ginjaninja 667 Posted June 18 Posted June 18 (edited) good find.. could be this then https://dev.emby.media/reference/pluginapi/MediaBrowser.Controller.Entities.BaseItem.html#MediaBrowser_Controller_Entities_BaseItem_GetInternalMetadataPath and this GetImagePath(BaseItem, ImageType) https://dev.emby.media/reference/pluginapi/MediaBrowser.Controller.Entities.BaseItemExtensions.html edit seems the ai gods agree using System; using System.Collections; using System.Collections.Generic; using System.IO; using System.Linq; using System.Threading; using System.Threading.Tasks; using MediaBrowser.Controller.Entities; using MediaBrowser.Controller.Library; using MediaBrowser.Model.Entities; using MediaBrowser.Model.Logging; using MediaBrowser.Model.Tasks; namespace Emby.PersonPathExporter { public class ExportPersonPathsTask : IScheduledTask { private readonly ILibraryManager _libraryManager; private readonly ILogger _logger; // Emby automatically injects dependencies via the constructor public ExportPersonPathsTask(ILibraryManager libraryManager, ILogManager logManager) { _libraryManager = libraryManager; _logger = logManager.GetLogger(Name); } public string Name => "Export Person Paths and Metadata"; public string Key => "ExportPersonPathsAndMetadataTask"; public string Description => "Logs the InternalMetadataPath and ImagePath for every person in the Emby library."; public string Category => "Maintenance"; public async Task Execute(CancellationToken cancellationToken, IProgress<double> progress) { _logger.Info("Starting Person Path Export task..."); // Query items of type 'Person' recursively across the entire database var query = new InternalItemsQuery { IncludeItemTypes = new[] { Tuple.Create(typeof(Person).Name, false) }, Recursive = true }; var people = _libraryManager.GetItemList(query); if (people == null || people.Length == 0) { _logger.Info("No people found in the library database."); progress.Report(100); return; } int totalCount = people.Length; int currentCount = 0; _logger.Info($"Found {totalCount} people. Iterating and logging paths..."); foreach (var item in people) { cancellationToken.ThrowIfCancellationRequested(); if (item is Person person) { // Extract paths string name = person.Name ?? "Unknown"; string internalMetadataPath = person.InternalMetadataPath ?? "No internal metadata path available"; // Retrieve the primary image path if it exists string imagePath = person.GetImagePath(ImageType.Primary) ?? "No primary image path found"; // Output directly to Emby server's primary logs _logger.Info($"Person: {name} | MetadataPath: {internalMetadataPath} | ImagePath: {imagePath}"); } currentCount++; progress.Report((double)currentCount / totalCount * 100); } _logger.Info("Finished exporting person paths."); await Task.CompletedTask; } public IEnumerable<TaskTriggerInfo> GetDefaultTriggers() { // Provides a template for manual execution, but can be scheduled to run weekly if needed return new[] { new TaskTriggerInfo { Type = TaskTriggerInfo.TriggerManual } }; } } } Edited June 18 by ginjaninja
Smitty018210 205 Posted June 18 Author Posted June 18 (edited) 3 hours ago, Lessaj said: Do you have Emby Data Explorer plugin installed? You can view the people data that way and it might point you in the right direction. EDIT: I noticed some newer people in my server don't have a path mentioned, in the data below there is still mention of where their primary image is stored, so that could still be a data point. I installed this plugin, but I do not see explore item detail option. Edited June 18 by Smitty018210
Lessaj 613 Posted June 18 Posted June 18 Try hard refreshing the web UI, disabling cache with Dev tools, use incognito or another browser. I remember it didn't appear right away, something with cache.
Smitty018210 205 Posted June 18 Author Posted June 18 (edited) 10 minutes ago, Lessaj said: Try hard refreshing the web UI, disabling cache with Dev tools, use incognito or another browser. I remember it didn't appear right away, something with cache. Yeah, work on different browser and in incognito. Thanks for the heads up! Edited June 18 by Smitty018210 1
