Cat091 2 Posted May 28 Posted May 28 A few weeks backs I found a fix for 7.6 and higher end bit rate movies on the google tv. For the Sony series tv the ethernet has a limit for 100 mbps max sometimes it refuses to play anything above 80. Similar for LG. The fix is to use wireless. Shocked I know most people say buy a nvdia shield or some android box and they are wrong. You also sometimes need to use kodi, if the video does not play.
Luke 43680 Posted June 11 Posted June 11 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
