Pejamas 259 Posted June 13 Posted June 13 Hi everyone, I wanted to share a custom Emby Web theme I’ve been working on called ElegantEmby. It is a dark, rounded theme for Emby Web with softer panels, cleaner cards, muted accent colors, larger Spotlight artwork/logo styling, circular cast images, polished buttons, and a more modern overall layout. Quote The visual style is inspired by ElegantFin by lscambo13: https://github.com/lscambo13/ElegantFin This has been adapted specifically for Emby Web. PEJAMAS_PC — Mozilla Firefox 2026-06-13 09-59-34.mp4 Main Features Dark slate-style interface Rounded cards and panels Cleaner top navigation tabs Styled sidebar and search field Larger Spotlight logo and metadata Cleaner Spotlight metadata separators Circular cast and crew images Themed buttons, dialogs, lists, inputs, scrollbars, and progress bars Custom accent color variables Optional Spotlight companion script Files Included Quote There are two files: Elegantemby.css - This is the main theme file. This is required. Elegantemby.css Elegantemby.spotlight.js - This is optional. It adds extra Spotlight features such as a hover play button, ratings, and trailer preview behavior. Elegantemby.spotlight.js Install the CSS Theme Open Emby Dashboard. Go to Settings > General. Paste the contents of Elegantemby.css into Custom CSS. Save. Hard refresh your browser. Hard refresh shortcuts: Windows / Linux: Ctrl + F5 Mac: Cmd + Shift + R Quote The base theme only needs the CSS file. Optional Spotlight Script Quote Emby’s main page only accepts CSS, so the JavaScript file needs to be added separately. The easiest option is to use the Custom CSS/JS plugin - https://github.com/Shurelol/EmbyCustomJS_Css Paste Elegantemby.spotlight.js into the Custom JS box, Add a name and set force on > save. You can also inject it through a reverse proxy or manually add it to index.html, but the plugin method is the simplest. Changing the Accent Color Near the top of Elegantemby.css you’ll find: --ee-accent-h: 176; --ee-accent-s: 3%; --ee-accent-l: 63%; These control the theme accent color. Hue examples: Quote 0 = red 25 = orange 95 = green 160 = teal 210 = blue 251 = purple Saturation (s) controls color strength and Lightness (l) controls brightness. Notes: The main CSS theme is intended for the current stable Emby Server/Web release. The optional Spotlight companion script and CSS is currently intended for Emby beta only. If you are on the current stable release, use the CSS theme by itself (you can keep the Spotlight CSS in to be ready for spotlight on release or remove it) and skip the Spotlight script section. Feedback, screenshots, and fixes are welcome. 5 1
craighton 0 Posted July 10 Posted July 10 Love it! I use this theme on Jellyfin and love to see it over here. I found one bug, it appears that with viewing Live TV there is a blue overlay to the video.
Pejamas 259 Posted July 11 Author Posted July 11 1 hour ago, craighton said: Love it! I use this theme on Jellyfin and love to see it over here. I found one bug, it appears that with viewing Live TV there is a blue overlay to the video. I'll see what I can figure out today (don't have live TV so never thought to check this) I've added some more changes from the jelly theme too - season episodes display in the same card view instead of the vertical list.
craighton 0 Posted July 11 Posted July 11 It appears it has to do with .backgroundContainer.withBackdrop { background-color: var(--ee-darkerGradientPointAlpha) !important; } And HTML <div class="backgroundContainer withBackdrop backgroundContainer-transparent"></div>
Pejamas 259 Posted July 18 Author Posted July 18 On 11/07/2026 at 13:56, craighton said: It appears it has to do with .backgroundContainer.withBackdrop { background-color: var(--ee-darkerGradientPointAlpha) !important; } And HTML <div class="backgroundContainer withBackdrop backgroundContainer-transparent"></div> Should be fixed now, this css file includes a host of changes (ive moved away from using the JS script, felt too unsafe imo) Most noteable change is the tv episode grive view inline with the jellyfin theme Elegantemby.css
ZanderKeen 88 Posted July 18 Posted July 18 This really looks decent. TY! While it looks great on my 4K screen, The only part that bothered me was on my smaller 22" monitor (1680x1050) the top pillbox navigation section was too far down with too much padding so I added this to the very bottom of the CSS & it looks perfect now. ((See photos below to compare)) I'm not really good at programming so I ran it thru my LLM and here is what it spit out. I figured I would drop the code here. /* =========================================================================== * Tab Position Fix - Pin tabs to top of header * ======================================================================== */ @media not all and (min-width: 66em) { .headerMiddle-withSectionTabs:not(.headerMiddle-tv) { margin-top: 0 !important; height: 2.5em !important; position: absolute !important; top: 23px !important; left: 0 !important; right: 0 !important; } } @media (min-width: 80em) { .headerMiddle.sectionTabs.headerMiddle-withSectionTabs { position: absolute !important; top: 13px !important; bottom: 0 !important; left: 0 !important; right: 0 !important; width: 60% !important; } } /* =========================================================================== * Page Padding Fix * ======================================================================== */ @media (min-width: 40em) { .skinBody-withFullDrawer .page-windowScroll.withTabs, .skinBody-withFullDrawer .withTabs .padded-top-page, .page-windowScroll.withTabs, html:not(.layout-tv) .withTabs .padded-top-page { padding-top: calc(5.5em + (var(--window-inset-top) * .7)) !important; } } /* =========================================================================== * Header Height * ======================================================================== */ .skinHeader:not(.osdHeader) { min-height: 75px !important; height: auto !important; padding-top: 0.4em !important; padding-bottom: 0.4em !important; } .emby-tab-button { padding-top: 0.3em !important; padding-bottom: 0.3em !important; line-height: 1.2 !important; } Before: After: I'll match my colors on the artwork later this week.
