GrumpyBear2014 0 Posted December 2, 2014 Posted December 2, 2014 I have one system that I am not able to play DVD from. When I click on the App for the optical drive it gives me the error of " Error beginning playback, Value cannot be null. Parameter name: source" I have MBT installed on three other machines and have no issues. Only errors if there is no disk in the drive. The only difference in the machine in question is that the optical drive is a BlueRay drive. At this point I am not concerning myself if it will play BlueRay disks. Am just wanting it to play a DVD. Log file is attached. theater-63553075200.txt
byngo 6 Posted December 4, 2014 Posted December 4, 2014 Im a newbie to MBT but I had that same message last night with a bluray disk actually. Not sure if its the answer but I know that I had been playing about with adding an external player (PDVD). The error message is a complaint that I had not correctly set up the parameters for this external player correctly ie either the path to the executable or arguments such as {path} /play. I forget which I had to jiggle with but have you been playing with adding an external software player on that machine but not got the setting right?
GrumpyBear2014 0 Posted December 5, 2014 Author Posted December 5, 2014 The issue is not that I want to play BluRay disks. I only want to play a DVD movie. It just happens to be that the optical drive in this machine is a BluRay player. So there should not be any need to add the external player.
GrumpyBear2014 0 Posted December 26, 2014 Author Posted December 26, 2014 Nobody else have ideas? Nobody bothering to look at the log? Please somebody help!
Luke 42241 Posted December 26, 2014 Posted December 26, 2014 i can say some areas around those functions in the log have changed. a new log should be supplied. thanks.
GrumpyBear2014 0 Posted December 27, 2014 Author Posted December 27, 2014 Thanks Luke! New Log attached. theater-63555208999.txt
Luke 42241 Posted December 27, 2014 Posted December 27, 2014 I don't see any problems here. is there still an issue?
GrumpyBear2014 0 Posted December 27, 2014 Author Posted December 27, 2014 Good day Luke Yes, I am still having the same issue with it. Have attached another log file for you to look at. The connection errors to the media server is known as I have them all turned off to do some electrical rewiring in the server room. If it is too messy of a log I will attach another one, once I finish the electrical. Thanks theater-63555235200.txt
mhariush 11 Posted January 6, 2015 Posted January 6, 2015 I am also having the same issue and error message. Version 3.0.5474.26071 Up to date. 1
mhariush 11 Posted January 14, 2015 Posted January 14, 2015 Any updates on this? Installed MTB on my new HTPC and getting the same "cannot be null" message. I need to be able to play my blu's Thanks 1
GrumpyBear2014 0 Posted March 29, 2016 Author Posted March 29, 2016 So I started this thread in December of 2014, and still have not had anybody with any information on how to resolve this.
Luke 42241 Posted March 29, 2016 Posted March 29, 2016 So I started this thread in December of 2014, and still have not had anybody with any information on how to resolve this. Sorry, we spent 2015 working on a new theater app. Now that app is available but it does not yet have optical disc playback, sorry.
