Swaf 2 Posted June 22 Posted June 22 Bonjour, quelqu'un aurait une m3u qui fonctionne dans emby avec les chaines française de base (surtout le groupe tf1, flemme de passer par leur appli) Merci d'avance !
Luke 43719 Posted June 22 Posted June 22 HI, if you google french m3u channels you should be able to find some.
Swaf 2 Posted June 22 Author Posted June 22 Hi, no sadly in France Even the free tnt Channel block their channel in m3u list 1
CLB01 1 Posted July 3 Posted July 3 (edited) Good morning, Here is a URL that works for me (not tested with Emby but on another IPTV application): [redacted] It takes a little while to understand, but all the channels are there (you may need to replace TF1 and M6 with TF1 Swiss and M6 Swiss, which are a little further down in the list). Edited July 3 by ebr removed url
ebr 17102 Posted July 3 Posted July 3 Hi. I'm afraid that link is most likely not legal to access in many parts of the world so we cannot have it here. Thanks.
Tandhruil 28 Posted July 8 Posted July 8 En espérant que ce lien soit autorisé : https://github.com/iptv-org/iptv/blob/master/PLAYLISTS.md
MAX92 110 Posted July 24 Posted July 24 Tu as trouvé ? @SwafMon HDHomeRun a rendu l'ame et avant de le remplacer je veux explorer cette piste
Swaf 2 Posted July 30 Author Posted July 30 (edited) non j'avoue avoir abandonné, une de celle dispo ici avait tf1 en clair dans la liste mais pas tmc/tfx/m6 etc je viens de re-regarder mais le ghitub officiel tu as bien tmc tfx tf1 (du moins dans vlc pas retest dans emby) Edited July 30 by Swaf
Tandhruil 28 Posted July 30 Posted July 30 (edited) Pourtant je trouve bien TF1, TMC ou M6 dans ce m3u ? https://iptv-org.github.io/iptv/countries/fr.m3u edit : J'avoue ne plus l'utiliser depuis 2 ans la fonction IPTV n'avait pas d'utilité pour les utilisateurs. Edited July 30 by Tandhruil
MAX92 110 Posted July 30 Posted July 30 Effectivement il existe dans le flux mais il ne fonctionne pas. Très peu de chaines fonctionnent (pas TF1, ni M6)
Swaf 2 Posted August 1 Author Posted August 1 pour le coup j'ai tf1/tmc/tfx fonctionelle avec le lien perso
Swaf 2 Posted August 2 Author Posted August 2 Pour le couo c’est le tf1 720 qui marche de mon cote mais ca lag pas mal
