tousled 10 Posted June 28 Posted June 28 Hi everyone, I’m opening a new thread because I didn’t want to hijack older OPPO/Xnoppo-related discussions. I’ve been working on a project called Home Cinema Control (HCC). The idea is simple: Use Emby as the library and browsing interface, but let an OPPO / Chinoppo player handle the actual playback locally through SMB/NFS path mapping. So instead of trying to make Emby transcode or stream content to a device that may not handle certain formats properly through DLNA/client playback, HCC acts as a bridge: Emby library → HCC → SMB/NFS path mapping → OPPO/Chinoppo local playback The project is inspired by the same kind of workflow that Xnoppo made useful for OPPO/Chinoppo users, but the goal is to make it more modern, maintained, Docker-friendly and easier to configure through a web UI. Current focus: Emby integration. OPPO / Chinoppo playback target. SMB/NFS path mapping. Docker deployment. Web configuration UI. Playback reporting back to Emby where possible. Clear logs and diagnostics. LG webOS TV control at the moment. Also supported: Better configuration for libraries, path mappings and monitored devices. Planned / under consideration: Sony / Philips / Android TV / Google TV support. Home Assistant integration. Philips Hue / Ambilight cinema scenes. Kodi / Zidoo / Dune playback targets if there is enough interest. The main use case is not to replace Emby. Quite the opposite: HCC assumes Emby remains the main library UI. The goal is to keep the comfort of browsing in Emby while using dedicated local playback hardware for users who care about: UHD remuxes. ISO / BDMV / folder-based libraries. Dolby Vision / HDR. Atmos / DTS:X / HD audio. NAS-based storage. OPPO 203/205 clones such as M9702 / M9201 / M9203 / M9205. Avoiding unnecessary transcoding. Keeping a family-friendly library interface without giving up playback quality. GitHub: https://github.com/tousled/home-cinema-control Current release / setup instructions: https://github.com/tousled/home-cinema-control/releases/tag/1.1.2 I’d really appreciate feedback from Emby users, especially anyone who: Uses or used Xnoppo. Has an OPPO / Chinoppo player. Stores movies on a NAS/Remotely through SMB or NFS. Has trouble with ISO / BDMV / full-disc playback. Wants Emby as the browsing interface but prefers external/local playback. Runs Emby in Docker, Unraid, Synology, QNAP, ASUSTOR or similar. Thanks in advance for any feedback, criticism, compatibility reports or suggestions. 3
tousled 10 Posted June 28 Author Posted June 28 Thank you! I hope that anyone who’s had problems with Xnoppo will be able to enjoy their home cinema with this new app 1
tousled 10 Posted July 8 Author Posted July 8 Hi everyone Home Cinema Control 1.2.1 is now available. The main addition in this release is support for Sony Bravia TVs, expanding HCC’s existing TV and home cinema device integrations. This version also includes several fixes and internal improvements to make configuration and general operation smoother. The new version is available on GitHub and Docker Hub. GitHub Release Docker Hub As always, any testing, feedback or bug reports would be greatly appreciated
borry73 1 Posted September 27 Posted September 27 Hi, thnx for this great program. I`ve tested xnoppo in the past but it didn`t work flawless for me. I`ve got emby runnning on a homebuild server with openmediavault, a LG OLED 65G6, marantz nr1711 and a chinoppo (sold my oppo 203 ) and sofar it works perfectly. Only little thing i could find is that the chinoppo needs to be turned on before i use Emby, home cinema control doesn`t activate the player. 1
tousled 10 Posted October 1 Author Posted October 1 Hello! Thank you very much for using it, and I’m glad it’s working well for you! Yes, that’s something I tried to do at the time – to make the Chinoppo turn on by itself without you having to use the remote control – but it was something I didn’t manage to do, because it didn’t respond to any API commands. Or, at least, I couldn’t find one
tousled 10 Posted October 13 Author Posted October 13 Home Cinema Control 1.4.0 released — Home Assistant integration HCC 1.4.0 is now available. The main addition is a new Home Assistant integration. HCC can publish playback lifecycle events when an intercepted Emby playback starts, pauses, resumes or stops, allowing Home Assistant to react without coupling home automation directly to the Emby/OPPO playback implementation. Typical uses would be cinema-room lighting, scene restoration or other local automations around a movie session. Home Assistant delivery is asynchronous and isolated from the playback-critical path, so webhook failures or a temporarily unavailable HA instance cannot prevent the Emby → HCC → OPPO handoff from working. 1.4.0 also adds background update notifications through Home Assistant and supported TV integrations, plus optional anonymous startup timing telemetry to help measure playback-start performance on different installations. There has also been a substantial internal cleanup around provider boundaries and playback lifecycle handling. Emby-specific payload interpretation now remains in the Emby adapter while the common playback layer deals with shared behaviour. For anyone who missed the very recent 1.3.2/1.3.3 updates, 1.4.0 also includes the Windows path-mapping correction and the fix for direct playback of .strm-backed Emby items. Release: https://github.com/tousled/home-cinema-control/releases/tag/1.4.0 Project: https://github.com/tousled/home-cinema-control Feedback from different Emby installations is very welcome.
