Sage9307 2 Posted April 23 Posted April 23 Emby Server 4.9.3.0 on Linux virtual machine (no pass through GPU, no hardware acceleration, all CPU) Emby App 2.1.23g on Google TV Not sure what other settings I should include here. Problem: When starting a stream or after pausing and starting a stream, the audio does not work. Temporary Resolution: Exit the stream and re-start the stream, sometimes multiple times resolves this issue. I attached the log file. Thank you! embyserver.txt
Luke 43390 Posted April 24 Posted April 24 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
Sage9307 2 Posted April 25 Author Posted April 25 21 hours ago, Luke said: Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks. I searched for it on the TV "Emby for Android TV" and it is the same one as is installed on the system. I could not find a way to check the version on the Store, but there was the option to Open the app, and it opened the same app as is already installed. I did see another app called "Emby for Android" but that one is not installed. Is that the information you were looking for?
seanbuff 1439 Posted April 25 Posted April 25 6 hours ago, Sage9307 said: I did see another app called "Emby for Android" but that one is not installed. Yes, Luke is requesting you to install that version of the app (both can be installed simultaneously) and see if the problem persists when using that app.
Sage9307 2 Posted April 25 Author Posted April 25 1 hour ago, seanbuff said: Yes, Luke is requesting you to install that version of the app (both can be installed simultaneously) and see if the problem persists when using that app. Oh I see, sorry I didn't realize that. I will do that and reply to this thread. 1
Sage9307 2 Posted April 29 Author Posted April 29 I've tried the other Emby app and I am also experiencing audio issues with that one.
Sage9307 2 Posted May 12 Author Posted May 12 Still seeing these issues when pausing and resuming. We have to exit the show / movie to start it again to get audio working. I can't make heads or tails of the attached log files but I assume nothing obvious was there. If anyone has any tips please let me know, thank you.
Luke 43390 Posted June 15 Posted June 15 On 4/28/2026 at 8:29 PM, Sage9307 said: I've tried the other Emby app and I am also experiencing audio issues with that one. HI, what version number did you try?
Sage9307 2 Posted June 15 Author Posted June 15 30 minutes ago, Luke said: HI, what version number did you try? I apologize, I did not take down the number, I assume it was whatever was the latest available on Google Store. Since I did that over a month ago I don't recall it either. I'm not the one who watches Emby, so I asked my family and they said the audio issues haven't really happened much lately. I am now on the latest 4.9.5.0, so maybe a bunch of fixes went into effect. 1
