baileyby 2 Posted May 7 Posted May 7 Just an additional heads up that all AAC 6 channel files suddenly stopped working for me as well (movies wouldn't even start). Like you, I've been playing these movies for years with the same tv, roku stick, server, etc. The only thing that may have changed is auto updates to emby server, emby client, or roku. Once I went into Roku and forced everything to Dolby/stereo, everything's working okay again (which is fine as I'm just playing through this TV). Attaching the relevant debug data from embyserver.txt. I'm back up and running sufficiently, but hoping it helps gives some clues for the problem threnos is hitting. 2026-05-06 22:00:01.932 Debug EncodingManager: KillTranscodingJob - JobId cf20eb47-db09-43c2-b366-1588c9027849 PlaySessionId 143fb49421974b878b976ca5d73e23b7. Killing transcoding 2026-05-06 22:00:01.932 Error DynamicHlsService-0HNKV6226T45R:00000001: Error processing request *** Error Report *** Version: 4.9.3.0 Command line: C:\Users\Byron\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19045 OS/Process: x64/x64 Framework: .NET 8.0.22 Runtime: C:/Users/Byron/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Data path: C:\Users\Byron\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\Byron\AppData\Roaming\Emby-Server\system Emby.Server.MediaEncoding.Unified.Ffmpeg.FfRunException: Emby.Server.MediaEncoding.Unified.Ffmpeg.FfRunException: Error starting ffmpeg -loglevel +timing -y -print_graphs_file "C:\Users\Byron\AppData\Roaming\Emby-Server\programdata\logs\ffmpeg-transcode-cf20eb47-db09-43c2-b366-1588c9027849_1graph.txt" -copyts -start_at_zero -f mp4 -c:v:0 h264 -noautorotate -i "H:\Movies\Ocean's Eleven (2001)\Ocean's Eleven (2001).m4v" -map 0:0 -map 0:1 -sn -c:v:0 libx264 -g:v:0 90 -maxrate:v:0 1866630 -bufsize:v:0 3733260 -sc_threshold:v:0 0 -keyint_min:v:0 90 -r:v:0 29.970029830932617 -pix_fmt:v:0 yuv420p -preset:v:0 veryfast -profile:v:0 high -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 ac3 -ab:a:0 384000 -ar:a:0 48000 -ac:a:0 6 -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "C:\Users\Byron\AppData\Roaming\Emby-Server\programdata\transcoding-temp\D95AD5\D95AD5.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "C:\Users\Byron\AppData\Roaming\Emby-Server\programdata\transcoding-temp\D95AD5\D95AD5_%d.ts" 22:00:01.836 ffmpeg version 5.1-emby_2023_06_25_p4 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC 22:00:01.836 built with gcc 12.2.0 (Rev10, Built by MSYS2 project) 22:00:01.836 Execution Date: 2026-05-06 22:00:01 22:00:01.891 Guessed Channel Layout for Input Stream #0.1 : 5.1 22:00:01.891 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'H:\Movies\Ocean's Eleven (2001)\Ocean's Eleven (2001).m4v': 22:00:01.891 Metadata: 22:00:01.891 major_brand : M4V 22:00:01.891 minor_version : 512 22:00:01.891 compatible_brands: M4V isomiso2avc1 22:00:01.891 encoder : Lavf59.27.100 22:00:01.891 Duration: 01:56:34.66, start: 0.000000, bitrate: 1025 kb/s 22:00:01.891 Stream #0:0[0x1](und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(progressive), 720x480 [SAR 32:27 DAR 16:9], 622 kb/s, Level 30, 29.97 fps, 29.97 tbr, 30k tbn (default) 22:00:01.892 Metadata: 22:00:01.892 handler_name : VideoHandler 22:00:01.892 vendor_id : [0][0][0][0] 22:00:01.892 Stream #0:1[0x2](und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 394 kb/s (default) 22:00:01.892 Metadata: 22:00:01.892 handler_name : SoundHandler 22:00:01.892 vendor_id : [0][0][0][0] 22:00:01.898 Stream mapping: 22:00:01.898 Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) 22:00:01.898 Stream #0:1 -> #0:1 (aac (native) -> ac3 (native)) 22:00:01.898 Press [q] to stop, [?] for help 22:00:01.903 [Parsed_anull_0 @ 0000017181eeff00] Channel layout change is not supported 22:00:01.903 Error while filtering: Not yet implemented in FFmpeg, patches welcome 22:00:01.903 Failed to inject frame into filter network: Not yet implemented in FFmpeg, patches welcome 22:00:01.903 Error while processing the decoded data for stream #0:1 22:00:01.908 Conversion failed! 22:00:01.908 EXIT
speechles 2130 Posted May 7 Posted May 7 (edited) 6-Channel Bug: FFmpeg can create an incorrect 6-channel layout (L R C Cb Lb Rb) rather than standard 5.1 (C L R Ls Rs LFE). Quote 22:00:01.891 Guessed Channel Layout for Input Stream #0.1 : 5.1 It looks like the "-ac 6" was removed from the ffmpeg parameters? @softworkz -ac:a:0 6 I mean it is in there. But before this was just "-ac 6". Seeing the "Guessed Channel Layout" makes me believe it cannot understand the channel count. Edited May 7 by speechles
Luke 43550 Posted May 11 Posted May 11 @baileybyplease attach the complete emby server and ffmpeg log files. Thanks !
