Bearobms
When I start emby it goes straight to this screen.  I have put i IP addresses for my Nas devices, my router, my server and it always says cannot connect to this device.  My server's name is LAPTOP.I recall a screen that said server not connected. I don't remember if it was in emby or some other program.image.jpeg.83b7450566813b39c9bcecaad30a298f.jpeg
alex77777
Are you on your local network or are you trying to access the server remotely? If you are on your local network, ensure Emby Server is running on LAPTOP. You should be typing in the IP address of the whatever device has Emby Server running.  I would recommend setting a static IP address for the device so it doesn't change.
  • Agree 1
legierk
Tuesday's Windows update changed my server network from private to public. YMMV.
Bearobms
Where in windows did you do this?
Windows network settings.
Bearobms
I can't find it. I cannot find how to share my computer on the network.
Neminem
  • Like 1
  • Thanks 1
