Gilgamesh_48 1259 Posted May 26 Posted May 26 (edited) 19 minutes ago, Nanciig88 said: I’m just trying to connect to my server I don’t know how I am quite sure that the experts here will need things like a detailed description of your setup. What clients you are trying to use. How your server is set up. If you are on the same network as your server and, probably, many other things. Trying to diagnose a problem with such a flimsy description is next to impossible and will lead some people to believe that you are trying to connect to a server that someone has, in violation of Emby's TOS, sold access to. Just be as complete as possible in your description of your setup and what exactly you have tried and are trying and, maybe, even server logs from when you tried to connect and much help will be available. Edited May 26 by Gilgamesh_48
Deb04 0 Posted May 26 Posted May 26 So I downloaded the app from the Microsoft Store and installed it, but when I open the app, there I need the enter the host. Where do I find that?
pwhodges 2132 Posted May 26 Posted May 26 You download the server software, install it, and then provide a library with the media files you want it to be able to play. Details here: https://emby.media/support/articles/Quick-Start.html Note the paragraph in larger type. Paul