Pejamas 259 Posted July 18 Author Posted July 18 51 minutes ago, ZanderKeen said: This really looks decent. TY! While it looks great on my 4K screen, The only part that bothered me was on my smaller 22" monitor (1680x1050) the top pillbox navigation section was too far down with too much padding so I added this to the very bottom of the CSS & it looks perfect now. ((See photos below to compare)) I'm not really good at programming so I ran it thru my LLM and here is what it spit out. I figured I would drop the code here. /* =========================================================================== * Tab Position Fix - Pin tabs to top of header * ======================================================================== */ @media not all and (min-width: 66em) { .headerMiddle-withSectionTabs:not(.headerMiddle-tv) { margin-top: 0 !important; height: 2.5em !important; position: absolute !important; top: 23px !important; left: 0 !important; right: 0 !important; } } @media (min-width: 80em) { .headerMiddle.sectionTabs.headerMiddle-withSectionTabs { position: absolute !important; top: 13px !important; bottom: 0 !important; left: 0 !important; right: 0 !important; width: 60% !important; } } /* =========================================================================== * Page Padding Fix * ======================================================================== */ @media (min-width: 40em) { .skinBody-withFullDrawer .page-windowScroll.withTabs, .skinBody-withFullDrawer .withTabs .padded-top-page, .page-windowScroll.withTabs, html:not(.layout-tv) .withTabs .padded-top-page { padding-top: calc(5.5em + (var(--window-inset-top) * .7)) !important; } } /* =========================================================================== * Header Height * ======================================================================== */ .skinHeader:not(.osdHeader) { min-height: 75px !important; height: auto !important; padding-top: 0.4em !important; padding-bottom: 0.4em !important; } .emby-tab-button { padding-top: 0.3em !important; padding-bottom: 0.3em !important; line-height: 1.2 !important; } Before: After: I'll match my colors on the artwork later this week. The one thing i ALWAYS forget, not everyone has my same setup. WIll look at adding this in (and checking any other elements on a smaller resolution). 1
Mangopulp 0 Posted July 23 Posted July 23 On 7/17/2026 at 11:15 PM, ZanderKeen said: This really looks decent. TY! While it looks great on my 4K screen, The only part that bothered me was on my smaller 22" monitor (1680x1050) the top pillbox navigation section was too far down with too much padding so I added this to the very bottom of the CSS & it looks perfect now. ((See photos below to compare)) I'm not really good at programming so I ran it thru my LLM and here is what it spit out. I figured I would drop the code here. /* =========================================================================== * Tab Position Fix - Pin tabs to top of header * ======================================================================== */ @media not all and (min-width: 66em) { .headerMiddle-withSectionTabs:not(.headerMiddle-tv) { margin-top: 0 !important; height: 2.5em !important; position: absolute !important; top: 23px !important; left: 0 !important; right: 0 !important; } } @media (min-width: 80em) { .headerMiddle.sectionTabs.headerMiddle-withSectionTabs { position: absolute !important; top: 13px !important; bottom: 0 !important; left: 0 !important; right: 0 !important; width: 60% !important; } } /* =========================================================================== * Page Padding Fix * ======================================================================== */ @media (min-width: 40em) { .skinBody-withFullDrawer .page-windowScroll.withTabs, .skinBody-withFullDrawer .withTabs .padded-top-page, .page-windowScroll.withTabs, html:not(.layout-tv) .withTabs .padded-top-page { padding-top: calc(5.5em + (var(--window-inset-top) * .7)) !important; } } /* =========================================================================== * Header Height * ======================================================================== */ .skinHeader:not(.osdHeader) { min-height: 75px !important; height: auto !important; padding-top: 0.4em !important; padding-bottom: 0.4em !important; } .emby-tab-button { padding-top: 0.3em !important; padding-bottom: 0.3em !important; line-height: 1.2 !important; } Before: After: I'll match my colors on the artwork later this week. where did you get images for the my media bar they super cool. I would really like to use them
ZanderKeen 88 Posted July 29 Posted July 29 On 7/23/2026 at 6:45 PM, Mangopulp said: where did you get images for the my media bar they super cool. I would really like to use them @Mangopulp Hey I'm glad you noticed & like them. I created them on gimp & hunted for matching images with transparent backgrounds then layered with the emby logo. When I get some time I will post a topic for it with my gimp template I use along with what images I already created. I tried to keep a green theme with them since emby's logo is green.
