PapalPenguin 1 Posted June 6 Posted June 6 I am dealing with issues with a old USB HDD where some MKV files have been having stuttering when playing on my Google TV 4K box. System Info: in My Gaming PC file Intel i5-13400F with 32 GB DDR4 C Drive 1 TB NVME D Drive 4 TB NVME E Drive 1 TB SSD F Drive(where my media is) USB External WD WD50NDZM 5 TB HDD WD MyPassport 260D USB External 5 TB HDD Model WD50NDZM I am looking to get a new HDD as I feel this one might be having issues due to age and the casing has a crack in it sadly. Looking at these two HDD's and wondering which one would be the better option: https://www.amazon.com/dp/B0DW8ZW47C/?coliid=I1XTYFCNVVVQN3&colid=2LCEWMVHVJCO6&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it or https://www.amazon.com/dp/B084ZTSMWF/?coliid=I3D0ZS2HARWF80&colid=2LCEWMVHVJCO6&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it Or is the problem that I am using a HDD instead of a faster SSD? My Gaming PC.LOG
RanmaCanada 596 Posted June 6 Posted June 6 Your drive has bad sectors and is starting to fail. Instead of buying from Amazon I would suggest goharddrive or ServerPartDeals. They both sell refurbished drives with 2-5 year warranties. 12TB with 5 year warranty "only" $320 (they used to be $75 before the AI/Surveillance Centre Apocalypse) 24TB with 5 year warranty for $560 I have personally bought from goharddrive in the past, and lots of users on reddit do as well. If you can come to Canada, you can get drives for cheaper shipped out of the states..24TB external for $660 CDN, or $474 USD.. 1 1
TMCsw 307 Posted June 6 Posted June 6 34 minutes ago, PapalPenguin said: Intel i5-13400F with 32 GB DDR4 It could also be that the "F" in your processor name doesn't support HW acceleration. Software transcoding may also be your problem. Before you buy new equipment, please upload your logs...
PapalPenguin 1 Posted June 6 Author Posted June 6 (edited) 3 minutes ago, TMCsw said: It could also be that the "F" in your processor name doesn't support HW acceleration. Software transcoding may also be your problem. Before you buy new equipment, please upload your logs... Here are my latest logs hardware_detection-63916280929.txt ffmpeg-directstream-38ecaa04-7d0f-4d17-b878-516cd6635bf8_1.txt embyserver (14).txt ffmpeg-transcode-1f0050f6-e3b6-4218-9490-1139d15ca793_1.txt Edited June 6 by PapalPenguin
PapalPenguin 1 Posted June 6 Author Posted June 6 Some logs from when I was noticing problems as it is playing fine right now, note I have a VPN(ProtonVPN) and I have a tunnel setup to go to emby but it shows the ip for the vpn. When I turn off VPN and stop qbittorrent and then restart emby it plays fine, not sure if its the vpn, downloads, etc embyserver (13).txt ffmpeg-transcode-13195652-ad0b-49fe-b74c-d5aea8a61e49_1.txt
PapalPenguin 1 Posted June 6 Author Posted June 6 7 minutes ago, TMCsw said: Radeon RX 9060 XT ?? Are you serious, or just trolling? Serious, its what I was able to afford, i am on ssdi disability
PapalPenguin 1 Posted June 6 Author Posted June 6 10 hours ago, TMCsw said: Radeon RX 9060 XT ?? Are you serious, or just trolling? Also why would I be trolling especially since it is shown in hwinfo64?
