MikeyMan 8 Posted May 7 Posted May 7 The trakt settings have been moved to the personal/profile settings. But over there i only see the on/off toggle. Are there other settings somewhere?
MikeyMan 8 Posted May 10 Author Posted May 10 (edited) Ah, under media settings. Found it, but seems it was already set correctly. Nothing happening on trakt side though it seems... Trakt says there was connection. But nothing played it seems... Emby Emby for Trakt Connected on May 10, 2026 8:08 PM Edited May 10 by MikeyMan
Luke 43675 Posted May 17 Posted May 17 On 5/10/2026 at 2:07 PM, MikeyMan said: Ah, under media settings. Found it, but seems it was already set correctly. Nothing happening on trakt side though it seems... Trakt says there was connection. But nothing played it seems... Emby Emby for Trakt Connected on May 10, 2026 8:08 PM @MikeyMan HI there, can you please provide a specific example? How to Report a Problem Thanks !
