vincen 89 Posted April 29 Posted April 29 Hi Since I use Emby (around a little more than 2 years now), I have always had that issue with Android users. They often don't disconnect/finish properly stream sessions and so I have a bunch of ghost sessions that stay there forever Only way to get rid of them is to restart Emby server..... as they don't show any stop buttons like sessions that are running and not hanging. Is it planned to get that issue fixed ? as it's there since at least 2 years (happen a lot more with devices like Chromecast but happens also with regular android clients). Thanks Vincèn
kikinjo 326 Posted April 29 Posted April 29 This was never fixed, in latest android unified app 95% of clients are non stop ghosts but now with bonus feature, now you don't have controls at all (stop pause, etc..) Look at it as "new feature" /s 1
vincen 89 Posted April 29 Author Posted April 29 2 hours ago, kikinjo said: This was never fixed, in latest android unified app 95% of clients are non stop ghosts but now with bonus feature, now you don't have controls at all (stop pause, etc..) Look at it as "new feature" oki so will have to live with it for a long time yet
yocker 2045 Posted April 29 Posted April 29 You can use this plugin i had an AI make me back when i had the same problems. Added the code as well in case people want to go through the code it made. SessionKiller.dll SessionKiller.zip
Luke 43395 Posted May 2 Posted May 2 On 4/29/2026 at 3:16 AM, vincen said: Hi Since I use Emby (around a little more than 2 years now), I have always had that issue with Android users. They often don't disconnect/finish properly stream sessions and so I have a bunch of ghost sessions that stay there forever Only way to get rid of them is to restart Emby server..... as they don't show any stop buttons like sessions that are running and not hanging. Is it planned to get that issue fixed ? as it's there since at least 2 years (happen a lot more with devices like Chromecast but happens also with regular android clients). Thanks Vincèn Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
vincen 89 Posted May 2 Author Posted May 2 6 hours ago, Luke said: Hi there, please attach the Emby server log from when the problem occurred: @Luke thanks but already posted in past and problem was not fixed and not posting anymore in all matters any logs here for confidentiality reasons..
vincen 89 Posted May 2 Author Posted May 2 On 4/29/2026 at 3:29 PM, yocker said: You can use this plugin i had an AI make me back when i had the same problems. Added the code as well in case people want to go through the code it made. SessionKiller.dll 13 kB · 1 download SessionKiller.zip 65.44 kB · 2 downloads Thanks for the share @yockerunhappy I'm unable to check the source code so can't use the plugin (sorry but 0 faith in AI stuffs 1
Neminem 1957 Posted May 2 Posted May 2 (edited) 1 hour ago, vincen said: unhappy I'm unable to check the source code so can't use the plugin Well run the source code through AI to find any bugs, thats called AI checking AI here har a list of most of his plugins, I have helped test most of them. yocksers (yock) / Repositories Edited May 2 by Neminem 1
yocker 2045 Posted May 2 Posted May 2 (edited) 1 hour ago, vincen said: Thanks for the share @yockerunhappy I'm unable to check the source code so can't use the plugin (sorry but 0 faith in AI stuffs Understandable. I just couldn't be bothered doing anything my self as i have enough to do with my other plugins. Edited May 2 by yocker 1
vincen 89 Posted May 2 Author Posted May 2 3 hours ago, yocker said: Understandable. I just couldn't be bothered doing anything my self as i have enough to do with my other plugins. so I copied the file with your other very nice plugin Embyicons. Embyicons shows up well, I could install it and it now works perfect but the SessionKiller one not Is it still compatible with current Emby server version ? (4.9.3.0)
yocker 2045 Posted May 2 Posted May 2 (edited) 1 hour ago, vincen said: so I copied the file with your other very nice plugin Embyicons. Embyicons shows up well, I could install it and it now works perfect but the SessionKiller one not Is it still compatible with current Emby server version ? (4.9.3.0) I will go through the code that the AI made and see if i can see the problem. In case you missed it, it doesn't have any image or anything as it was as said just AI and all it was asked was make a plugin to kill idle sessions. Also if for the Windows version of Emby then the plugin should be placed in programdata\plugins and not system\plugins. Edited May 2 by yocker
vincen 89 Posted May 2 Author Posted May 2 39 minutes ago, yocker said: In case you missed it, it doesn't have any image or anything as it was as said just AI and all it was asked was make a plugin to kill idle sessions. Also if for the Windows version of Emby then the plugin should be placed in programdata\plugins and not system\plugins. Thanks for the detail but yeah I confirm it doesn't show up at all in the Plugin library on my server. I'm on Linux and I putted it not in the system but where all files created by emby are and where I putted the EmbyIcons one but found out it had wrong rights on file sorry for that I'll try again later when I can restart Emby server to check if it shows up and will let you know 1
yocker 2045 Posted May 2 Posted May 2 7 minutes ago, vincen said: Thanks for the detail but yeah I confirm it doesn't show up at all in the Plugin library on my server. I'm on Linux and I putted it not in the system but where all files created by emby are and where I putted the EmbyIcons one but found out it had wrong rights on file sorry for that I'll try again later when I can restart Emby server to check if it shows up and will let you know No need to apologize. Just AI generated anyway because i was too lazy. Maybe if i wasn't so lazy... 1
vincen 89 Posted May 3 Author Posted May 3 10 hours ago, yocker said: No need to apologize. Just AI generated anyway because i was too lazy. Maybe if i wasn't so lazy... I restarted the Emby server and still it doesn't show up in any categories of plugins It showed up straight in installed plugins so it looks all good now, will see if I have less hanging sessions now, will keep you updated !
