One2Go 129 Posted June 2 Posted June 2 (edited) My setup is a Roku Ultra version SG 4.1.63 and is connected to Dennon AVR-4311C1.Today for the first time I noticed that a MKV Movie with a DTS-HD MA 7.1 audio track did not produce any audio and the Dennon AVR just showed the default stereo lights but no sound came out. The very same Roku passes ALL other audio formats. DD, DTS, DTS-HD MA 5.1 TrueHD 7.1 to the AVR. After searching this forum I couldn't find an answer, is there a setting in the Emby app to play from the DTS-HD MA 7.1 audio the DTS-HD MA 5.1 as that works flawless. Playing the same file to a Roku TCL TV which just has stereo speakers Emby does trancode it to two channels. The Roku volume mode is OFF. My Google Chromecast (AndroidTv 2.1.23g) played the very same file flawless but it was connected to a different HDMI input on the AVR. I plugged the Roku into that input but nothing changed still no audio. So I think that the problem must be in the Roku as the Denon AVR-4311 should automatically fold down 7.1 content to a 5.1 layout by default. Here is the weird part a few years ago a different movie but also with a DTS-HD MA 7.1 audio track played just fine. I am not sure if it was the same device or if it was a software update to this device that crewed things up. Thanks for any help and it may be a reason to convince the wife to let me buy an NVIDIA Shield PS: I think I just found the answer: "Roku devices do not support lossless DTS-HD MA 7.1 (Master Audio) passthrough. When playing files with this format, the Roku will either produce no sound, crash, or reboot. So are there any settings that can force a transcode just on the DTS-HD MA 7.1? Edited June 2 by One2Go
ebr 17032 Posted June 2 Posted June 2 8 hours ago, Luke said: Hi, does it play dts-hd 5.1? Yes, he said that in the post. One - Have you changed any of the transcoding options for this user?
One2Go 129 Posted June 2 Author Posted June 2 I have not touched anything regarding any settings including transcoding. Where do you find the transcoding options per user? I only have entries in the server and there for H.264 it is set to "Enabled Hardware acceleration" nothing else has been touched as transcoding worked when the device could not play either the video or the audio. When I tried to change the audio settings in the Roku Emby App it said go to the Web App. I only see in the server settings an Audio entry. Where can I find the Web App for the Roku Emby App or is the server the place where to look? When using a TCL Roku TV with just the inbuilt speakers having the same version SG 4.1.63 the DTS-HD MA 7.1 is transcoded to (AC3 384 kbps)
One2Go 129 Posted June 2 Author Posted June 2 (edited) I found the per user settings in FireFox and I presume (Local IP Address/:8096) Below are the screenshots for the User preference and the server transcoding settings. User preference Server Transcoding Edited June 2 by One2Go
speechles 2130 Posted June 2 Posted June 2 (edited) @One2GoOh no. That isn't supposed to happen. If you don't change something we don't arbitrarily force setting changes upon you when the app updates. But our friends at Roku might when the Roku firmware updates. They could change your audio settings and reset everything. That might be what is happening. On your Roku do you have Custom checked or Auto? You might want to select Custom and then Choose Dolby Digital and turn DTS to ON. The Roku audio settings are passed through to the Emby Roku app. The Emby Roku app uses these to build a capabilities profile. If you set those to Auto and depending on the order of the HDMI devices and which is turned on first the Roku may not understand correctly. With Auto it can incorrectly determine you have no support for pass-through at all. Or it might be simply that DTS isn't turned on. But it might also be the recent Roku firmware update which changed how AAC was passed. Before the Roku would assume it could decode AAC 5.1 even if it was converting it to stereo. Now the Roku reports it only has support for AAC 2.0 when it can support AAC 5.1 but convert to stereo. We will probably have an option in the Emby Roku app to handle this so you can still get AAC 5.1 to direct play in stereo. That same firmware change affects the audio. DTS-HD MA was never going to work with Roku using 7.1 channels. It had to passthrough the DTS core with 5.1. But it reported it could decode the full 8 channel DTS-HD MA even though it couldn't. But this might have changed if you turn on DTS and it still doesn't work for you. Once you change audio settings on your Roku you must RESTART the Roku for it to have any affect. Remember this. If Roku did change the DTS to now report a maximum of 6 channel support we could likely make a setting to fix it. Otherwise there will be needless transcoding when the device is fully capable of passing through the DTS core. I am hoping you are simply using Auto and need to change that to Custom and then enable DTS. Hopefully that is all this is. Please tell us what happens when you try. I haven't fully tested this myself. I was on other things and such. If you can try and after enabling DTS and restart the Roku it still doesn't work we will need to dig deeper. Let us know what you find. Thanks. If an ffmpeg log is created seeing that would confirm the suspicion. Edited June 2 by speechles 1
ebr 17032 Posted June 2 Posted June 2 6 hours ago, One2Go said: Where do you find the transcoding options per user
One2Go 129 Posted June 2 Author Posted June 2 Thank you for your lengthy and excellent comment. I did what you suggested and changed from auto to custom in the streaming output and turned DTS to ON. I did not play back the DTS-HAD MA 7.1 but still showed the 2 stereo lights on the Denon AVR-4311. I did some further testing and the DTS-HD MA 5.1 audio was actually transcoded to DD 5.1 on the Roku. However a plain DTS 5.1 was passed through as DTS. On the Chromcast the DTS-HD MA 7.1 was also transcoded. I try to fix this but understand that the Roku is somewhat not very flexible and accommodating. The OLD Nvidia Shield looks more and more like an option.
