ZAIAC001 6 Posted May 20 Posted May 20 Pls, help me figure out what wrong TV show - devil may cry from netflix https://www.themoviedb.org/tv/235930-devil-may-cry Meta source - tmdb Added TV show to media library Start library update and it not recognized And some errors appear in logs What should I do? Manual linkage via tmdb not work too Other TV shows work fine and meta appear Problem only with that tv show for now embyserver.txt
ZAIAC001 6 Posted May 20 Author Posted May 20 Found temp solution: In folder name replaced spaces with "_" Meta succesfully gathered Again spaces not work only for that tv show Many other (more than 100) also contains spaces but work fine Checked logs for api url and tested it manually Somehow api token replaces with charencode string So api fetch not work Idk what so especial on that tv show Folder structure as usual And I replace spaces only in root tv show folder (episodes still contains spaces) Devil_May_Cry │ ├── Season 1 │ │ ├── Devil May Cry S1E01.mkv │ │ ├── Devil May Cry S1E02.mkv │ │ ├── Devil May Cry S1E03.mkv │ │ ├── Devil May Cry S1E04.mkv │ │ ├── Devil May Cry S1E05.mkv │ │ ├── Devil May Cry S1E06.mkv │ │ ├── Devil May Cry S1E07.mkv │ │ └── Devil May Cry S1E08.mkv
Vidmo232 11 Posted May 20 Posted May 20 There seems to be an issue with the Emby TMDB API key right now, stay tuned.
ZAIAC001 6 Posted May 20 Author Posted May 20 12 minutes ago, Vidmo232 said: There seems to be an issue with the Emby TMDB API key right now, stay tuned. Key issue brokes all api requests usually But there only one tv show broken
Solution Vidmo232 11 Posted May 20 Solution Posted May 20 Looks like the root cause was an issue at TMDB itself, but it did not affect all of their data, only some. It's slowing coming back online. API returning corrupted data instead of JSON - Talk — The Movie Database (TMDB) 1
