GrimEvil 113 Posted June 5 Posted June 5 Hi, I have an issue with my Live TV setup. I use a HD Homerun/m3u8, Example below of the layout of a channel from a standard m3u. #EXTM3U x-tvg-url="http://*.*.*.*:****/epg" url-tvg="http://*.*.*.*:****/output/epg" #EXTINF:-1 tvg-id="101" tvg-name="BBC One HD" tvg-logo="http://*.*.*.*:****/api/channels/logos/3870/cache/" tvg-chno="101" group-title="Sky: Entertainment",BBC One HD http://*.*.*.*:****/proxy/ts/stream/5253535 This works fine but I do not see the Tag/Group in the Emby guide, all it shows just shows "All" I would expect emby to use group-title="Sky: Entertainment" or any of the other one's I set for Group-title. Currently I have to use the bulk plugin to fix this issue manually, as per below Is there any reason why this does not work as expected and auto import the tag/group from the m3u/HD homerun?
Luke 43719 Posted June 10 Posted June 10 Hi, if you just edited the m3u then try running the guide refresh. Also make sure you haven't locked the tags in the metadata editor for the channel.
GrimEvil 113 Posted June 11 Author Posted June 11 (edited) @Luke No it never creates them for the guide, no mater what I try, I have do the manual setup as Emby does not automatically create them from my m3u/homerun. Edited June 11 by GrimEvil
Luke 43719 Posted June 11 Posted June 11 OK. Also make sure you haven't locked the tags in the metadata editor for the channel.