Eigeplackter 117 Posted October 13 Posted October 13 I just pulled the image and opened up webpage, but even though there‘s an english install guide, I can‘t cope with an only spanish Interface. Will there be an option to change UI language any time soon ?
tousled 10 Posted October 13 Author Posted October 13 52 minutes ago, Eigeplackter said: I just pulled the image and opened up webpage, but even though there‘s an english install guide, I can‘t cope with an only spanish Interface. Will there be an option to change UI language any time soon ? Hi! Thanks for contacting me. There's already a button. It's in the lower-left corner, as shown in the image below: 1
anthony_m 10 Posted November 20 Posted November 20 Hi, this looks very interesting, great work! As I have Emby running on an intel Qnap that also has Container Station installed this may not be the most straightforward install but I will have a look on the wekend. If you have any pointers on how to get HCC running within Container Station please let me know. From what it looks like it supports Docker Compose so this should work out somehow 1
tousled 10 Posted November 20 Author Posted November 20 (edited) Hi Anthony! Thanks for your interest in HCC! Since your QNAP is Intel-based and already has Container Station installed, I think you should be able to get HCC running without too much trouble. Container Station supports Docker Compose, so you can just create a new application and use the configuration you can find in the installation guide. Just change the timezone to yours. Once it's running, you should be able to access HCC at `http://YOUR_QNAP_IP:8090` and go through the setup wizard. The main thing is to keep host networking enabled so HCC can communicate with your devices. You'll also need to make sure port 8090 isn't already being used. I haven't tested HCC on QNAP myself, but I don't see any reason why it shouldn't work. If you run into any problems, let me know and we'll try to figure it out. By the way, I'm currently finishing up HCC 1.5.0, which should be released in the next few days. It will include experimental Samsung TV support and automatic power on/off for OPPO/Chinoppo and Kodi devices. If you manage to get it running on your QNAP, it'd be great to know how it went. I could then add QNAP to the installation documentation. Thanks again, and feel free to ask if you need a hand! Edited November 20 by tousled 1
anthony_m 10 Posted November 21 Posted November 21 Thank you, will of course update you once I progress further. I think it would be nice to be able to have a solution that works with the usual suspects when it comes to Network storage. Synology is probably bigger but from what I can see there are also a substantial number of Qnap users. There is a big stumbling block though as I just remembered that the OPPO cannot get a direct connection to the Qnap as they are not supporting the SMB v1 protocol any more and truth be told I was not that comfortable with using SMB v1 anyway. As a workaround I am using a Raspberry Pi as an SMB "bridge" for all folders that the OPPO needs to access directly and that has proven to be a good way to still access them via SMB v1. Correct me if I am wrong but I take it there is no option to "translate" the network address of my movie library to the one the OPPO needs to see (different path and IP). In that case I will first have to make sure somehow that the OPPO can access the exact same path that Emby uses and not only the path through the Raspberry.
tousled 10 Posted November 21 Author Posted November 21 Hi Anthony! You're absolutely right about Synology and QNAP, and that's actually one of the main advantages of HCC. Since it runs as a Docker container, it isn't tied to any particular NAS manufacturer. You can run it on ASUSTOR, QNAP, Synology, TrueNAS, or other compatible Docker hosts, including a Raspberry Pi or a Windows PC with Docker Desktop. Regarding SMBv1, have you considered using NFS instead? The OPPO UDP-203 supports NFS, and QNAP can serve NFS shares directly. If your OPPO firmware supports it correctly, you could potentially connect straight to your QNAP without needing the Raspberry Pi as an SMB bridge. And about your question regarding paths, HCC does exactly what you're describing Emby and the OPPO don't need to use the same network address or folder path. HCC lets you map the path used by Emby to the corresponding path accessible by the OPPO, even when they use different IP addresses. So you could also keep your existing Raspberry Pi setup if you prefer. As long as the OPPO can access the movies through it, HCC can map those paths to your Emby libraries. I'm also sharing the installation guide and the media paths guide, as they should help explain how everything works: - Installation: https://github.com/tousled/home-cinema-control/blob/main/INSTALL.en.md - Media paths: https://github.com/tousled/home-cinema-control/blob/main/docs/configure-media-paths.en.md I'd personally try NFS directly from the QNAP first, as it could simplify your setup quite a bit. Let me know how you get on. I'd be very interested to hear how HCC works with your QNAP setup! 1
anthony_m 10 Posted November 22 Posted November 22 So I spent a bit of time with it, looks easy enough on paper to get things going with just uploading the reference yaml file from GitHub. I did just that and it looked like I was on my way to the install but then I got this error: Not sure if that is an issue on my side or on yours?