One2Go 129 Posted June 2 Author Posted June 2 @ebr That is exactly what the settings of this user look like all enabled.
One2Go 129 Posted June 2 Author Posted June 2 (edited) I just realized that none of my streamers are passing through DTS-HD MA, so I decided screw it I get an Nvidea Shield Pro which does upscaling passing through of DTS-HD MA plus I can hook up a keyboard and don't have to futz around with some no name browsers for the device. In addition the apps only screen is desirable in view of the shitification of Google and Roku's home screens. I will help with solving this problem it needed to. Edited June 2 by One2Go
speechles 2130 Posted June 2 Posted June 2 (edited) 1 hour ago, One2Go said: I did some further testing and the DTS-HD MA 5.1 audio was actually transcoded to DD 5.1 on the Roku. However a plain DTS 5.1 was passed through as DTS. On the Chromcast the DTS-HD MA 7.1 was also transcoded. That is to be expected. DTS cannot be repackaged into HLS. So once you cannot direct play it has to use HLS. It notices this was a surround sound codec using pass-through and has the only choice left using DD 5.1. If you had no pass-through support it would've immediately chosen to transcode to stereo AAC. 14 minutes ago, One2Go said: I just realized that none of my streamers are passing through DTS-HD MA, so I decided screw it I get an Nvidea Shield Pro which does upscaling passing through of DTS-HD MA plus I can hook up a keyboard and don't have to futz around with some no name browsers for the device. In addition the apps only screen is desirable in view of the shitification of Google and Roku's home screens. I will help with solving this problem it needed to. If you notice it is transcoding audio you can just post your ffmpeg log. It will show what is happening. One with DTS-HD MA not working correctly. That would be enough. Thanks. Edited June 2 by speechles
One2Go 129 Posted June 3 Author Posted June 3 Here are 3 logs two of them DTS-HD MA 5.1 the same movie and 1 DTS-HD MA 7.1. Thanks for the help. ffmpeg-remux-e12d3954-eb32-4f96-aa1d- 319e741558a2_1 (DTS-HD MA 7.1).txt ffmpeg-transcode-03b7a423-ceb1-4cce-bb7c-dd008409145f_1 (DTS-HD MA 5.1.txt ffmpeg-transcode-8f25e5c7-7587-4f3b-8cbe-aa57cfca2208_1 (DTS-HD MA 5.1).txt ffmpeg-transcode-03b7a423-ceb1-4cce-bb7c-dd008409145f_1 (DTS-HD MA 5.1.txt
speechles 2130 Posted June 3 Posted June 3 (edited) All of these on the Roku show the same cause. The container is MKV which the Roku can direct play. But the video stream is VC1 which the Roku cannot. This causes the below condition to happen. The video is transcoded into h264 and since DTS cannot be muxed into HLS it becomes AC3 to keep the surround sound since AC3 is found to be supported. Bourne Identity, The (2002) -> Video:VC1, Audio:DTS -> TranscodeReasons=VideoCodecNotSupported -> Video:H264, Audio:AC3 The very top log you post shows from Android TV. That one detects support for DTS. The Roku logs you posted do not show support for DTS on your Roku. Are you sure you enabled DTS in the audio settings and then rebooted/restarted the Roku after making the change? Roku shows this: (missing DTS support?!) AudioCodec=ac3,aac,mp2,mp3,eac3,flac,vorbis,lpcm While Android TV shows this: (has DTS support) AudioCodec=aac_latm,mp4a_latm,ac3,eac3,dts,dca,dtshd,aac,mp3 Edited June 3 by speechles
One2Go 129 Posted June 3 Author Posted June 3 I did first setting the digital output to auto and I believe that are the logs I posted. I will now set the digital output to custom and the DD is already set and will change DTS from OFF to ON. Will run the same too files Bourne Identity eith DTS-HD MA 5.1 and Zootopia 2 with DTS-HD MA 7.1 and will post those 2 ffmped logs.