yocker 2045 Posted May 3 Posted May 3 3 hours ago, vincen said: I restarted the Emby server and still it doesn't show up in any categories of plugins It showed up straight in installed plugins so it looks all good now, will see if I have less hanging sessions now, will keep you updated ! Yeah, it's not in the catalog if that's where you looked. 1
vincen 89 Posted May 4 Author Posted May 4 On 5/2/2026 at 8:49 PM, yocker said: In case you missed it, it doesn't have any image or anything as it was as said just AI and all it was asked was make a plugin to kill idle sessions. @yocker Just to let you know that it doesn't look to work. I don't know if it's due at my installation or Emby server version or something else but it doesn't delete any ghost sessions (I have setup it at 10 minutes to be sure). Also what is the exact use of the option in the plugin ? A little confused by the wording (When enabled, sessions currently playing media will also be terminated if they exceed the inactivity timeout.). How a playing session can be inactive ? because the ghost session are not progressing in play status. Thanks
yocker 2045 Posted May 4 Posted May 4 (edited) 2 hours ago, vincen said: @yocker Just to let you know that it doesn't look to work. I don't know if it's due at my installation or Emby server version or something else but it doesn't delete any ghost sessions (I have setup it at 10 minutes to be sure). Also what is the exact use of the option in the plugin ? A little confused by the wording (When enabled, sessions currently playing media will also be terminated if they exceed the inactivity timeout.). How a playing session can be inactive ? because the ghost session are not progressing in play status. Thanks With the setting you mentioned it will also terminate sessions that are NOT idle. It a stupid setting but one i asked it to add in case i had to do debugging. As said, this plugin was minimal effort from me and made with AI as i have enough to do with other things. With that setting off: User pauses or closes a video stream without exiting Emby, the stream will start to idle, when idle for the set amount of time the plugin will remove the session. Dashboard — Mozilla Firefox 2026-05-04 15-06-57.mp4 At around 28 seconds in you can see it removed the idle session. Users will not notice anything and can resume the stream as if nothing had happened. I've looked a bit through the code and can't see anything really wrong with it at first glance, it looks like the AI did a pretty good job at making it. I've tested it on Windows, Ubuntu and Docker versions of Emby and it works with all of them. Edited May 4 by yocker
vincen 89 Posted May 4 Author Posted May 4 38 minutes ago, yocker said: With the setting you mentioned it will also terminate sessions that are NOT idle. It a stupid setting but one i asked it to add in case i had to do debugging. As said, this plugin was minimal effort from me and made with AI as i have enough to do with other things. With that setting off: User pauses or closes a video stream without exiting Emby, the stream will start to idle, when idle for the set amount of time the plugin will remove the session. Thanks for all the tests and the video unhappy on my Emby server it doesn't work at all. I have setup it at 10 minutes without the option but it's doing nothing I checked in Emby logs but I see no mention anywhere of Session Killer. No idea what to test else to find the issue....
yocker 2045 Posted May 4 Posted May 4 I see the problem. It only works on the webclient as the apps sends a "keep-alive" alike signal. Will see if i can find out something though hadn't planned on working on this plugin at all. 1