tousled 10 Posted November 22 Author Posted November 22 Hi Anthony! Thanks for giving HCC a try, and especially for taking the time to report this! I've identified the issue. The reference `compose.yaml` on GitHub uses a version variable that your Docker management tool doesn't seem to be resolving correctly. Fortunately, the fix should be straightforward. Find this line in your YAML file: `image: ghcr.io/tousled/home-cinema-control:${HCC_VERSION:-latest}` And replace it with: `image: tousled/home-cinema-control:latest` Then try deploying it again. You can also find the simplified configuration in our [installation guide](https://github.com/tousled/home-cinema-control/blob/main/INSTALL.en.md). I'll make sure we address this inconsistency in our installation files so other users don't run into the same problem. By the way, which platform are you using to deploy HCC? Let me know how it goes. I'd be happy to help you get everything running! Thanks again for your interest in HCC! 1
anthony_m 10 Posted November 23 Posted November 23 (edited) Thanks, that worked. I managed to stumble my way to the next road block which is the path editing. I mapped my SMB path (I got it all working and a bunch of shortcuts active over several players so I think it will stay) but I got this error message: It says that SMB was not attempted which is strange as I thought I had it activated here: Looks correct to me? Overall the whole experience seemed pretty straightforward. Found Emby, filled in the OPPO IP address and off I went. Also what I saw from the interface until now looks very polished - looking forward to finally play my first folders Edited November 23 by anthony_m
tousled 10 Posted November 23 Author Posted November 23 Hi Anthony! First of all, I'm really glad you've got HCC up and running! And thanks for the kind words about the interface — it's great to hear that the initial setup has been straightforward. I've looked into your error, and I think we can narrow it down. You're right: Use SMB/CIFS is enabled in your screenshot. I've checked the code and found that the diagnostic message about SMB not being attempted can be misleading. That's something we need to improve on our side. The id_without_remember error seems to be coming from the OPPO's network authentication/mounting process. Could you try the following? In Media Paths → OPPO access, keep Use SMB/CIFS enabled. If your SMB share requires authentication, enter the NAS username and password. Enable Pre-mount SMB share before playback. This is a compatibility workaround we've found useful with some OPPO/NAS combinations. Click Save in the OPPO access section, then try Test path again. One other thing I'd like to check: can you browse and play files from that same SMB share directly through the OPPO's own network menu? If it still fails, let me know your OPPO/Chinoppo model and NAS model, and ideally share the player-side path you're trying to configure (without any credentials). I suspect we're dealing with an OPPO SMB authentication or mounting quirk rather than an Emby connection problem. We're getting closer to that first movie! 1
anthony_m 10 Posted November 23 Posted November 23 Thanks for your help, for some reason I could not see the Raspberry Pi any more via the OPPO so there was no way I should expect HCC to work that way. It took all of 10 minutes to get NFS working that supposedly was hard to get going years ago and now I am up and running I just tested that I can now enjoy perfect folder playback via Emby and also chapters work at all times which is something that always bugged me - excellent work! Minus the time wasted on trying to troubleshoot SMB this was very straightforward and easy to do, here is a screenshot from my Qnap NAS Container Station for other users: Basically it is Container Station -> Applications -> Create and then the user only has to upload your yaml file that I assume is already working by now so that is really easy to do once Container Station is installed which also is very easy. Instructions for adding the Emby player and the OPPO are also easy to follow and I would suggest to go the NFS route in order to not waste time on SMB, here are my settings for activating NFS and in the Edit Shared Folder Permission Window for NFS: This is with QTS 5.2.8.3321.
tousled 10 Posted November 23 Author Posted November 23 On 9/27/2026 at 6:21 PM, borry73 said: Hi, thnx for this great program. I`ve tested xnoppo in the past but it didn`t work flawless for me. I`ve got emby runnning on a homebuild server with openmediavault, a LG OLED 65G6, marantz nr1711 and a chinoppo (sold my oppo 203 ) and sofar it works perfectly. Only little thing i could find is that the chinoppo needs to be turned on before i use Emby, home cinema control doesn`t activate the player. HCC 1.5.0 will be released shortly with this new feature!
