brcarls 2 Posted April 26 Posted April 26 It seems totally random to me... I usually just see a "Play" button and when I click it, sometimes it starts from beginning and sometimes from "Live". If it starts from Live, sometimes I can back out and see a "Start from Beginning" button appear, but clicking it often just goes back to the Live position... Sometimes it will never offer start from beginning and I have to sit there for a few minutes and manually rewind. Emby Server 4.9.3.0 Emby for Android 3.5.32
Luke 43719 Posted April 27 Posted April 27 HI, a lot depends on what screen you're on and where you are clicking play from. For example if you're on the channel screen, then you're only going to see a play button. But if you're on the screen for the active recording, then that's when you might see those different options.
brcarls 2 Posted April 27 Author Posted April 27 I'm always playing from the "Latest Recordings" in the Recordings tab of LiveTV. I assume that I just don't understand the intended behavior which is why it seems random (and frustrating) to me. I was hoping to be pointed to some documentation or previous discussion (which I failed to find, so asked here).
Luke 43719 Posted May 11 Posted May 11 On 4/27/2026 at 9:08 AM, brcarls said: I'm always playing from the "Latest Recordings" in the Recordings tab of LiveTV. I assume that I just don't understand the intended behavior which is why it seems random (and frustrating) to me. I was hoping to be pointed to some documentation or previous discussion (which I failed to find, so asked here). HI there, can you please provide a specific example? How to Report a Problem Thanks !