Neminem 1957 Posted June 6 Posted June 6 Well this is your issue, your hardware can't hack it, when it needs to transcode. File played : F:\\TV\\The Rookie\\The Rookie Season 2\\The Rookie S02E18 Under the Gun [1080p x265 q22 S85 Joy].mkv Its reverts to software because of you GPU can do what is needed. >>>>>> Processing Plan Name CanDoInHW WillDoInHW Reason DX11VA AMD Radeon RX 9060 XT - H.265 ... >> True True Hardware Codec VideoInput >> False False The sw pipeline builder does not support hw accelera... Scaling >> False False ColorConversion >> False False VideoOutput >> False False Not a hardware encoder x265 >> False False Software Codec >! ThrottleByStreamBufferSize: WARNING - Playback position too close to transcoding position: PlaybackPosition: 00:00:03 - TranscodingPosition: 00:00:06 - ThrottleBuffer: 3s 17:35:48.027 elapsed=00:00:18.85 frame= 181 fps=9.6 q=20.3 q=-1.0 size=N/A time=00:00:07.00 bitrate=N/A throttle=off speed=0.372x 17:35:48.081 elapsed=00:00:22.53 frame= 182 fps=8.1 q=23.7 q=-1.0 size=N/A time=00:00:07.04 bitrate=N/A throttle=off speed=0.313x 17:35:48.688 elapsed=00:00:23.10 frame= 187 fps=8.1 q=24.6 q=-1.0 size=N/A time=00:00:07.25 bitrate=N/A throttle=off speed=0.314x The values marked in RED should be above 1 just to keep up. 1
PapalPenguin 1 Posted June 6 Author Posted June 6 24 minutes ago, Neminem said: Well this is your issue, your hardware can't hack it, when it needs to transcode. File played : F:\\TV\\The Rookie\\The Rookie Season 2\\The Rookie S02E18 Under the Gun [1080p x265 q22 S85 Joy].mkv Its reverts to software because of you GPU can do what is needed. >>>>>> Processing Plan Name CanDoInHW WillDoInHW Reason DX11VA AMD Radeon RX 9060 XT - H.265 ... >> True True Hardware Codec VideoInput >> False False The sw pipeline builder does not support hw accelera... Scaling >> False False ColorConversion >> False False VideoOutput >> False False Not a hardware encoder x265 >> False False Software Codec >! ThrottleByStreamBufferSize: WARNING - Playback position too close to transcoding position: PlaybackPosition: 00:00:03 - TranscodingPosition: 00:00:06 - ThrottleBuffer: 3s 17:35:48.027 elapsed=00:00:18.85 frame= 181 fps=9.6 q=20.3 q=-1.0 size=N/A time=00:00:07.00 bitrate=N/A throttle=off speed=0.372x 17:35:48.081 elapsed=00:00:22.53 frame= 182 fps=8.1 q=23.7 q=-1.0 size=N/A time=00:00:07.04 bitrate=N/A throttle=off speed=0.313x 17:35:48.688 elapsed=00:00:23.10 frame= 187 fps=8.1 q=24.6 q=-1.0 size=N/A time=00:00:07.25 bitrate=N/A throttle=off speed=0.314x The values marked in RED should be above 1 just to keep up. Whats wrong with the GPU I have? Its been decent for my gaming needs, why cant it work with hw acceleration?
visproduction 375 Posted June 6 Posted June 6 Graphics card specs looks OK. Maybe some transcoding setting could be better? https://gpu.userbenchmark.com/Compare/AMD-RX-9060-XT-vs-Nvidia-RTX-5070-Ti/m2417253vs4181
PapalPenguin 1 Posted June 6 Author Posted June 6 5 minutes ago, visproduction said: Graphics card specs looks OK. Maybe some transcoding setting could be better? https://gpu.userbenchmark.com/Compare/AMD-RX-9060-XT-vs-Nvidia-RTX-5070-Ti/m2417253vs4181 I might have figured it out, when I had it set to Advanced it was really poor, but set to Yes, it seems ok so far. I do plan to invest in a newer hdd maybe a internal 12 tb or larger to expand my storage.
Neminem 1957 Posted June 6 Posted June 6 (edited) 2 hours ago, PapalPenguin said: might have figured it out, when I had it set to Advanced it was really poor, but set to Yes, it seems ok so far. That would mean you have messed with the advanced settings Did you read what I wrote? Happy you got it working with your setup. Edited June 6 by Neminem
PapalPenguin 1 Posted June 6 Author Posted June 6 1 hour ago, Neminem said: That would mean you have messed with the advanced settings Did you read what I wrote? Happy you got it working with your setup. Yes I am not sure how to setup Advanced Settings, but setting it as Yes seems to be working just fine as videos are streaming smoothly.
PapalPenguin 1 Posted June 7 Author Posted June 7 I also noticed my troubles went away when I wasn't downloading torrents directly to my external drive, which I figured out was a SMR Drive, which plays a role, so I setup qbittorrent to download directly to my nvme drive and upon completion it moves the files to the external which reduces the amount of drive activity causing less struggles, I do plan to buy a 22 TB Internal HDD from GoHardDrives to expand my storage and eventually be the sole location for media, although I might just put new stuff on it and leave the usb as is until I can transfer it over to the new drive. But this seems to be working fine now as long as I keep the activity lower on the usb drive 1
Neminem 1957 Posted June 7 Posted June 7 Yes I/O can be a real problem, if you do that on a 1000/1000 connection. Then the USB interfaces transfer limit would be used by you download habit's. But none of this was disclosed to helpful users, trying to help you.
