Luke 42287 Posted October 25, 2013 Posted October 25, 2013 i don't know. you're going to have to provide more information - examples, screenshots, logs, etc.
nicko84 72 Posted October 26, 2013 Posted October 26, 2013 Hi, Even i choose "Saving metadata in media folders" in Tools, images are saving in C:\ProgramData\MediaBrowser-Classic\ImageCache for Movies only but not for TVshows. Images for TVshows are saved in each folders but it doesn't wok for Movies....is it normal ? I've cleanup C:\ProgramData\MediaBrowser-Classic\ImageCache and all images in all folders of my testing media database...and refresh all Movies and TVshows Thanks for your help !
Luke 42287 Posted October 26, 2013 Author Posted October 26, 2013 C:\ProgramData\MediaBrowser-Classic\ImageCache has nothing to do with that setting. That folder is a client-side cache that prevents MBC from downloading images from the server over and over again.
nicko84 72 Posted October 26, 2013 Posted October 26, 2013 (edited) Thanks for your answer, So why there is no images in movies folder ? Edited October 25, 2013 by nicko84
Solution nicko84 72 Posted October 26, 2013 Solution Posted October 26, 2013 I've erased all metadata et images, reinstall Server and client, browse library and it works well know. 1
