Kramerika 21 Posted June 15 Posted June 15 I refreshed my HD Homerun channel list, and now have a new subchannel for one network. I refreshed the Emby guide data, and it did not show up there and does not show up when I try to manually map it. zip code: 17070 channel: 21.4 WHP-DT4 Charge! It is showing up here: https://www.channelmaster.com/pages/tv-antenna-map-new-cumberland-pa-17070 It's been a while since I had any issues with guide data, so I am out of the loop on what else I can do.
sa2000 890 Posted June 15 Posted June 15 4 hours ago, Kramerika said: zip code: 17070 channel: 21.4 WHP-DT4 Charge! Thank you for reporting this. I can see that 21.4 is showing as available for your area TV Market and that the station is of similar signal strength as 21.1 to 21.3 I have passed a request to Gracenote to add the channel to the USA-OTA17070 lineup.