One2Go 129 Posted June 3 Author Posted June 3 (edited) Here we go: I changed the digiral options to DD Plus and the DTS set to ON. Restarted the Roku device and these are the results. 1.. Bourne Identity (DTS-HD MA 5.1) Played flawless because of transcoding and attached is the log. 2. Zootopia 2 (DTS-HD MA 7.1) NO ffmpeg log because it was a direct play look and the screenshot was from the Emby server. Video played but no audio at all. Didn't think the Roku had the DTS-HD MA codecs. 3. Constant Gardener (DTS 5.1) again NO ffmpeg log and it played flawless the video and audio. ffmpeg-transcode-51117f7b-4d06-4a8b-9524-7dc1ee312ba6_1 (DTS-HD MA 5.1).txt Edited June 3 by One2Go
ebr 17032 Posted June 3 Posted June 3 2 hours ago, One2Go said: Zootopia 2 (DTS-HD MA 7.1) NO ffmpeg log because it was a direct play look and the screenshot was from the Emby server. Video played but no audio at all. Didn't think the Roku had the DTS-HD MA codecs. Please repeat this test and follow the instructions to send a log from the app right after. Thanks.
speechles 2130 Posted June 4 Posted June 4 6 hours ago, One2Go said: 2. Zootopia 2 (DTS-HD MA 7.1) NO ffmpeg log because it was a direct play look and the screenshot was from the Emby server. Video played but no audio at all. Didn't think the Roku had the DTS-HD MA codecs. It direct plays from shown on the dashboard. Video plays fine but no audio. This really does suggest that either the DTS core isn't being passed through from the Roku anymore or that your equipment cannot decode DTS. Please send an app log since this is direct playing. That is the best way to see what is going on with the app behavior. Thanks. @ebrDo you have something that can play DTS? If you have something with DTS HD-MA and disable audio transcoding do you hear silence? Maybe it is something with a recent Roku firmware update causing issue with passing through the DTS core from the DTS-HD MA. The Roku is reporting support for 8 channel DTS when I enable DTS but I cannot hear it since I have nothing that supports it. If you have something capable of hearing DTS HD-MA you can check if the DTS core is still passing through directly or if you hear nothing but silence.
One2Go 129 Posted June 4 Author Posted June 4 (edited) NVidea Shield TV Pro arrived today all the DTS-HD MA 5.1 & 7.1 play directly without transcoding and the Denon AVR 4311 display shows DTS HD Master. So all the devices after the Roku are just fine. Plain Vanilla DTS plays just fine on the Roku it is just the DTS-HD MA that doesn't work. 5.1 is being transcoded and 7.1 does a bogus direct play and the display of the Denon AVR just shows 2 little round lights which I believe indicate no audio because if there is audio you have 2 square block with the letters L and R in them for stereo and 6 square blocks for 5.1. I believe the Roku either doesn't send any audio or has crashed. So, I enabled debugging on the Emby Roku App and also on the server settings. The only log that I get is the embyserver.txt which is attached.. The Shield will replace the Roku and even though 6 years old there is no streamer that can touch this device. Hope you get this sorted with the Roku. embyserver.txt Edited June 4 by One2Go
ebr 17032 Posted June 4 Posted June 4 8 hours ago, One2Go said: So, I enabled debugging on the Emby Roku App and also on the server settings. The only log that I get is the embyserver.txt which is attached.. Please follow the instructions to send a log from the app
rotational467 45 Posted June 4 Posted June 4 (edited) @One2Go- If you ripped these yourself, did you remove the DTS core when doing the rip? MakeMKV for example will allow you to strip the DTS core and get only the DTS-MA track. I made this error with a few early rips. That may explain the silence + lack of any errors. Check the info on one of these files, it should show a second DTS 5.1 audio track along with the DTS-MA. I just tested with my rip of Edge of Tomorrow and it properly passed the DTS core - Roku Ultra to a Denon AVR-1910 with a 5.1 setup. Roku preferred streaming format is Auto and Digital output format is Passthrough. Edited June 4 by rotational467