chrismallia 13 Posted August 4 Posted August 4 Hi, first off thanks for this theme. Been running it on my server for a bit and the web client finally looks like something I want to open. Much appreciated. Ran into one issue and I think I found the cause, so posting it here in case it's useful. The preview thumbnails when you hover the progress bar during playback weren't showing for me. The bubble itself appeared fine - right size, dark background, chapter name and timestamp all there - just no image. Turns out Emby builds that bubble with the class "sliderBubble dialog", and it paints the thumbnail as an inline style: nowPlayingPositionSlider.getBubbleElement().style.backgroundImage = "url('...')" So it gets caught by this rule in the theme: html body .dialog { background: rgb(23, 31, 44) !important; background-color: rgb(23, 31, 44) !important; ... } The background shorthand sets background-image to none, and because it's !important it beats a normal inline style. So the image gets wiped before it can render. Removing just the shorthand line fixes it, and nothing changes visually because the background-color line right underneath is already doing the work. Same thing on the .sliderBubble rule further up. That one isn't !important so it doesn't kill the image, but the shorthand still resets background-size and background-repeat, so the thumbnail ends up tiled at full size instead of fitted. Changing it to background-color sorts it: .sliderBubble { border-radius: var(--ee-smallRadius); background-color: var(--ee-drawerColor); } One caveat - I'm on 4.10.0.22 beta, not stable. So I honestly don't know if this is a 4.10 markup change or if it hits everyone. If someone on stable can hover the progress bar mid playback and say whether the thumbnail shows properly, that would settle it. My guess is the tiling one would still show up on stable even if the first doesn't. Second thing, unrelated. On the dashboard the server info panel at the top (version, ports, LAN and WAN access) is basically unreadable for me. Emby gives .infoBanner a light background of its own and the theme doesn't restyle it, so you end up with light grey text on near white. Added this and it's fine now: .infoBanner { background-color: var(--ee-selectorBackgroundColor); color: var(--ee-textColor); } Worth knowing if you try it - I had to use "html body .infoBanner" with !important to make it stick. The dashboard's own CSS gets lazy loaded when you navigate there, so it lands after the custom CSS and wins at equal specificity. Took me a while to work that out, I thought my rule just wasn't loading at all. Anyway, minor stuff overall. Thanks again for putting this together.
chrismallia 13 Posted August 4 Posted August 4 (edited) Follow up - I checked the stable image so nobody has to guess. 4.9.5.0 has both of the same bits: the bubble is still built as "sliderBubble dialog", and the thumbnail is still set inline with getBubbleElement().style.backgroundImage. So it isn't something new in 4.10, stable is affected the same way. On the .infoBanner one, I had the cause wrong earlier and want to correct it properly. It is nothing to do with the main Theme setting. Emby's Display settings have a second dropdown called "Settings theme" which is separate from "Theme", and out of the box it defaults to Light while the main Theme defaults to Dark. The dashboard and settings pages follow that second dropdown, which is why you can be on a dark setup and still get a near-white info banner in there. So it only affects people still on the default Settings theme, not everyone. And setting "Settings theme" to Dark or Black fixes the contrast on its own with no CSS at all, so it may not be worth changing anything in the theme for it. Your call. The seek thumbnail one above is the one I would actually bother with. Edited August 4 by chrismallia
chrismallia 13 Posted August 4 Posted August 4 (edited) Ignore this one, I got the cause wrong here and folded the corrected version into my post above. Short version: it is the separate "Settings theme" dropdown, not the main Theme. Edited August 4 by chrismallia
MediaEmby1968 91 Posted August 28 Posted August 28 Nice topic, I had already seen this topic on the internet. But some questions - How can I make the movie tabs wider, they seem narrow and elongated to me. - Also how to change the color of the seen and unseen icon Thank you
MediaEmby1968 91 Posted August 31 Posted August 31 I've found a bug, at least it's happening to me. The "Continue Watching" and "Latest" images under "X" and more are cut off on the right. Here's a screenshot so you can see what I mean.
