 20.8 to 20.13 list to gracenote as i can see the channel names on https://www.tvpassport.com/tv-listings for Portland, OR region
sa2000 890 Posted July 14 Posted July 14 @gdbrow We had a response from Gracenote indicating that these channels cannot be added to the lineups because the stations are not in their database. It would be up to broadcasters to lisise with gracenote and request inclusion - the broadcaster in this case is KOXI-CD (HC2 Holding) If you find a way to let them know please do - that they should reach out to Gracenote and negotiate inclusion of all their channels in the gracenote dataset
sa2000 890 Posted August 7 Posted August 7 Just an update to let you know that Gracenote are discussing with the KOXI-CD broadcaster the additional channels. It appears that charges are involved and that would need to be agreed between KOXI-CD and Gracenote.