One2Go 129 Posted June 4 Author Posted June 4 (edited) No I didn't rip these myself. A Roku can't pass through DTS-HD MA. With the 7.1 movie it pretended to play direct but no audio input was displayed at the AVR. with the 5.1 Emby realized it needed transcoding. This is clearly a problem with the Roku why would DTS-HD MA 5.1 be transcoded but DTS-HD MA 7.1 is a direct play. Makes no sense. The DTS core is not a separate audio track. It is natively embedded directly inside the DTS-HD Master Audio. So Roku is not extracting this one. What is your software version of the Roku Ultra? 1. Played the movie Zootopia 2 which had a DTS-HD MA 7.1 audio track and no sound could be heard. 2. I repeated the test at 7:40pm EST and sent the log. 3. Local user Hans I am so done with the Roku and there is not a single feature, program or event which the Shield doesn't have or is not superior to. Edited June 5 by One2Go
speechles 2130 Posted June 5 Posted June 5 (edited) 1 hour ago, One2Go said: No I didn't rip these myself. A Roku can't pass through DTS-HD MA. There is a DTS "core" that should be discoverable inside the DTS-HD MA stream. That "core" stream within the DTS-HD MA is what the Roku should be passing through. You should not have to add both DTS-HD MA 7.1 and DTS 5.1 streams. Both streams contain the same "core" that Roku should be able to direct play. Having just DTS-HD MA 7.1 should passthrough as DTS 5.1 with direct play. https://en.wikipedia.org/wiki/DTS-HD_Master_Audio Quote DTS-HD Master Audio (DTS-HD MA; known as DTS++ before 2004[1]) is a multi-channel, lossless audio codec developed by DTS as an extension of the lossy DTS Coherent Acoustics codec (DTS CA; usually itself referred to as just DTS). Rather than being an entirely new coding mechanism, DTS-HD MA encodes an audio master in lossy DTS first, then stores a concurrent stream of supplementary data representing whatever the DTS encoder discarded. This gives DTS-HD MA a lossy "core" able to be played back by devices that cannot decode the more complex lossless audio. DTS-HD MA's primary application is audio storage and playback for Blu-ray media; it competes in this respect with Dolby TrueHD, another lossless surround format. Now the fact you say, that you are doing this and still getting silence means either: 1) Your equipment cannot decode the core DTS stream. Which you said another DTS in 5.1 passed through just fine. So this cannot be the reason if that is true. 2) The Roku has a firmware bug where the DTS-HD MA stream is no longer being passed-through. Which is odd because the Roku reports 8 channel support for DTS. This is why above @ebrhas asked for you to send logs from that Roku device. Server logs will not show what is happening with Direct Play. We would need to see how the Roku decided to play this back and that is only discoverable within the logs the Roku app will keep when you turn on debug mode. Now that you've provided app logs we will find out... I can only suspect that Roku has a firmware bug. Seeing your logs would confirm it. Then we can add a setting or something to work-around that firmware bug if that is what this is. Thanks. Edited June 5 by speechles
One2Go 129 Posted June 5 Author Posted June 5 @speechles thanks for the follow up and any video that has the plain vanilla DTS 5.1 the Roku passes it on and the AVR displays DTS 5.1. I have one video with a TrueHD 7.1 audio track and it gets transcoded.to DD. Still don't get it why the DTS-HD MA 5.1 gets flaged for transcoding and the DTS-HD MA 7.1 does not. I am looking at a very positive side without this incident I never gad a reason to buy an Nvidea Shield. Plus with the shitification of both the Google and Roku home screens the 2019 Shield has an option to get rid of it.
ebr 17032 Posted June 5 Posted June 5 13 hours ago, One2Go said: I repeated the test at 7:40pm EST and sent the log. There is no playback in your log. Looks like maybe you restarted the app before sending the log. 13 hours ago, rotational467 said: did you remove the DTS core when doing the rip? This would be a very plausible explanation of what is happening.
pünktchen 1426 Posted June 5 Posted June 5 14 hours ago, rotational467 said: If you ripped these yourself, did you remove the DTS core when doing the rip? MakeMKV for example will allow you to strip the DTS core and get only the DTS-MA track. The DTS Core is usually embedded within the lossless DTS HD-MA track, so it cannot be "deleted" without re-encoding the audio. Most Blu-rays have a seperate DTS only track, that's what you can deselect within MakeMKV.
