kricker 6 Posted June 8 Posted June 8 I noticed that the universal Android app has grey bars during HRD video playback on Sony TVs. Kodi had a similar issue due to some sort of rendering method on Sony TVs and various other devices. An overlay setting was added to Kodi's advanced settings.xml file that allowed that to be dealt with. Attached are images showing the same HDR content played back on each of the apps on an older yet still highly capable Sony TV.
kricker 6 Posted June 22 Author Posted June 22 Is there any more information needed for this report? This is the main issue keeping me from using the universal version instead of the for AndroidTV version. I just experienced some media playback issues using the old for AndriodTV version. To get around it for a certain video, I had to assign an external player. I'm not sure why the video is having issues with playback in Emby for AndroidTV. It want's to convert the video for some reason even though direct playback of the video does work in other players like NovaPlayer and Kodi. That's a diiferent issue, but would be moot if the OP issues was resolved.
kricker 6 Posted June 22 Author Posted June 22 I originally posted in the Android TV/FireTV section, but it should probably be moved to this section as it is specific to the Android version running on GoogleTV.
Luke 43720 Posted July 29 Posted July 29 Hi, please try again once Emby for Android 3.5.42+ is available. Thanks.
kricker 6 Posted August 9 Author Posted August 9 (edited) I just tried 3.5.42 and I still have gray bars on HDR content Emby displays the video as 4K Dolby Vision HEVC. MediaInfo shows it as HDR10/HDR10+ It plays in Emby ATV without grey bars. Edited August 9 by kricker
Luke 43720 Posted September 3 Posted September 3 Hi, have you tried with the latest update to the Emby Android app? What version number are you on now?
kricker 6 Posted September 3 Author Posted September 3 I just tried 3.5.55 and 3.5.56, and they both still exhibit grey bars on HDR content that does not fill the screen. The same content is fine in the AndroidTV version.
kricker 6 Posted September 29 Author Posted September 29 Tried again tonight with 3.5.63. It is still an issue. This happens with any HDR content that is not at 16:9 aspect ratio. Here are screen shots of the same movie in each: Â
kricker 6 Posted October 5 Author Posted October 5 I just tried 3.5.66, which was the latest build on github. It looks good! I tested a few videos that had problems and they all played with proper black bars on HDR content that is letterboxed. Thank you! Can I ask what was done to make that happen? 1
Solution Luke 43720 Posted October 5 Solution Posted October 5 Hi, I think we had to change which element in the view layer had a background color applied.
kricker 6 Posted October 5 Author Posted October 5 I am glad you could get it worked out. Do you still need me to try .64 and or .65 as well? 1
