PeteGul 54 Posted June 19 Posted June 19 Hi I have two problems with my Emby system, both regard Friend’s TV show. 1: Emby for Android won't show dvdsub on my nVidia Shield TV 2019 pro. Tested on an iPhone it loads subs Android phone does not load subs, another Android tv system loads subs(Get tv box in Norway, tested one week ago), Emby web shows the subtitles. It is my Shield and Android phone that does not show it. Logs can be sent in PM if needed as they are not depersonalized. 2: The show won't auto resume either. Other tested shows will. Is there any setting that I have forgotten, or is it an Android bug? I think it is strange that it works on web and iPhone. This tells me (I think) that it is not a server problem. Phones and everything is updated to latest builds. The server is on latest beta.
PeteGul 54 Posted June 19 Author Posted June 19 Will just add that if I use "Playback Correction" the sun is showing afterwards. So in my opinion now, this is a server issue that don't understand what works or not. And there should be an option for burn in of subs.
ebr 17102 Posted June 22 Posted June 22 On 6/19/2026 at 4:26 AM, PeteGul said: Emby for Android won't show dvdsub on my nVidia Shield TV 2019 pro. Tested on an iPhone it loads subs Android phone does not load subs Hi. What app version?
PeteGul 54 Posted June 22 Author Posted June 22 It is the latest on everything, it has being an problem for a while so I try to always check for the newest all the time. Emby for Android 3.5.36, Emby server 4.10.0.15 beta
PeteGul 54 Posted July 13 Author Posted July 13 Is there any help on this. Googled, Gemini, ChatGPT, everything I can think of. It's always the same answer, something like: "After an update (must be long ago) the developer removed the option to set burn in or other settings for transcoding subtitles". And I would say I agree, there is very limited options for subtitles, in my head it was more options before. Force burnin etc... This is not a good thing, it works at once I push the "fix playback" option while playing the series. So I know it works. And as far as I understand this is a problem of the player used on Nvidia Shield's, so subtitles like this have to be burned in. Let's have it as a choice as it has been before. (If I remember right) In my opinion, I didn't think this should be a problem anymore. Subtitles there is....
PeteGul 54 Posted July 14 Author Posted July 14 The one i selct to get the subs back under playing is: Playback Correction. If I use this, the sub are showing as the should. If I remember correctly it was more options on the server side regards for subs. Like "Force burn in", but this could be an error in my head But still, I think my shield played this before, so I don't understand.
ebr 17102 Posted July 14 Posted July 14 1 hour ago, PeteGul said: If I remember correctly it was more options on the server side regards for subs. Like "Force burn in", but this could be an error in my head Perhaps you had the Diagnostics plug-in installed...?
PeteGul 54 Posted July 14 Author Posted July 14 3 hours ago, ebr said: Perhaps you had the Diagnostics plug-in installed...? Not as far as I recall. Is this an known problem? If so, is there any more info needed?
Luke 43720 Posted July 15 Posted July 15 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
PeteGul 54 Posted July 16 Author Posted July 16 Here is my logs, tried to sanitize them. What I did: Open Emby - Goes to Tv shows menu - select show and season - Start to play the show (Friends) - let it play for a while without any subs then activate "playback correction" and the sub is there. embyserver-63919756800.txt ffmpeg-transcode-11f960db-583d-46f2-bd59-2bdf5fef7a41_1.txt embyserver.txt emby_android_1784225023464.txt
PeteGul 54 Posted July 18 Author Posted July 18 Update: Tried Moonfin just for fun. Same problem there. Media3 player don't show at all, mpv player trying to show but it just stops.