tousled 10 Posted November 23 Author Posted November 23 1 hour ago, anthony_m said: Thanks for your help, for some reason I could not see the Raspberry Pi any more via the OPPO so there was no way I should expect HCC to work that way. It took all of 10 minutes to get NFS working that supposedly was hard to get going years ago and now I am up and running I just tested that I can now enjoy perfect folder playback via Emby and also chapters work at all times which is something that always bugged me - excellent work! Minus the time wasted on trying to troubleshoot SMB this was very straightforward and easy to do, here is a screenshot from my Qnap NAS Container Station for other users: Basically it is Container Station -> Applications -> Create and then the user only has to upload your yaml file that I assume is already working by now so that is really easy to do once Container Station is installed which also is very easy. Instructions for adding the Emby player and the OPPO are also easy to follow and I would suggest to go the NFS route in order to not waste time on SMB, here are my settings for activating NFS and in the Edit Shared Folder Permission Window for NFS: This is with QTS 5.2.8.3321. Hi Anthony! That's fantastic news! I'm really happy to hear that you've finally got everything working and, even better, that you're enjoying the playback experience and chapter navigation! Thank you so much for your patience, for testing HCC, and especially for taking the time to share your QNAP setup and screenshots. Feedback like yours is incredibly valuable, particularly as I'm working towards the final 1.5.0 release. I'm also really pleased to hear that you found the installation straightforward overall. Making HCC accessible to people without requiring complicated technical setups has been one of my main goals. Would you mind if I used your screenshots to create a QNAP installation guide in HCC's official documentation? I think they could be really helpful to other QNAP users. I'd be happy to credit you as anthony_m, if you'd like! One small suggestion regarding your NFS configuration: I noticed you've used * under Host / IP / Network, which allows access from any client that can reach the NFS service. Since your OPPO is the device accessing the files, you could replace * with your OPPO's local IP address. That would restrict NFS access to the player and make the configuration more secure. It should continue working just as well, provided the OPPO keeps that IP address and no other devices need NFS access to the same share. And finally, I'm really glad the chapter navigation is working reliably for you. That's exactly the kind of experience I want HCC to deliver! Thanks again for all your help and encouragement. Enjoy your movies!
anthony_m 10 Posted November 23 Posted November 23 Feel free to use those screenshots, happy to help. And no credit needed, you deserve it much more than us users! The player was set to DHCP so for now I put an *. I will change that once I know how many players should work with NFS and their IP addresses. I read about your plan to support more than one player so if that is also planned for 1.5.0 I look forward to it a lot 1
tousled 10 Posted November 23 Author Posted November 23 Hi everyone, Just a quick update on Home Cinema Control: HCC 1.5.0 is now available. The biggest addition is Kodi support. You can now use Emby as your library interface and let HCC start playback on either a compatible OPPO/Chinoppo player or Kodi, using media files accessible over NFS or SMB. There's also quite a bit of work in this release for existing OPPO/Chinoppo users: Better Blu-ray ISO/BDMV resume and playback-position handling, particularly around disc menus. Experimental automatic player power-on/off, including a configurable shutdown delay. More reliable switching between movies and different versions of the same movie. Improved audio/subtitle selection, setup screens and diagnostics. Better feedback when an update is triggered through Portainer. I've also started working on Samsung TV integration. It's available as an experimental feature, but I still need feedback from more models before making broader compatibility claims. HCC has been tested with a Samsung S90C tv model. The aim hasn't changed: keep Emby for browsing and managing the library, and use HCC to coordinate playback on the device you actually want to watch on. Thanks to everyone who's given feedback or helped troubleshoot issues so far. Release notes: https://github.com/tousled/home-cinema-control/releases/tag/1.5.0 Project and setup guides: https://github.com/tousled/home-cinema-control If you're using Emby with an OPPO/Chinoppo or Kodi setup, I'd be interested to hear how 1.5.0 works for you.
anthony_m 10 Posted Tuesday at 10:07 AM Posted Tuesday at 10:07 AM So I saw the improvements and was curious. Tried to update and got this error: How do I configure a webhook? Also watched my first complete movie yesterday - perfect playback
tousled 10 Posted Tuesday at 01:50 PM Author Posted Tuesday at 01:50 PM I use Portainer Business Edition and it's pretty easy, but I don't know how to do with Container Station in QNAP. However, if you want to update HCC, I have found this tutorial for Container Station 3: https://promincproductions.com/blog/update-container-version-in-qnap-container-station-3/#Steps-for-Update-in-Place-to-Upgrade-an-8220Application8221-Image-in-Container-Station-3 I hope it helps!
anthony_m 10 Posted Wednesday at 08:50 AM Posted Wednesday at 08:50 AM Thanks good find but unfortunately this did not go too well. Pretty glad I had a duplicate as the update attempt completely destroyed the container - it is gone Here is the error message: For me 1.4.6 seems to be running quite well and I am tempted to just install 1.5.0 in parallel to check out the improvements if I stumble into any issues with 1.4.6. I have very few settings to redo, only the folder paths and the OPPO ip-address, so it should only take maybe 10 minutes to get going. For others with more settings it would be pretty cool though if we could have the option to back up all user settings or is there already such an option that I may have overlooked?
